Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 04-17-2005, 01:55   #466 (permalink)
Member: 9891
Thanks Meter: 2
;*** EXR. Explorer Rightsoftkey (v2) ***
;Firmware: sl45v56
;Author: rizapn
;Created: July 16, 2004
;Modified: Apr 17, 2005 (v2)
;Modify RightSoftKey function in the Card Explorer, from Mark/Unmark
;to become "Open". Mark/Unmark is handled by '#' button.
;v2->[*] button has Mark/Unmark All function
0x189F98: 8B013900 E8012D00
0x189F9E: 8401 E801
0x3863C4: EA207869 EA203664
0x3863E4: EA204666 EA20E464
0x3863EC: EA204666 EA207869
0x386482: E6F72F00 EA009664
0x386496: E6F73900DC41B876A8C0 DC41A87646F72F002DF3
0x3864A0: D4D00200DAE7AE61F064F075F0C6F0D7 889088808860DAD89873EA00CE69DC47
0x3864B0: F0E8F0F906FEF001DAD8 F426010057F2FF00DB00
0x3869A2: E7F2FF00 DAD8AE64
0x38653C: 47FCFF00 57FCFF00
0x386540: 3D03 0D04
;rizapn
Old 04-18-2005, 03:45   #467 (permalink)
charlielao's Avatar
Member: 66040
Thanks Meter: 14
;*** Answering Machine while Incoming Call Ringing ***
;firmware: SL45iv56
;author: charlielao
;release: April 18, 2005
;Thank You to Prof Lalo and Charger
;changes right soft key from reject to activate answering machine while ;incoming call ringing
;needs ANM patch.
;use EP B814E3 on your FAV to disable ANM after the call
;0x444CDE: 40 10 ;<= change time to activate ANM (shorter)
;automatic clear of ANM function after incoming call is finished
;Menu/ Time/Charge /Charge Settings / Auto Display should be OFF
;because if it is ON, if you make outgoing call, the ANM function is continuosly
;set/cleared
3AFE50: EA2012FF DAB814E3
18F024: 4B03 BF0B ; change text Reject to ANM
18E314: FFFF 8890
18E316: FFFFFFFF D7403600 ; extp #36h, #1
18E31A: FFFFFFFF F2F96C09 ; mov r9, mem_D896C <= ANM selectable at ;Profile 2
18E31E: FFFFFFFF AAF90220 ; jbc r9.2, 9 <= ANM at Function 3
18E322: FFFF 2FF9 ; bset r9.2
18E324: FFFF 0D01 ; jmpr cc_UC, 5
18E326: FFFF 2EF9 ; bclr r9.2
18E328: FFFFFFFF D7403600 ; EXTP #36H, #1
18E32C: FFFFFFFF F6F96C09 ; mem_D896C, mov r9
18E330: FFFF 9890
18E332: FFFF DB00
;Edit message 99 : 0BBF "O2 - NL" => "ANM"
1AD232: 954F32202D204E4C00 95414E4D9595959500
;If you DON'T use JACT. Just Another CallingTime v2 use this:
0x0023F0: DAC79E85 DAB120E5
;If you USE JACT. Just Another CallingTime v2 use this instead:
;0x27DFEA: FAC79E85 DAB120E5
11E520: FFFFFFFF DAB814E3
11E524: FFFFFFFF FAC79E85
Old 04-20-2005, 07:40   #468 (permalink)
charlielao's Avatar
Member: 66040
Thanks Meter: 14
;*** Answering Machine while Incoming Call Ringing v2 ***
;firmware: SL45iv56
;author: charlielao
;release: April 20, 2005
;changes right soft key from reject to activate answering machine while incoming call ringing
;needs ANM patch selectable at P2F3
;0x444CDE: 40 05 ; <= change time to activate ANM (shorter)
;v2 Auto clear ANM (P2F3) after call has ended. Auto Clear selectable at P2F2
;disregard v1 (it doesnt work)
3AFE50: EA2012FF DAA86E40
08406E: FFFF 8890
084070: FFFFFFFFFFFFFFFFFFFFFFFFFFFF D7403600F2F96C092FF9D7403600
08407E: FFFFFFFFFFFFFFFF F6F96C099890DB00
444CC4: FAD414F3 FAC706D1
27D106: FFFFFFFFFFFFFFFFFFFF DAD414F38890D7403600
27D110: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2F96C099AF901102EF9DAA87A40DB00
Old 04-20-2005, 14:24   #469 (permalink)
Crazy Poster
Member: 82312
; *** SPAS. Show Picture, when Alarm is Set ***
;Firmware : SL45i v56
; Autor truhlik
;Release : 20.04.2005
;show any picture when you have alarm (appointments) set on
;need "Collection of mainscreen patches" by rc-flitzer
;selectable thru profile 1/14
;show picture #675 in right upper corner
0x27D700: CC00CC00 DAC7b6d6 ; if have installed patch by rc-flizter
;0x3B3A54: DAC1EC22 DAC7b6d6 ; can test install this,when not istalled patch by flitzer,but not tested!!
0x27D6B6: FFFFFFFFFFFFFFFFFFFF D7400E00F2F142BA9AF1
0x27D6C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0BD0DAA488AF48402D07E6FEA302E6FC
0x27D6D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 5D00E08DDAC1EC22DB00
;change picture 675
4BB9CE: 080B0100 06070100
4B9030: 0000000000000000000000 335B7B7BFF03230F0F0F0F
;locale=Czech_Czech Republic.1250
Old 04-20-2005, 21:52   #470 (permalink)
Froster's Avatar
Member: 91303
WARNING I leave this patch as a kind of curiosity. DO NOT apply it unless you want to make a joke on somebody.
;***Disable ringtones, vibra on both SKs and possibility of answering an incoming call ***
;Firmware: SL45iv56
;Author: Froster
;Date: 20.04.2005
; Patch changes the options Answer/Reject on incomming call
; which are on left and right SKs for Silence option - both ringtones
; as well as vibrations.
; WHAT'S MORE it disables the green key so there is no possibility of
;answering the call.
3AFE30: EA203CFF 3F002D2D
3AFE50: EA2012FF 3F002D2D
18F012: 5000 8A03
18F024: 4B03 8A03
Old 04-21-2005, 08:51   #471 (permalink)
Froster's Avatar
Member: 91303
;***SRSKIC - Silence the ringtones and vibra on both SKs on incoming call ***
;Firmware: SL45iv56
;Author: Lalo.Lerry
;Date: 21.04.2005
;left sk:
18F00E: 0C 4D ;button code 'M' (for mute)
18F012: 5000 8A03 ;button text
;right sk:
18F020: 59 4D ;button code 'M' (for mute)
18F024: 4B03 8A03 ;button text
;incoming call routine button handler - disalbe sk add on:
3AFE60: EA201EFF46F65C00EA2024FFEA002AFF 2D5E46F65C002D5E46F64D002D100D5D
Old 04-24-2005, 01:10   #472 (permalink)
Member: 9891
Thanks Meter: 2
;*** FTA. File Type Association ***
;Firmware : sl45v56
;Author : rizapn
;Created : August 8, 2004 (JSTV)
;Modified : April 24, 2005
;Need FAM & EXR patch. UNDO JSTV patch ...
;Associate any unknown file extension with any binary file ...
;Put the BIN file in the directory a:/zbin/ext, for example
;a:/zbin/ext/zzz.bin, then Open .zzz file will execute zzz.bin
;after loading that file content into the buffer.
;The opened file will be buffered in the RAM 22h:0 and BIN file
;is in the 20h:0 (just like opening a normal BIN file).
;If there is no associated BIN file, the file will be opened as
;a text file, and JSTV v3 patch will be executed.
;For JSTV v3 info, please read the JSTV patch remarks ...
;Using this patch together with midlet may produce unpredictable result.
;This patch use some RAM which is probably use also by the midlet.
0x18A5CA: 2801AB02 51025102
0x18A5F4: DEFFEB00 A450E400
0x3874CE: EAE0 EAE0
0x3874D0: 1876 1475
0x387514: 0804EA001076 DAE4204F0DEF
;Modify programmable shortcut "Currency Converter" -> "Read Memory"
0x18E39C: 3008 5102
0x18E3D0: D702 5807
0x18E482: 30083008 51025102
0x3AE394: DAA5BA6D DAE4A450
0x444F20: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F04806F4B200D7502F00F6F41835F6F9
0x444F30: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 1A35E00CE6FD2200E6F5E400E6F4784F
0x444F40: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FE0040D7703600885E884E88DE88CE
0x444F50: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FEF43FD770210088DE88CEE6F61C00
0x444F60: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DC49C4682C00DB00DC439922DC4DB92C
0x444F70: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2D0208C10DF9CB00D7502F00F2FC1835
0x444F80: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FD1A35E6FE2E00DAC7CC850841E6FC
0x444F90: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0236E6FD3700E6F2CE1AE6F39103BBE4
0x444FA0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F024F035BBE1E6F2DB1AE6F39103BBDC
0x444FB0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FC0236E6FE0001F0FEDADF3EA746F4
0x444FC0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFF2D1D88908880E008E6F920008840
0x444FD0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF A8C0F0D8F0E9E6FF0004DADFAEAB0084
0x444FE0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 46F800408D02E008089146F400042DF0
0x444FF0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 98C0DADF70C598809890FA0800008870
0x445000: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E017BB49E6FFF83FD750360098EF98FF
0x445010: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DC5588F488E4DC5DA84CD43C02004981
0x445020: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3D030033083400C3F01DF02CE003E004
0x445030: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E00540DFED328D0240CE9D2FBB2DDC4D
0x445040: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 998C2D2B48712D02DC4D999C09A147FA
0x445050: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9A00ED0846F420009D02F16A0DEA3DE9
0x445060: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F17A0DE749602D02F1A60D0349702D01
0x445070: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F1A7C0A42841F0C2F0D148712D05DC5D
0x445080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 898C899C08C25C1400C4BB06E108DC4D
0x445090: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF B98C00C70DC90D660D5BBB64E003DC4F
0x4450A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF B96E9870BB5FF03FF02EBB463D40F03D
0x4450B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F02CBB423D3C8890E6F9FE13E6FC381B
0x4450C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FD9103DAD6D40EF0C9E00DDAE65E5B
0x4450D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BB49F0EDF0DC49602D0949613D05E6FE
0x4450E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9103E6FD3C1B0D6D49622D67D7402200
0x4450F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2F2000049413D65F05EF04DE6FE3700
0x445100: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FD023646F400408D0268470851DC45
0x445110: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 99442D52C04248213D31DC4599444941
0x445120: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3DF1DC45982426F2010100420DEBE01C
0x445130: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FD3204FAE698F14830BD0846F32900
0x445140: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF AD0546F2FF3FED02E003CB00E013CB00
0x445150: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 46FC00408D06DD0228D10D0108D166FC
0x445160: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FF3FCB00E6F4F03FE6F52100DC7598C4
0x445170: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 98D498E498F4DC45A834CB0046F2FA00
0x445180: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FD0B26F2FB00F0325C822023DC459964
0x445190: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF C063002306F2FA0000220820D7402200
0x4451A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF A83256F3FFFFF146BB03F147BB010DAA
0x4451B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DC4EB94D08D1CB00BBFBE6FE3700E6FD
0x4451C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0236F0C9E00FDAE69C5946F9FE133D05
0x4451D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6F4001BE6FCF81A0D04E6F4201BE6FC
0x4451E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 181BE6F5910388508840F0D5DADA42B4
0x4451F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9890DB008890E6F9FF130D038890E6F9
0x445200: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FE13BB0648403D02FAE4C8509890DB00
0x445210: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 8880F08EBBA7E004E6F5220046F80A00
0x445220: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3D04DAEEAC1CEA00E459E01146F81800
0x445230: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3D0528C2E6F3FFFFEA00A85946F81900
0x445240: FFFFFFFFFFFFFFFF EA309059E0130DF8
0x445990: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6F1280046F817002D5946F81400EA20
0x4459A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 32520D32EA005051BBFD40DFED2A8D02
0x4459B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 40CE9D2740D5CD19ED0240C4CD16BBF2
0x4459C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DC4DA94C00C349403DEF28113DED4830
0x4459D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF AD0108C2BBE7E6F4F43FD750210088D4
0x4459E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C4E008F0489880CB00F0C4F0D5E6F3
0x4459F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F03FD750210098239833402C3DEC403D
0x445A00: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3DEAE6F852000DEEE6F33700E6F20036
0x445A10: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E001D7400E00F3F2B5393D02E7F21400
0x445A20: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7400E00F421B53947F22A003D04BB10
0x445A30: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 5921BB100D4A47F22300EA306C5AE102
0x445A40: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BB09E6FD2200E00CDC43A812EA004452
0x445A50: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF EA00625AEA00585AD7402100F7F2F83F
0x445A60: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CB00D7402100F3F2F83FCB0047F23000
0x445A70: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9D02EA00E45947F23900EDFB66F10F00
0x445A80: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DC43A8C2E6F4E80340C48D05F6FC0EFE
0x445A90: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 5B44F2FC0CFEF05C00555C3C00C500C1
0x445AA0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DC43B8C2E122BBD8E6FE3700E6FD0836
0x445AB0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6F26520E6F36167E6F40D50DC6E882D
0x445AC0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 883D884D08D6DAC71E89EA00E259613A
0x445AD0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2F7A62696E2F6578742F002E62696E00
0x445AE0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 18001800FFFF52005200FFFF52005200
0x445AF0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFF19001900FFFF0040000022000000
0x445B00: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FE13FF7F00000000F451E40000000000
0x445B10: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E01A9103000000000040000022000000
0x445B20: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FF13FF7F00000000FC51E40000000000
0x445B30: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E01A9103000000005D08FF7F01204A53
0x445B40: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 54562076332048656C70202020202020
0x445B50: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 20010D4C6566745366743A2050727650
0x445B60: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 6167650D52696768745366743A204E78
0x445B70: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 74506167650D4C4546543A2050727643
0x445B80: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 6861707465720D52494748543A204E78
0x445B90: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 74436861707465720D2A3A2048656C70
0x445BA0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2073637265656E0D233A20476F746F20
0x445BB0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 506167650D4469676974733A20506167
0x445BC0: FFFFFFFFFFFFFFFF 65204E6F2E0D0000
;rizapn
Old 04-27-2005, 07:28   #473 (permalink)
Member: 79973
;*** DCC. Don't Close On Accepting Call v2 ***
;v2 - sets mp3 on pause on incoming call and unpause it on call ending
;additionally contains fix for 'Address book skipping for sms view' patch,
;when number of incoming has taken from sim sometimes. It's no matter if
;you don't use it
3AFF4A: DAA0AC15 DAC780D6 ;on incoming
453300: 3D0C CC00 ;on accept
4532F4: 3D12 CC00
452b32: DAEEAC1C DAC7AED6 ;on end
452B30: 0D02 CC00
0x27D680: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7400C00F68F521AD7403200F2FCA82F
0x27D690: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3D02FAA0AC15E6FCE835E6FD0E00E6FE
0x27D6A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF AC00E6FF2400DAC130AAFAA0AC15D740
0x27D6B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3200F2FCA82F3D01DB00E6FCE835E6FD
0x27D6C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFF 0E00E6FEAC00E6FF2600FAC130AA
;ps: problem still is - I dont know how to move call screen to front, (if
;have some opened dialogs, such as mp3), so you must close all opened first,
;if you want to end call by yourself.
Old 05-09-2005, 06:03   #474 (permalink)
abomin's Avatar
Member: 48199
;*** Play ringtone only in the earphone (if it`s connected) ***
;Firmware: SLIK56
;Author: abomin
;Release: 30.04.2005
22E90E: E6FC0001E6FD0200DAC28AE6F2FC0081 F2FC0081DAC254E148413D0BE112F7F2
22E91E: DAC254E148402D14E112F7F20281F78E 0281F78E0481F78F0681F6F80881F6F9
22E92E: 0481F78F0681F6F80881F6F90A81E6FC 0A81E6FC0001E6FD0200DAC28AE60D08
22E93E: 0001E6FD0200DAC28AE60D02 CC00CC00CC00CC00CC00CC00
Old 05-09-2005, 10:28   #475 (permalink)
abomin's Avatar
Member: 48199
;*** Enable vibra when charging ***
;Firmware: SLIK56
;Author: abomin
;Release: 09.05.2005
22E660: 8A880960 CC00CC00
Old 05-11-2005, 11:33   #476 (permalink)
Member: 79973
;*** DCC. Don't Close On Accepting Call v3 ***
;UNDO previous version
;v3:
; - sets mp3 on pause on incoming call and unpause it on call ending
; - call screen shows normally when you have something opened
;you don't use it
4532F4: 3D12 CC00
4532FE: 48413D0CDC49D4C83000E02DDAD62A05E006DC49C4683000EA 007639 DC49D4C83000E02DDAD62A05E006DC49C4683000DAE57639FA C7F0D6
452B32: DAEEAC1C DAC7AED6
452B30: 0D02 CC00
0x27D6A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF AC00E6FF2400DAC130AAFAA0AC1548C0
0x27D6B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3D0FE004D7400E00F3F8B539D7400E00
0x27D6C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F484B63946F40C00EA20D0D6DAE64EF6
0x27D6D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7403200F2FCA82F3D01DB00E6FCE835
0x27D6E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FD0E00E6FEAC00E6FF2600FAC130AA
0x27D6F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FECEC6E6FFDA0088F088E0E6FC0000
0x27D700: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FD3500E03EE00FDAC186CA0804DB00
;If you have something opened and accepted call:
; - after changing volume during call, press ok in volume dialog, otherwise it
; close all previously opened dialogs;
; - after going to menu by rightsoft during call, you must close all opened, if
; you want to go back to callscreen
Old 05-14-2005, 03:30   #477 (permalink)
charlielao's Avatar
Member: 66040
Thanks Meter: 14
; *** SSSN - Show SMS Sender Number ***
; Firmware: SLIK
; Author: charlielao
; Created: May 14, 2005
; Thanks to DeadManS' SNC Patch. I used his idea and patch and modified it.
; This patch will show 10-digit SMS sender number when there is an incoming
; SMS. It will replace the operator code shown. If no ne SMS, op code
; is shown. Apply SNC first.
; If you dont want to use SNC, use this:
; 3B36E4: E00CE00D DAEE22A9
3B36E4: DAE000D0 DAEE0EA9
4EA90E: FFFF 8840
4EA910: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7400D00F2F4D8293D039840FAE000D0
4EA920: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 984088E088D088C088B088708860E6FC
4EA930: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0000E6FD0800E6FB0600E6F71703BB0D
4EA940: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BB0CBB0BBB0ABB099860987098B098C0
4EA950: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 98D098E0E00CE00DDB000871D7403200
4EA960: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF A9C7BB1ABB05BB0EBB1CBB02BB0BCB00
4EA970: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 28669D0406F60702F0E6CB0006F60702
4EA980: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F0E6CB0088B088C088D0DAC1EC2298D0
4EA990: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 98C098B000CBCB00E10D886067FC0F00
4EA9A0: FFFFFFFFFFFFFFFFFFFFFFFF CB00986067FCF0003C46CB00
;customize
;4EA930: 00 ; <-x
;4EA934: 08 ; <-y
;4EA938: 06 ; <-width digit picture + distance before
Old 05-15-2005, 22:44   #478 (permalink)
Member: 94448
; ***** Archer *****
;Simply arcade game
; sc0ty ([email protected])
; relased: May 15, 2005
; www.sc0ty.pro.tc
; Poznan, Poland
download
Old 05-17-2005, 21:57   #479 (permalink)
Member: 94448
;New wersion without a little bug connected with a stages counting
THIS VERSION IS REALLY CORRECT!
The same link:
download
Old 05-20-2005, 17:46   #480 (permalink)
Member: 60520
; *** No red key in SMS editor ***
;- Disable short press red button function in SMS editor
;Firmware : SL45v56
;Author : rc-flitzer
;based upon patch SRB from RizaPN
;Release : May 20th, 2005
; Pressing RED button short in SMS editor will have no effect anymore.
; Still pressing red button longer time will exit editor and save
; current message in outbox folder.
; Please undo SRB patch before applying this.
0x3A7C26: 46FC5A00 FAC730E0
0x27E030: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 48C13D02FADA507C46FC5A00FADA2A7C
SLIKv56: Flash Patching (3rd part) ... rizapn x4x, x5x Flashpatching 2900 12-24-2007 10:51
TOC for Sticky: SLIKv56: Flash patches. StevieRay x4x, x5x Flashpatching 17 10-15-2005 08:26
"Bugs" in Thread SLIKv56: Flash patches trustkill Siemens-Benq Flash Patching 2 07-13-2004 07:33
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? Uvedovle x4x, x5x Flashpatching 0 04-27-2004 10:32
Where can i download riza's SLIKv56: Flash Patching (3rd part) Gabriel_he Siemens-Benq Flash Patching 2 04-04-2003 03:20
Page generated in 0.38781 seconds with 11 queries
