04-17-2005, 01:55 | #466 (permalink) |
No Life Poster Join Date: Mar 2002 Location: -[r0]- Age: 53
Member: 9891 Status: Offline Thanks Meter: 2 | ;Firmware: sl45v56 ;Author: rizapn ;Created: July 16, 2004 ;Modified: Apr 17, 2005 (v2) ;Modify RightSoftKey function in the Card Explorer, from Mark/Unmark ;to become "Open". Mark/Unmark is handled by '#' button. ;v2->[*] button has Mark/Unmark All function 0x189F98: 8B013900 E8012D00 0x189F9E: 8401 E801 0x3863C4: EA207869 EA203664 0x3863E4: EA204666 EA20E464 0x3863EC: EA204666 EA207869 0x386482: E6F72F00 EA009664 0x386496: E6F73900DC41B876A8C0 DC41A87646F72F002DF3 0x3864A0: D4D00200DAE7AE61F064F075F0C6F0D7 889088808860DAD89873EA00CE69DC47 0x3864B0: F0E8F0F906FEF001DAD8 F426010057F2FF00DB00 0x3869A2: E7F2FF00 DAD8AE64 0x38653C: 47FCFF00 57FCFF00 0x386540: 3D03 0D04 ;rizapn |
04-18-2005, 03:45 | #467 (permalink) |
No Life Poster Join Date: May 2004
Member: 66040 Status: Offline Thanks Meter: 14 | ;*** Answering Machine while Incoming Call Ringing *** ;firmware: SL45iv56 ;author: charlielao ;release: April 18, 2005 ;Thank You to Prof Lalo and Charger ;changes right soft key from reject to activate answering machine while ;incoming call ringing ;needs ANM patch. ;use EP B814E3 on your FAV to disable ANM after the call ;0x444CDE: 40 10 ;<= change time to activate ANM (shorter) ;automatic clear of ANM function after incoming call is finished ;Menu/ Time/Charge /Charge Settings / Auto Display should be OFF ;because if it is ON, if you make outgoing call, the ANM function is continuosly ;set/cleared 3AFE50: EA2012FF DAB814E3 18F024: 4B03 BF0B ; change text Reject to ANM 18E314: FFFF 8890 18E316: FFFFFFFF D7403600 ; extp #36h, #1 18E31A: FFFFFFFF F2F96C09 ; mov r9, mem_D896C <= ANM selectable at ;Profile 2 18E31E: FFFFFFFF AAF90220 ; jbc r9.2, 9 <= ANM at Function 3 18E322: FFFF 2FF9 ; bset r9.2 18E324: FFFF 0D01 ; jmpr cc_UC, 5 18E326: FFFF 2EF9 ; bclr r9.2 18E328: FFFFFFFF D7403600 ; EXTP #36H, #1 18E32C: FFFFFFFF F6F96C09 ; mem_D896C, mov r9 18E330: FFFF 9890 18E332: FFFF DB00 ;Edit message 99 : 0BBF "O2 - NL" => "ANM" 1AD232: 954F32202D204E4C00 95414E4D9595959500 ;If you DON'T use JACT. Just Another CallingTime v2 use this: 0x0023F0: DAC79E85 DAB120E5 ;If you USE JACT. Just Another CallingTime v2 use this instead: ;0x27DFEA: FAC79E85 DAB120E5 11E520: FFFFFFFF DAB814E3 11E524: FFFFFFFF FAC79E85 Last edited by charlielao; 04-19-2005 at 06:43. |
04-20-2005, 07:40 | #468 (permalink) |
Member: 66040 Status: Offline Thanks Meter: 14 | ;*** Answering Machine while Incoming Call Ringing v2 *** ;firmware: SL45iv56 ;author: charlielao ;release: April 20, 2005 ;Thank You to Prof Lalo and Charger ;changes right soft key from reject to activate answering machine while incoming call ringing ;needs ANM patch selectable at P2F3 ;0x444CDE: 40 05 ; <= change time to activate ANM (shorter) ;v2 Auto clear ANM (P2F3) after call has ended. Auto Clear selectable at P2F2 ;disregard v1 (it doesnt work) 3AFE50: EA2012FF DAA86E40 18F024: 4B03 BF0B ; change text Reject to ANM 08406E: FFFF 8890 084070: FFFFFFFFFFFFFFFFFFFFFFFFFFFF D7403600F2F96C092FF9D7403600 08407E: FFFFFFFFFFFFFFFF F6F96C099890DB00 ;Edit message 99 : 0BBF "O2 - NL" => "ANM" 1AD232: 954F32202D204E4C00 95414E4D9595959500 444CC4: FAD414F3 FAC706D1 27D106: FFFFFFFFFFFFFFFFFFFF DAD414F38890D7403600 27D110: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2F96C099AF901102EF9DAA87A40DB00 |
04-20-2005, 14:24 | #469 (permalink) |
Crazy Poster Join Date: Sep 2004 Location: Czech Republic, Prague Age: 41
Member: 82312 Status: Offline Thanks Meter: 1 | ; *** SPAS. Show Picture, when Alarm is Set *** ;Firmware : SL45i v56 ; Autor truhlik ;Release : 20.04.2005 ;show any picture when you have alarm (appointments) set on ;need "Collection of mainscreen patches" by rc-flitzer ;selectable thru profile 1/14 ;show picture #675 in right upper corner 0x27D700: CC00CC00 DAC7b6d6 ; if have installed patch by rc-flizter ;0x3B3A54: DAC1EC22 DAC7b6d6 ; can test install this,when not istalled patch by flitzer,but not tested!! 0x27D6B6: FFFFFFFFFFFFFFFFFFFF D7400E00F2F142BA9AF1 0x27D6C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0BD0DAA488AF48402D07E6FEA302E6FC 0x27D6D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 5D00E08DDAC1EC22DB00 ;change picture 675 4BB9CE: 080B0100 06070100 4B9030: 0000000000000000000000 335B7B7BFF03230F0F0F0F ;locale=Czech_Czech Republic.1250 |
04-20-2005, 21:52 | #470 (permalink) |
Freak Poster Join Date: Nov 2004 Location: Poland Age: 41
Member: 91303 Status: Offline Thanks Meter: 0 | WARNING I leave this patch as a kind of curiosity. DO NOT apply it unless you want to make a joke on somebody. ;***Disable ringtones, vibra on both SKs and possibility of answering an incoming call *** ;Firmware: SL45iv56 ;Author: Froster ;Date: 20.04.2005 ; Patch changes the options Answer/Reject on incomming call ; which are on left and right SKs for Silence option - both ringtones ; as well as vibrations. ; WHAT'S MORE it disables the green key so there is no possibility of ;answering the call. 3AFE30: EA203CFF 3F002D2D 3AFE50: EA2012FF 3F002D2D 18F012: 5000 8A03 18F024: 4B03 8A03 Last edited by Froster; 04-21-2005 at 18:52. |
04-21-2005, 08:51 | #471 (permalink) |
Member: 91303 Status: Offline Thanks Meter: 0 | ;***SRSKIC - Silence the ringtones and vibra on both SKs on incoming call *** ;Firmware: SL45iv56 ;Author: Lalo.Lerry ;Date: 21.04.2005 ; Patch changes the options Answer/Reject on incomming call ; which are on left and right SKs for Silence option - both ringtones ; as well as vibrations. ;left sk: 18F00E: 0C 4D ;button code 'M' (for mute) 18F012: 5000 8A03 ;button text ;right sk: 18F020: 59 4D ;button code 'M' (for mute) 18F024: 4B03 8A03 ;button text ;incoming call routine button handler - disalbe sk add on: 3AFE60: EA201EFF46F65C00EA2024FFEA002AFF 2D5E46F65C002D5E46F64D002D100D5D Last edited by Froster; 04-21-2005 at 18:53. |
04-24-2005, 01:10 | #472 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | ;*** FTA. File Type Association *** ;Firmware : sl45v56 ;Author : rizapn ;Created : August 8, 2004 (JSTV) ;Modified : April 24, 2005 ;Need FAM & EXR patch. UNDO JSTV patch ... ;Associate any unknown file extension with any binary file ... ;Put the BIN file in the directory a:/zbin/ext, for example ;a:/zbin/ext/zzz.bin, then Open .zzz file will execute zzz.bin ;after loading that file content into the buffer. ;The opened file will be buffered in the RAM 22h:0 and BIN file ;is in the 20h:0 (just like opening a normal BIN file). ;If there is no associated BIN file, the file will be opened as ;a text file, and JSTV v3 patch will be executed. ;For JSTV v3 info, please read the JSTV patch remarks ... ;Using this patch together with midlet may produce unpredictable result. ;This patch use some RAM which is probably use also by the midlet. 0x18A5CA: 2801AB02 51025102 0x18A5F4: DEFFEB00 A450E400 0x3874CE: EAE0 EAE0 0x3874D0: 1876 1475 0x387514: 0804EA001076 DAE4204F0DEF ;Modify programmable shortcut "Currency Converter" -> "Read Memory" 0x18E39C: 3008 5102 0x18E3D0: D702 5807 0x18E482: 30083008 51025102 0x3AE394: DAA5BA6D DAE4A450 0x444F20: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F04806F4B200D7502F00F6F41835F6F9 0x444F30: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 1A35E00CE6FD2200E6F5E400E6F4784F 0x444F40: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FE0040D7703600885E884E88DE88CE 0x444F50: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FEF43FD770210088DE88CEE6F61C00 0x444F60: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DC49C4682C00DB00DC439922DC4DB92C 0x444F70: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2D0208C10DF9CB00D7502F00F2FC1835 0x444F80: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FD1A35E6FE2E00DAC7CC850841E6FC 0x444F90: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0236E6FD3700E6F2CE1AE6F39103BBE4 0x444FA0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F024F035BBE1E6F2DB1AE6F39103BBDC 0x444FB0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FC0236E6FE0001F0FEDADF3EA746F4 0x444FC0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFF2D1D88908880E008E6F920008840 0x444FD0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF A8C0F0D8F0E9E6FF0004DADFAEAB0084 0x444FE0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 46F800408D02E008089146F400042DF0 0x444FF0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 98C0DADF70C598809890FA0800008870 0x445000: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E017BB49E6FFF83FD750360098EF98FF 0x445010: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DC5588F488E4DC5DA84CD43C02004981 0x445020: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3D030033083400C3F01DF02CE003E004 0x445030: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E00540DFED328D0240CE9D2FBB2DDC4D 0x445040: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 998C2D2B48712D02DC4D999C09A147FA 0x445050: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9A00ED0846F420009D02F16A0DEA3DE9 0x445060: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F17A0DE749602D02F1A60D0349702D01 0x445070: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F1A7C0A42841F0C2F0D148712D05DC5D 0x445080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 898C899C08C25C1400C4BB06E108DC4D 0x445090: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF B98C00C70DC90D660D5BBB64E003DC4F 0x4450A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF B96E9870BB5FF03FF02EBB463D40F03D 0x4450B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F02CBB423D3C8890E6F9FE13E6FC381B 0x4450C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FD9103DAD6D40EF0C9E00DDAE65E5B 0x4450D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BB49F0EDF0DC49602D0949613D05E6FE 0x4450E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9103E6FD3C1B0D6D49622D67D7402200 0x4450F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2F2000049413D65F05EF04DE6FE3700 0x445100: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FD023646F400408D0268470851DC45 0x445110: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 99442D52C04248213D31DC4599444941 0x445120: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3DF1DC45982426F2010100420DEBE01C 0x445130: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FD3204FAE698F14830BD0846F32900 0x445140: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF AD0546F2FF3FED02E003CB00E013CB00 0x445150: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 46FC00408D06DD0228D10D0108D166FC 0x445160: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FF3FCB00E6F4F03FE6F52100DC7598C4 0x445170: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 98D498E498F4DC45A834CB0046F2FA00 0x445180: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FD0B26F2FB00F0325C822023DC459964 0x445190: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF C063002306F2FA0000220820D7402200 0x4451A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF A83256F3FFFFF146BB03F147BB010DAA 0x4451B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DC4EB94D08D1CB00BBFBE6FE3700E6FD 0x4451C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0236F0C9E00FDAE69C5946F9FE133D05 0x4451D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6F4001BE6FCF81A0D04E6F4201BE6FC 0x4451E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 181BE6F5910388508840F0D5DADA42B4 0x4451F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9890DB008890E6F9FF130D038890E6F9 0x445200: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FE13BB0648403D02FAE4C8509890DB00 0x445210: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 8880F08EBBA7E004E6F5220046F80A00 0x445220: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3D04DAEEAC1CEA00E459E01146F81800 0x445230: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3D0528C2E6F3FFFFEA00A85946F81900 0x445240: FFFFFFFFFFFFFFFF EA309059E0130DF8 0x445990: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6F1280046F817002D5946F81400EA20 0x4459A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 32520D32EA005051BBFD40DFED2A8D02 0x4459B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 40CE9D2740D5CD19ED0240C4CD16BBF2 0x4459C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DC4DA94C00C349403DEF28113DED4830 0x4459D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF AD0108C2BBE7E6F4F43FD750210088D4 0x4459E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88C4E008F0489880CB00F0C4F0D5E6F3 0x4459F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F03FD750210098239833402C3DEC403D 0x445A00: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3DEAE6F852000DEEE6F33700E6F20036 0x445A10: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E001D7400E00F3F2B5393D02E7F21400 0x445A20: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7400E00F421B53947F22A003D04BB10 0x445A30: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 5921BB100D4A47F22300EA306C5AE102 0x445A40: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BB09E6FD2200E00CDC43A812EA004452 0x445A50: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF EA00625AEA00585AD7402100F7F2F83F 0x445A60: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CB00D7402100F3F2F83FCB0047F23000 0x445A70: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 9D02EA00E45947F23900EDFB66F10F00 0x445A80: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DC43A8C2E6F4E80340C48D05F6FC0EFE 0x445A90: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 5B44F2FC0CFEF05C00555C3C00C500C1 0x445AA0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DC43B8C2E122BBD8E6FE3700E6FD0836 0x445AB0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6F26520E6F36167E6F40D50DC6E882D 0x445AC0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 883D884D08D6DAC71E89EA00E259613A 0x445AD0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2F7A62696E2F6578742F002E62696E00 0x445AE0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 18001800FFFF52005200FFFF52005200 0x445AF0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFF19001900FFFF0040000022000000 0x445B00: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FE13FF7F00000000F451E40000000000 0x445B10: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E01A9103000000000040000022000000 0x445B20: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FF13FF7F00000000FC51E40000000000 0x445B30: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E01A9103000000005D08FF7F01204A53 0x445B40: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 54562076332048656C70202020202020 0x445B50: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 20010D4C6566745366743A2050727650 0x445B60: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 6167650D52696768745366743A204E78 0x445B70: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 74506167650D4C4546543A2050727643 0x445B80: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 6861707465720D52494748543A204E78 0x445B90: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 74436861707465720D2A3A2048656C70 0x445BA0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2073637265656E0D233A20476F746F20 0x445BB0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 506167650D4469676974733A20506167 0x445BC0: FFFFFFFFFFFFFFFF 65204E6F2E0D0000 ;rizapn |
04-27-2005, 07:28 | #473 (permalink) |
Major Poster Join Date: Aug 2004 Age: 40
Member: 79973 Status: Offline Thanks Meter: 0 | ;*** DCC. Don't Close On Accepting Call v2 *** ;v2 - sets mp3 on pause on incoming call and unpause it on call ending ;additionally contains fix for 'Address book skipping for sms view' patch, ;when number of incoming has taken from sim sometimes. It's no matter if ;you don't use it 3AFF4A: DAA0AC15 DAC780D6 ;on incoming 453300: 3D0C CC00 ;on accept 4532F4: 3D12 CC00 452b32: DAEEAC1C DAC7AED6 ;on end 452B30: 0D02 CC00 0x27D680: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7400C00F68F521AD7403200F2FCA82F 0x27D690: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3D02FAA0AC15E6FCE835E6FD0E00E6FE 0x27D6A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF AC00E6FF2400DAC130AAFAA0AC15D740 0x27D6B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3200F2FCA82F3D01DB00E6FCE835E6FD 0x27D6C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFF 0E00E6FEAC00E6FF2600FAC130AA ;ps: problem still is - I dont know how to move call screen to front, (if ;have some opened dialogs, such as mp3), so you must close all opened first, ;if you want to end call by yourself. |
05-09-2005, 06:03 | #474 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Russia inc. Age: 51
Member: 48199 Status: Offline Thanks Meter: 0 | ;*** Play ringtone only in the earphone (if it`s connected) *** ; ;Firmware: SLIK56 ;Author: abomin ;Release: 30.04.2005 ; 22E90E: E6FC0001E6FD0200DAC28AE6F2FC0081 F2FC0081DAC254E148413D0BE112F7F2 22E91E: DAC254E148402D14E112F7F20281F78E 0281F78E0481F78F0681F6F80881F6F9 22E92E: 0481F78F0681F6F80881F6F90A81E6FC 0A81E6FC0001E6FD0200DAC28AE60D08 22E93E: 0001E6FD0200DAC28AE60D02 CC00CC00CC00CC00CC00CC00 ;------------------------------- |
05-09-2005, 10:28 | #475 (permalink) |
Member: 48199 Status: Offline Thanks Meter: 0 | ;*** Enable vibra when charging *** ; ;Firmware: SLIK56 ;Author: abomin ;Release: 09.05.2005 ; 22E660: 8A880960 CC00CC00 ;--------------------------- |
05-11-2005, 11:33 | #476 (permalink) |
Member: 79973 Status: Offline Thanks Meter: 0 | ;*** DCC. Don't Close On Accepting Call v3 *** ;UNDO previous version ;v3: ; - sets mp3 on pause on incoming call and unpause it on call ending ; - call screen shows normally when you have something opened ;additionally contains fix for 'Address book skipping for sms view' patch, ;when number of incoming has taken from sim sometimes. It's no matter if ;you don't use it 3AFF4A: DAA0AC15 DAC780D6 4532F4: 3D12 CC00 4532FE: 48413D0CDC49D4C83000E02DDAD62A05E006DC49C4683000EA 007639 DC49D4C83000E02DDAD62A05E006DC49C4683000DAE57639FA C7F0D6 452B32: DAEEAC1C DAC7AED6 452B30: 0D02 CC00 0x27D680: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7400C00F68F521AD7403200F2FCA82F 0x27D690: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3D02FAA0AC15E6FCE835E6FD0E00E6FE 0x27D6A0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF AC00E6FF2400DAC130AAFAA0AC1548C0 0x27D6B0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3D0FE004D7400E00F3F8B539D7400E00 0x27D6C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F484B63946F40C00EA20D0D6DAE64EF6 0x27D6D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7403200F2FCA82F3D01DB00E6FCE835 0x27D6E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FD0E00E6FEAC00E6FF2600FAC130AA 0x27D6F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FECEC6E6FFDA0088F088E0E6FC0000 0x27D700: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FD3500E03EE00FDAC186CA0804DB00 ;If you have something opened and accepted call: ; - after changing volume during call, press ok in volume dialog, otherwise it ; close all previously opened dialogs; ; - after going to menu by rightsoft during call, you must close all opened, if ; you want to go back to callscreen |
05-14-2005, 03:30 | #477 (permalink) |
Member: 66040 Status: Offline Thanks Meter: 14 | ; *** SSSN - Show SMS Sender Number *** ; Firmware: SLIK ; Author: charlielao ; Created: May 14, 2005 ; Thanks to DeadManS' SNC Patch. I used his idea and patch and modified it. ; This patch will show 10-digit SMS sender number when there is an incoming ; SMS. It will replace the operator code shown. If no ne SMS, op code ; is shown. Apply SNC first. ; If you dont want to use SNC, use this: ; 3B36E4: E00CE00D DAEE22A9 3B36E4: DAE000D0 DAEE0EA9 4EA90E: FFFF 8840 4EA910: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7400D00F2F4D8293D039840FAE000D0 4EA920: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 984088E088D088C088B088708860E6FC 4EA930: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0000E6FD0800E6FB0600E6F71703BB0D 4EA940: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BB0CBB0BBB0ABB099860987098B098C0 4EA950: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 98D098E0E00CE00DDB000871D7403200 4EA960: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF A9C7BB1ABB05BB0EBB1CBB02BB0BCB00 4EA970: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 28669D0406F60702F0E6CB0006F60702 4EA980: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F0E6CB0088B088C088D0DAC1EC2298D0 4EA990: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 98C098B000CBCB00E10D886067FC0F00 4EA9A0: FFFFFFFFFFFFFFFFFFFFFFFF CB00986067FCF0003C46CB00 ;customize ;4EA930: 00 ; <-x ;4EA934: 08 ; <-y ;4EA938: 06 ; <-width digit picture + distance before |
05-15-2005, 22:44 | #478 (permalink) |
Insane Poster Join Date: Nov 2004 Location: Poznan, Poland Age: 37
Member: 94448 Status: Offline Thanks Meter: 0 | ; ***** Archer ***** ;Simply arcade game ; sc0ty ([email protected]) ; relased: May 15, 2005 ; www.sc0ty.pro.tc ; Poznan, Poland download |
05-17-2005, 21:57 | #479 (permalink) |
Member: 94448 Status: Offline Thanks Meter: 0 | ; ***** Archer ***** ;New wersion without a little bug connected with a stages counting THIS VERSION IS REALLY CORRECT! The same link: download Last edited by sc0ty; 05-18-2005 at 08:14. |
05-20-2005, 17:46 | #480 (permalink) |
No Life Poster Join Date: Mar 2004
Member: 60520 Status: Offline Thanks Meter: 0 | ; *** No red key in SMS editor *** ;- Disable short press red button function in SMS editor ;Firmware : SL45v56 ;Author : rc-flitzer ;based upon patch SRB from RizaPN ;Release : May 20th, 2005 ; Pressing RED button short in SMS editor will have no effect anymore. ; Still pressing red button longer time will exit editor and save ; current message in outbox folder. ; Please undo SRB patch before applying this. 0x3A7C26: 46FC5A00 FAC730E0 0x27E030: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 48C13D02FADA507C46FC5A00FADA2A7C |
SLIKv56: Flash Patching (3rd part) ... | rizapn | x4x, x5x Flashpatching | 2900 | 12-24-2007 10:51 |
TOC for Sticky: SLIKv56: Flash patches. | StevieRay | x4x, x5x Flashpatching | 17 | 10-15-2005 08:26 |
"Bugs" in Thread SLIKv56: Flash patches | trustkill | Siemens-Benq Flash Patching | 2 | 07-13-2004 07:33 |
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? | Uvedovle | x4x, x5x Flashpatching | 0 | 04-27-2004 10:32 |
Where can i download riza's SLIKv56: Flash Patching (3rd part) | Gabriel_he | Siemens-Benq Flash Patching | 2 | 04-04-2003 03:20 |
