01-30-2003, 15:14 | #1 (permalink) |
Major Poster Join Date: Jan 2003
Member: 20543 Status: Offline Thanks Meter: 2 | SLIKv56: Flash patches We could keep the first post as a table of content, and each further post as an individual patch. Here are the first patches: [list=1][*]Create new shortcut for Inbox SMS (located on the SIM card)[*]Create new shortcut for Outbox SMS (located on the SIM card)[*]Eliminate the additional "_nnn_nnn" string when moving SMS to the archive folder[*]Get access to "SIM Location" directly using front UP Arrow key[*]Add "Send via IrDA ..." options in CardExplorer[*]Overwrite "VoiceDialling" shortcut with "Display" shortcut[*]Overwrite "VoiceDialling" shortcut with "Illumination Toggle"[*]Use # short button to release the key-lock[*]Use * [GREEN] as an Illumination Toggle shortcut[*]Disable "Do you want to copy all SIM Card content to the phonebook" message when change SIM Card[*]Use * 0 and # followed by [GREEN] button as shortcuts[*]Use LEFT Arrow key as a "SIM-Location" shortcut[*]*NEW* Long press of left side [+] button for "Illumination Toggle" and its short press for IrDA[*]*NEW* Overwrite selectable "User Group" shortcut/hotkey with "Archive"[/list=1] Instructions for fast modification without full-flash:[list=1][*]The patch shows at which address the bytes need to be changed. Each address is in the form: 0xYYZZZZ[*]Download the flash from address 0xYY0000 with a size of 0x10000 (use UniSiemens or other suitable software)[*]Save the downloaded block as a local file, name it sl45_YY.bin (use the actual digits instead of YY)[*]Open the file in your favourite hex editor (I use UltraEdit)[*]Navigate to address 0xZZZZ[*]Verify that the bytes to be modified have the correct value; if they don't, do not perform the patch: you might be using a different firmware version which requires a different patch or location[*]Modify the bytes as intructed in the patch[*]Save the modified flash file as sl45_YY.bin[*]Repeat the operation for any other location that needs to be modified until all the bytes have been changed. You might end up with more than one file[*]Upload the modified sl45_YY.bin file(s) to the phone at address 0xYY0000 with a size of 0x10000[/list=1] Last edited by zdob; 12-18-2003 at 14:35. |
The Following User Says Thank You to arman68 For This Useful Post: |
01-30-2003, 15:16 | #2 (permalink) |
Member: 20543 Status: Offline Thanks Meter: 2 | Create new shortcut for Inbox SMS (located on the SIM card) Firmware: SL45 v56 Author: RizaPN * overwrite 'Profile' shortcut * use your full-flash file 0x18E3AC : 2A 08 ==> 5A 03 0x18E3E0 : 0B 02 ==> D3 00 0x18E524 : 2A 08 2A 08 ==> 5A 03 5B 03 0x3AE412 : DA DF 94 4C ==> DA D9 EE 0A For fast modification, if there is no full-flash yet, just download the flash from address 0x180000 with size 0x10000 and from 0x3A0000 size 0x10000 (partials). Name the first one as sl45_18.bin and the 2nd as sl45_3A.bin Addresses to be modified from file sl45_18.bin is : and E3AC, E3E0, E524. Address to be modified from file sl45_3A.bin is E412. After the modification, upload sl45_18.bin to the phone at address 0x180000 with size 0x10000, and sl45_3A.bin to 0x3A0000 size 0x10000. Last edited by arman68; 01-31-2003 at 11:55. |
01-30-2003, 15:18 | #3 (permalink) |
Member: 20543 Status: Offline Thanks Meter: 2 | Create new shortcut for Outbox SMS (located on the SIM card) Firmware: SL45 v56 Author: RizaPN * overwrite 'Conceal ID' shortcut * use your full-flash file 0x18E38A : 49 ==> 92 0x18E3BE : 4A 01 ==> 69 00 0x18E416 : 49 01 49 01 ==> 92 01 92 01 0x3AE308 : DA DA 04 A3 ==> DA D9 F8 0A 0x18E38A is address in the full flash file, 49 is the original value(s), and 92 is the new value(s)... For fast modification, if there is no full-flash yet, just download the flash from address 0x180000 with size 0x10000 and from 0x3A0000 size 0x10000 (partials). Name the first one as sl45_18.bin and the 2nd as sl45_3A.bin Addresses to be modified from file sl45_18.bin is : E38A, E3BE, E416. Address to be modified from file sl45_3A.bin is E308. After the modification, upload sl45_18.bin to the phone at address 0x180000 with size 0x10000, and sl45_3A.bin to 0x3A0000 size 0x10000. Last edited by arman68; 01-31-2003 at 11:54. |
01-30-2003, 15:19 | #4 (permalink) |
Member: 20543 Status: Offline Thanks Meter: 2 | Eliminate the additional "_nnn_nnn" string when moving SMS to the archive folder Firmware: SL45 v56 Author: RizaPN 0x39FE5C : 88 60 F0 C8 ==> FA D9 02 FF Last edited by arman68; 01-31-2003 at 11:53. |
01-30-2003, 15:21 | #5 (permalink) |
Member: 20543 Status: Offline Thanks Meter: 2 | Get access to "SIM Location" directly using front UP Arrow key Firmware: SL45 v56 Author: RizaPN original: 0x3B0366 : EA 20 3C 04 48 C3 EA 20 0x3B036E : 3C 04 46 FC 20 00 EA 20 0x3B0376 : 5A 04 48 C6 EA 20 82 04 modify to: 0x3B0366 : 2D 6A 48 C3 2D 68 46 FC 0x3B036E : 20 00 2D 74 48 C6 EA 20 0x3B0376 : 82 04 46 FC 21 00 2D 7E original: 0x3B0474 : E0 0C E0 0D E0 0E DA D4 AC 70 modify to: 0x3B0474 : DA DB 3C EF 0D 02 DA DB 46 EF Last edited by arman68; 01-31-2003 at 11:52. |
01-30-2003, 15:22 | #6 (permalink) |
Member: 20543 Status: Offline Thanks Meter: 2 | Add "Send via IrDA ..." options in CardExplorer Firmware: SL45 v56 Author: RizaPN This patch will *overwrite* ---Help--- menu inside the Sort menu with the new "Send via IrDA" options. 0x18A3E4 : 28 01 28 01 => 21 02 21 02 (change the text) 0x18A3FE : AE AB => A4 7D (change the function address) Last edited by arman68; 01-31-2003 at 11:51. |
01-31-2003, 11:45 | #7 (permalink) |
Member: 20543 Status: Offline Thanks Meter: 2 | Overwrite "VoiceDialling" shortcut with "Display" shortcut Firmware: SL45 v56 Author: RizaPN Use Left side button [+] to access VoiceDialling. 0x18E3A0 : 4E 02 --> 60 00 (shorcut Start: text) 0x18E3D4 : 4F 02 --> 60 00 (upper-right button text) 0x18E4A6 : 4E 02 4E 02 --> 60 00 60 00 (menu item text) 0x3AE3B2 : DA E6 F8 A9 --> DA D5 6A F2 (function entry-point) It will give the access to the "Display" menu directly. Last edited by arman68; 01-31-2003 at 11:50. |
01-31-2003, 11:49 | #8 (permalink) |
Member: 20543 Status: Offline Thanks Meter: 2 | Overwrite "VoiceDialling" shortcut with "Illumination Toggle" Firmware: SL45 v56 Author: RizaPN Use Left side button [+] to access VoiceDialling. 0x18E3A0 : 4E 02 --> 82 00 0x18E3D4 : 4F 02 --> 82 00 0x18E4A6 : 4E 02 4E 02 --> 82 00 82 00 0x3AE3B2 : DA E6 F8 A9 --> DA DC 80 46 It can be used to assign a single button for doing Illumination Toggle as in SLCK firmwares. |
02-04-2003, 12:22 | #9 (permalink) |
Member: 20543 Status: Offline Thanks Meter: 2 | Use # short button to release the key-lock Firmware: SL45 v56 Author: RizaPN 0x3B07C4 : 1E -> 14 0x3B07C7 : 03 -> 04 0x3B07CA : 1F -> 21 0x3B07CE : DA A2 18 4C 48 40 2D 10 -> 0D 03 DA DA EC F6 0D 0F If you want to use * instead of #, modify 0x3B07CA with 13. For other button, use the value listed in the button code table. * That patch also unhides a VoiceDial function * Press UP arrow key when the key is locked to activate the VoiceDial function. If you want to use another button, just modify the value in 0x3B07C4 with the listed button code. Button Code: 5C : UPPER LEFT 05 : GREEN 01 : RED 03 : UPPER RIGHT 22 : RIGHT ARROW 20 : DOWN ARROW 21 : UP ARROW 23 : LEFT ARROW 13 : * 14 : # 15 : DIGIT 0-9 1F : LONG # 0E : LEFT SIDE + 0D : LEFT SIDE - 62 : LEFT SIDE PLAY |
02-04-2003, 12:27 | #10 (permalink) |
Member: 20543 Status: Offline Thanks Meter: 2 | Use[*][GREEN] as an Illumination Toggle shortcut Firmware: SL45 v56 Author: RizaPN 0x3AD7A4 : E6 FC 0A 00 E6 FD 36 00 -> E6 00 36 00 F3 FC 0A 00 0x3AD7AC : DA DB 00 30 48 40 3D 21 -> 47 FC 2A 00 3D 04 DA DC 0x3AD7B4 : E6 00 36 00 CC 00 -> 80 46 EA 00 04 DA If you want to use 0[GREEN], just modify 2A (0x3AD7AE) with 30. If you want to use #[GREEN] use 23 ... |
02-04-2003, 12:35 | #12 (permalink) |
Member: 20543 Status: Offline Thanks Meter: 2 | Use[*] [0] and [#] followed by [GREEN] button as shortcuts Firmware: SL45 v56 Author: RizaPN 0x3AD7A4 : E6 FC 0A 00 E6 FD 36 00 -> E6 00 36 00 F3 FC 0A 00 0x3AD7B2 : 2D 19 -> 2D 12 0x3B3000 : F0 ED 70 EC 2D 0B DC 4D -> E0 14 27 FC 23 00 3D 03 0x3B3008 : A9 2C 47 F2 -> DA D8 B4 E1 ([#] button function) 0x3B300C : 30 00 2D 06 47 F2 -> 0D 09 29 C7 3D 03 0x3B3012 : 2A 00 2D 03 -> DA DC 80 46 ([*] button function) 0x3B3016 : 47 F2 23 00 3D 02 -> 0D 04 29 C6 3D 03 0x3B301C : E0 04 DB 00 -> DA D9 62 0A ([0] button function) 0x3B3020 : E0 14 DB 00 -> E0 04 DB 00 It will assign : [#][GREEN] as a shortcut to "Java",[*][GREEN] as a shortcut to "Illumination Toggle", [0][GREEN] as a shortcut to "Write Message" ... Remark: if you already apply patch : "[*][GREEN] as an Illumination Toggle shortcut" then you need to reset some addresses back to their original values. |
02-04-2003, 12:38 | #13 (permalink) |
Member: 20543 Status: Offline Thanks Meter: 2 | Use LEFT Arrow key as a "SIM-Location" shortcut Firmware: SL45 v56 Author: RizaPN * If you already apply patch for UP Arrow as a "SIM-Location" shortcut, and want to apply this patch, please reset them back to the original values * [font=courier new] 0x3B03B0 : EA 20 0A 05 46 FC 14 00 -> 8D 04 46 FC 15 00 EA F0 0x3B03B8 : EA 20 0A 05 46 FC 15 00 -> 0A 05 46 FC 23 00 2D 5D 0x3B0474 : E0 0C E0 0D E0 0E -> DA DB 3C EF 0D 02 0x3B047A : DA D4 AC 70 -> DA DB 46 EF [font] |
02-04-2003, 12:39 | #14 (permalink) |
Member: 20543 Status: Offline Thanks Meter: 2 | Use RIGHT Arrow key as a "Card-Explorer" shortcut Firmware: SL45 v56 Author: RizaPN It will overwrite the previous function (entered to the Main Menu) 0x3B0368 : 3C -> 54 0x3B0450 : F0 C4 DA E5 -> EA 00 EE 07 0x3B0454 : 24 3A EA 00 F4 07 -> DA D8 CA E1 0D 23 |
02-06-2003, 10:26 | #15 (permalink) |
Member: 20543 Status: Offline Thanks Meter: 2 | Long press of left side [+] button for "Illumination Toggle" and its short press for IrDA Firmware: SL45 v56 Author: RizaPN 0x3B04A4 : DA A2 18 4C 48 40 EA 20 -> DC 59 98 C8 A8 D8 DC 4D 0x3B04AC : F6 07 DC 59 -> D4 8C 04 00 0x3B04B0 : 98 C8 A8 D8 DC 4D -> 46 F8 EB 00 2D 03 0x3B04B6 : D4 8C 04 00 -> DA DC E8 46 ... (*) 0x3B04BA : 46 F8 EB 00 EA 30 F6 07 -> 0D 07 E0 1C E6 FD 82 00 0x3B04C2 : E0 1C DA F0 -> DA E6 98 F1 0x3B04C6 : 50 83 EA 00 -> DA DC 80 46 0x3B04CA : D6 07 -> 0D 0B * Known bug : IrDA will also toggled for long-press ... If you want to apply this patch withour IrDA capability, use : 0x3B04B6 : D4 8C 04 00 -> CC 00 CC 00 ... (without IrDA) |
SLIKv56: Flash Patching (3rd part) ... | rizapn | x4x, x5x Flashpatching | 2900 | 12-24-2007 10:51 |
TOC for Sticky: SLIKv56: Flash patches. | StevieRay | x4x, x5x Flashpatching | 17 | 10-15-2005 08:26 |
"Bugs" in Thread SLIKv56: Flash patches | trustkill | Siemens-Benq Flash Patching | 2 | 07-13-2004 07:33 |
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? | Uvedovle | x4x, x5x Flashpatching | 0 | 04-27-2004 10:32 |
Where can i download riza's SLIKv56: Flash Patching (3rd part) | Gabriel_he | Siemens-Benq Flash Patching | 2 | 04-04-2003 03:20 |
