Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 03-23-2003, 00:53   #46 (permalink)
Member: 9891
Thanks Meter: 2
More Shortcut ... 0-9 followed by RIGHT Arrow
*** More shortcut, 0-9,#, and + followed by [RIGHT Arrow] for Midlet Access ***
Firmware : SL45v56
Author : RizaPN
Version : 02
Just another way to access java-midlet directly using shortcut.
For anyone who already apply the 1st version of this patch, please update with this version !
0x3AD9D0 : 46 F4 29 00 3D 1F E6 00 -> 48 41 3D 04 DA C7 20 D4
0x3AD9D8 : 36 00 CC 00 F2 FC 00 00 -> 0D 15 CC 00 E6 00 36 00
0x3AD9E4 : DA F1 EC 10 46 F4 29 00 -> F2 FC 00 00 DA F1 EC 10
0x3AD9EC : 3D 13 -> 0D 13
0x27D420 : FF FF FF FF FF FF FF FF -> E6 F1 10 00 88 10 E6 FC
0x27D428 : FF FF FF FF FF FF FF FF -> 40 38 E6 FD 11 00 E6 FE
0x27D430 : FF FF FF FF FF FF FF FF -> 60 14 E6 FF 1F 03 DA C7
0x27D438 : FF FF FF FF FF FF FF FF -> 9E 85 08 02 D7 40 36 00
0x27D440 : FF FF FF FF FF FF FF FF -> C2 F1 0A 00 D7 40 11 00
0x27D448 : FF FF FF FF FF FF FF FF -> F7 F2 4A 38 E6 FC 40 38
0x27D450 : FF FF FF FF FF FF FF FF -> E6 FD 11 00 E0 1E DA C8
0x27D458 : FF FF FF FF FF FF FF FF -> DE 0B DB 00 FF FF FF FF
0x27D460 : FF FF FF FF FF FF FF FF -> 61 3A 2F 6A 61 76 61 2F
0x27D468 : FF FF FF FF FF FF FF FF -> 73 2F 78 2E 6A 61 64 00
Using this patch, you need to copy "your_midlet.jad" to directory /java/s/x.jad ... x is the shortcut code (0-9, #, and +), for example copy /java/jam/Game1/Game1.jad to /java/s/1.jad to become accessed by shortcut 1 followed by [RIGHT Arrow].
After copying your_midlet.jad to 1.jad (for example), modify the midlet parameter "Midlet-Jar-URL" (inside the .jad file) to become a jar file location.
Complete example:
1. We have midlet /java/jam/Game1/Game1.jar,
2. Copy /java/jam/Game1/Game1.jad to /java/s/1.jad
3. Modify 1.jad content :
Midlet-Jar-URL : file://a:/java/jam/Game1/Game1.jar
4. Access that midlet using this combination : [1][RIGHT Arrow]
5. All midlet should be accessible, just copy or create the good .jad file ...
Good luck,
RizaPN
Old 03-23-2003, 01:21   #47 (permalink)
ValeraVi's Avatar
Member: 24687
Here is a .vkp file of this patch version 2
Old 03-24-2003, 11:16   #48 (permalink)
Member: 22131
*** Assign a shortcut to concrete midlets - version 2 ***
Firmware : SL45v56
Author : Chaos
This is second version of my patch. Before installing, remove the 1st version! The way of assigning shortcuts is the same as in Riza's patch, with an exception that midlets are started by long-press of hot key. Iinit.jar is not needed anymore.
18E3A0: 4E 02 -> A7 08
18E3D4: 4F 02 -> A7 08
18E4A6: 4E 02 -> A7 08
18E4A8: 4E 02 -> A7 08
27ECB0: FF FF FF FF FF FF FF FF -> E6 F1 10 00 88 10 E6 FC
27ECB8: FF FF FF FF FF FF FF FF -> 40 3D E6 FD 11 00 E6 FE
27ECC0: FF FF FF FF FF FF FF FF -> F0 2C E6 FF 1F 03 DA C7
27ECC8: FF FF FF FF FF FF FF FF -> 9E 85 08 02 D7 40 36 00
27ECD0: FF FF FF FF FF FF FF FF -> C2 F1 0A 00 D7 40 11 00
27ECD8: FF FF FF FF FF FF FF FF -> F7 F2 4A 3D E6 FC 40 3D
27ECE0: FF FF FF FF FF FF FF FF -> E6 FD 11 00 E6 FE 01 00
27ECE8: FF FF FF FF -> FA C8 DE 0B
27ECF0: FF FF FF FF FF FF FF FF -> 61 3A 5C 6A 61 76 61 5C
27ECF8: FF FF FF FF FF FF FF FF -> 73 5C 5F 2E 6A 61 64 00
3AE3B3: E6 F8 A9 -> C7 B0 EC
Chaos
Old 03-25-2003, 09:29   #49 (permalink)
Member: 9891
Thanks Meter: 2
Left Arrow for SIM-Location (During Calls Mode)
*** Left Arrow for SIM-Location (During Calls Mode) ***
Firmware : SL45v56
Author : RizaPN
0x3ABDF0 : 48 C6 EA 20 AE BE -> 46 FC 23 00 2D 5C
RizaPN
Old 03-26-2003, 10:11   #50 (permalink)
Member: 9891
Thanks Meter: 2
Right Soft Key for SIM-Location Saving Number
*** 39. Right Soft Key for SIM-Location (Saving Number) ***
Firmware : SL45v56
Author : RizaPN
Release : March 26, 2003
It will permanently change the Right Soft Key function. If you want to save any number to Addressbook, just use <New Entry> function inside the Addressbook (such as : DOWN Arrow key)
0x3AD694 : FE -> FC
0x3AD7F7 : 18 B8 80 EA 00 18 DA -> 14 EA 00 1A DA D7 40
0x3AD7FE : DA D7 90 2F 48 40 2D -> 0C 00 F7 8E 52 1A 0D
0x346F78 : DC 4D D4 FC 98 02 46 FF -> D7 40 0C 00 F7 8F 52 1A
0x346F80 : 1E 00 -> 0D 01
Old 03-26-2003, 13:23   #51 (permalink)
Member: 9891
Thanks Meter: 2
Modify Characters for Filename Input
*** 40. Modify Characters for Filename Input ***
Firmware : SL45v56
Author : RizaPN
It will give a possibility to use '\\' and '/' as a filename
(tested for SMS Archive and Rename). The characters is putted
under button '0' overwriting '¿' and '¡'
0x186110 : BF 00 A1 -> 2F 00 5C
Remark:
- It can be putted under another button, just see the data around that address, and you will get the feeling
Old 03-27-2003, 15:06   #52 (permalink)
Member: 9891
Thanks Meter: 2
Using Midlet for Screen Saver when Keylocked
*** 43. Using midlet for Screen Saver when Keylocked v03 ***
Firmware : SL45v56
Author : RizaPN
Release : March 29, 2003
Using this patch, it is possible to assign one midlet as a "Screen
Saver" midlet which will be executed automatically after some time (Auto Key Locked options must be set).
0x3B02B2 : DA A3 74 40 -> DA C7 70 D4
0x27D470 : FF FF FF FF FF FF FF FF -> E6 FC 60 14 E6 FD 1F 03
0x27D478 : FF FF FF FF FF FF FF FF -> E0 1E DA C8 DE 0B DB 00
If you want to use that midlet also for long pressing of button '#' (usually for keylock), enter this data... If you want to keep your long press of # as a normal keylock function, skip this...
0x3AD2B8 : DA A3 74 40 -> DA C7 70 D4
If you already apply "Midlet Shortcut" patch, you don't need to enter these data...
Midlet format is same with the one used by "Midlet Shortcut" patch, but this patch use only file "a:/java/s/x.jad" (the real x.jad filename, no need to rename it) midlet caller.
RizaPN
Old 03-29-2003, 02:33   #53 (permalink)
Member: 9891
Thanks Meter: 2
Insert Timbre Options for MP3Player
*** 41. Insert "Timbre" Options for MP3Player ***
Firmware : SL45v56
Author : RizaPN
While MP3 Player is running, press button '8' will change the BASS setting, and press '0' will change the PITCH setting.
0x3BA196 : EA 00 C8 A3 -> FA C7 80 D4
0x27D480: FF FF FF FF FF FF FF FF -> 46 F1 30 00 3D 15 DA D0
0x27D488: FF FF FF FF FF FF FF FF -> CE 5C 2D 02 E0 0C 0D 01
0x27D490: FF FF FF FF FF FF FF FF -> E0 1C DA D0 98 5C DA D0
0x27D498: FF FF FF FF FF FF FF FF -> CE 5C 2D 03 E6 FD FE 03
0x27D4A0: FF FF FF FF FF FF FF FF -> 0D 02 E6 FD 83 06 E0 1C
0x27D4A8: FF FF FF FF FF FF FF FF -> DA E6 98 F1 FA DB C8 A3
0x27D4B0: FF FF FF FF FF FF FF FF -> 46 F1 38 00 3D FB DA D0
0x27D4B8: FF FF FF FF FF FF FF FF -> C2 5C 2D 02 E0 0C 0D 01
0x27D4C0: FF FF FF FF FF FF FF FF -> E0 1C DA D0 7A 5C DA D0
0x27D4C8: FF FF FF FF FF FF FF FF -> C2 5C 2D EB E6 FD FD 03
0x27D4D0: FF FF -> 0D EA
RizaPN
Old 04-05-2003, 15:57   #54 (permalink)
Member: 9891
Thanks Meter: 2
Graphical Menu
*** 42. Graphical Menu ***
Firmware : SL45v56
Author : RizaPN
Release : April 5, 2003
It will use Right Arrow key to activate the full graphical Menu. It will overwrite "Right Arrow for Card-Explorer" patch
0x3B0368 : 3C -> 54
0x3B0450 : F0 C4 DA E5 24 3A EA 00 -> EA 00 EE 07 DA C7 C0 D5
0x3B0458 : F4 07 -> 0D 23
0x38E1CE : F0 CE F0 DF -> E6 FD A1 02
0x3BF1D0 : DC 4D C4 EC 04 00 -> E6 FC F2 2A CC 00
0x27D500 : FF FF FF FF FF FF FF FF -> DC 4F D4 4E 02 00 2D 32
0x27D508 : FF FF FF FF FF FF FF FF -> D7 40 34 00 F2 FE 1C 3E
0x27D510 : FF FF FF FF FF FF FF FF -> 26 FE 6F 00 46 F4 20 00
0x27D518 : FF FF FF FF FF FF FF FF -> 3D 02 08 E3 0D 11 46 F4
0x27D520 : FF FF FF FF FF FF FF FF -> 21 00 3D 02 28 E3 0D 0C
0x27D528 : FF FF FF FF FF FF FF FF -> 46 F4 22 00 3D 02 08 E1
0x27D530 : FF FF FF FF FF FF FF FF -> 0D 07 46 F4 23 00 3D 02
0x27D538 : FF FF FF FF FF FF FF FF -> 28 E1 0D 02 48 41 2D 62
0x27D540 : FF FF FF FF FF FF FF FF -> 48 E0 DD 02 E0 BE 0D 04
0x27D548 : FF FF FF FF FF FF FF FF -> 46 FE 0C 00 CD 01 E0 0E
0x27D550 : FF FF FF FF FF FF FF FF -> 48 45 2D 0F 48 43 2D 0D
0x27D558 : FF FF FF FF FF FF FF FF -> 06 FE 6F 00 D7 40 34 00
0x27D560 : FF FF FF FF FF FF FF FF -> F6 FE 1C 3E E0 0C E0 0D
0x27D568 : FF FF FF FF FF FF FF FF -> DA C1 EC 22 E6 F4 FF FF
0x27D570 : FF FF FF FF FF FF FF FF -> DB 00 F0 4E 5C 14 00 E4
0x27D578 : FF FF FF FF FF FF FF FF -> 06 FE DC 14 E0 05 D7 60
0x27D580 : FF FF FF FF FF FF FF FF -> 1F 03 99 8E 99 9E 99 AE
0x27D588 : FF FF FF FF FF FF FF FF -> 2D F1 DA C7 88 EE 0D EE
*) Remark :
0x27D51B ... modify E3 with Ex where x is increment for DOWN Arrow
0x27D525 ... modify E3 with Ex where x is decrement for UP Arrow
0x27D52F ... modify E1 with Ex where x is increment for RIGHT Arrow
0x27D539 ... modify E1 with Ex where x is decrement for LEFT Arrow
0x27D590 : FF FF FF FF FF FF FF FF -> 00 00 00 00 00 D5 C7 00
0x27D598 : FF FF FF FF FF FF FF FF -> 00 00 00 00 52 7C F0 00
0x27D5A0 : FF FF FF FF FF FF FF FF -> 94 29 E1 02 28 16 1F 03
0x27D5A8 : FF FF FF FF FF FF FF FF -> 00 00 00 00 65 00 50 00
0x27D5B0 : FF FF FF FF FF FF FF FF -> 1C 3E 34 00 00 00 00 00
0x27D5B8 : FF FF FF FF -> 00 00 FF 00
0x27D5C0 : FF FF FF FF FF FF FF FF -> E6 F4 6F 00 D7 40 34 00
0x27D5C8 : FF FF FF FF FF FF FF FF -> F6 F4 1C 3E 88 90 88 80
0x27D5D0 : FF FF FF FF FF FF FF FF -> E6 FC 5A F5 E6 FD D8 00
0x27D5D8 : FF FF FF FF FF FF FF FF -> E6 FE 96 F5 F0 FD DA F0
0x27D5E0 : FF FF FF FF FF FF FF FF -> 3C FD F0 84 F0 95 F0 C8
0x27D5E8 : FF FF FF FF FF FF FF FF -> F0 D9 E6 FE 90 15 E6 FF
0x27D5F0 : FF FF FF FF FF FF FF FF -> 1F 03 DA F0 24 FF F0 C8
0x27D5F8 : FF FF FF FF FF FF FF FF -> F0 D9 DA F0 9E 80 98 80
0x27D600 : FF FF FF FF FF FF FF FF -> 98 90 DB 00 E0 04 DB 00
0x27D610 : FF FF FF FF FF FF FF FF -> 03 00 03 00 FF FF 00 00
0x27D618 : FF FF FF FF FF FF FF FF -> 00 00 FF FF 00 00 00 00
0x27D620 : FF FF FF FF FF FF FF FF -> FF FF 05 00 05 00 FF FF
0x27D628 : FF FF FF FF FF FF FF FF -> 10 16 1F 03 01 00 FF FF
0x27D4DC : 3C 40 DB ... Organiser
0x27D4DF : 08 40 DB ... Message
0x27D4E2 : 4C 40 DB ... Surf/Fun
0x27D4E5 : 6C 40 DB ... Audio
0x27D4E8 : 1C 40 DB ... Record
0x27D4EB : 2C 40 DB ... Setup
0x27D4EE : 62 0A D9 ... WriteMessage
0x27D4F1 : B4 E1 D8 ... Java
0x27D4F4 : C4 E1 D8 ... MP3Player
0x27D4F7 : A6 79 DC ... Games
0x27D4FA : 50 EF DB ... Calendar
0x27D4FD : CA E1 D8 ... Card-Explorer
If you want to use the Right Soft Key as a Graphical Menu Key and Right Arrow Key for Normal Menu Access, then enter these data also :
0x3B0368 : 54 -> 3C
0x3B036E : 3C -> 54
If you want to use a normal key habbit, just like in the "Text Menu" mode
(RIGHT for Access, LEFT for exit, UP/DOWN for select), add these data :
0x27D51B : E3 -> E1
0x27D525 : E3 -> E1
0x27D52E : 08 E1 -> 0D 21
0x27D53B : 02 -> 64
*) This patch use firmware image no. 112 until 123. Please modify those images after/before applying this patch. Image is 101x80, could be any image, but one image should be focus on one menu item.
*) Modify the images and the entry-point values as you need (do not ask me about the images sample) ...
Other Entry-Point (Main Menu Items) :
5C 40 DB : Profiles
7C 40 DB : Time/Charge
8C 40 DB : Divert
50 FB EC : Help
Happy Trying ...
RizaPN
Old 04-09-2003, 10:03   #55 (permalink)
Member: 9891
Thanks Meter: 2
*** 50. Use Graphical Menu in the MP3 Player ***
Firmware : SL45v56
Author : RizaPN
Release : April 9, 2003
*) Need "Graphical Menu" patch
*) Need "Doing Something Else while Playing MP3" patch
After applying both patch, please add these data:
0x3BA0FA : DA DB DC 42 -> DA C7 C0 D5
RizaPN
Old 04-10-2003, 04:29   #56 (permalink)
Member: 9891
Thanks Meter: 2
Vibra Toggle
*** 51. #[RightSoft] as Vibra Toggle ***
Firmware : SL45v56
Author : RizaPN
Release : April 10, 2003
Revision : May 05, 2003
0x3B31AC : 7D 03 -> C8 02
0x3B3398 : DA D9 1A 49 -> DA DC 6A 17
If you want to use another fixed shortcut button, select your own patch for that particular button (in the previous patch list), and use DA DC 6A 17 as a Vibra Toggle entry-point.
RizaPN
Old 04-10-2003, 06:35   #57 (permalink)
Member: 9891
Thanks Meter: 2
Profile Swapping
*** 52. 0[RightSoft] for Profile swapping (Normal/Quiet) ***
Firmware : SL45v56
Author : RizaPN
After applying this patch, we can use 0 followed by Right Soft Key to swap between Normal Environment profile and the Quiet Environment ones.
0x3B309E : 48 40 -> E0 14
0x3B30C4 : 7B 03 -> 08 02
0x3B3322 : DA A0 AC 15 -> DA C7 52 D6
0x3B3326 : 48 40 -> E0 04
0x27D652 : FF FF FF FF FF FF -> DA A4 66 98 2D 02
0x27D658 : FF FF FF FF FF FF FF FF -> E0 0C 0D 02 E6 FC 01 01
0x27D660 : FF FF FF FF FF FF FF FF -> D7 40 0D 00 F6 FC 88 24
0x27D668 : FF FF FF FF FF FF FF FF -> DA A4 4A 98 DA A4 66 98
0x27D670 : FF FF FF FF FF FF FF FF -> 5C 14 C0 8D 06 FD D5 03
0x27D678 : FF FF FF FF FF FF FF FF -> E0 1C DA E6 98 F1 DB 00
If you want to use another fixed shortcut button, select your own patch for that particular button (in the previous patch list), and use DA C7 52 D6 as a Profile Swap entry-point (you must enter 0x27---- part of this patch only, not the 0x3B---- part).
RizaPN
Old 04-10-2003, 07:31   #58 (permalink)
Member: 9891
Thanks Meter: 2
Vibra Indicator
*** 53. Modify MultiLine Indicator to become Vibra Indicator ***
Firmware : SL45v56
Author : RizaPN
This patch will provide an ability to display firmware image no. 339 in the top screen if the Vibra is active. Please modify the image (original image is like up-arrow) as you like.
0x3B3708 : DA A0 AC 15 48 40 2D 08 -> D7 40 0D 00 C2 FD 89 24
0x3B3710 : DA A0 CA 15 F0 C4 DA CB -> 5C 1D D7 40 0D 00 D4 ED
0x3B3718 : 38 CA 48 40 2D 0D 0D 05 -> 9A 24 66 FE 10 00 0D 04
RizaPN
Old 04-12-2003, 12:45   #59 (permalink)
vikado77's Avatar
Member: 13636
press of left side [+] button for "Profile-menu“
Firmware: SL45 v56
Author: vikado77
0x3B04A4 : DA A2 18 4C 48 40 EA 20 -> DC 59 98 C8 A8 D8 DC 4D
0x3B04AC : F6 07 DC 59 -> D4 8C 04 00
0x3B04B0 : 98 C8 A8 D8 DC 4D -> 46 F8 EB 00 2D 03
0x3B04B6 : D4 8C 04 00 -> DA DB 5C 40
0x3B04BA : 46 F8 EB 00 EA 30 F6 07 -> 0D 07 E0 1C E6 FD 82 00
0x3B04C2 : E0 1C DA F0 -> DA E6 98 F1
0x3B04C6 : 50 83 EA 00 -> DA DB 5C 40
0x3B04CA : D6 07 -> 0D 0B
vikado
Old 04-12-2003, 18:57   #60 (permalink)
ValeraVi's Avatar
Member: 24687
[GLOW=orange];Set[*][RightSoft] for Profile swapping (Normal/Quiet)[/GLOW]
;Firmware : SL45v56
;Author : ValeraVi
;Release : April 14, 2003
; This patch replaces behavior of[*][RightSoft] conbination from
;open Profiles-menu to the Profile swapping (Normal/Quiet) if you apply
;patch Profile swapping (Normal/Quiet) from RizaPN.
; If you want to go to the Profiles-menu, you can do this with help of
;the Main Menu.
; After applying this patch, you can use * followed by Right Soft
;Key to swap between Normal Environment profile and the Quiet
;Environment profiles.
3B3134: 0B02 0B02 ;Text label code for[*][RightSoft]
3B339E: DADF4A4D DAC752D6 ;Entry-point place for[*][RightSoft]
3B33A2: F0C4DAE5243A CC00CC00CC00
; Before applying this patch you must apply the patch from RizaPN
;*** 52. 0[RightSoft] for Profile swapping (Normal/Quiet) ***
;without the 0x3B---- part. Apply only 0x27---- part of that patch.
; I.e. you must apply only this block:
27D652: FFFFFFFFFFFF DAA466982D02
27D658: FFFFFFFFFFFFFFFF E00C0D02E6FC0101
27D660: FFFFFFFFFFFFFFFF D7400D00F6FC8824
27D668: FFFFFFFFFFFFFFFF DAA44A98DAA46698
27D670: FFFFFFFFFFFFFFFF 5C14C08D06FDD503
27D678: FFFFFFFFFFFFFFFF E01CDAE698F1DB00
; If you want to use[*][RightSoft] for other function do not apply
;that block (27D6xx) and specify the entry-point of other function in
;the entry-point place (3B339E) and text label code of other function in
;the text code place (3B3134).
;_______________________
;ValeraVi
the [GLOW=tomato].vkp[/GLOW] file you can download here: http://www.is.svitonline.com/valerav...5i/Patches.htm
SLIKv56: Flash Patching (3rd part) ... rizapn x4x, x5x Flashpatching 2900 12-24-2007 10:51
TOC for Sticky: SLIKv56: Flash patches. StevieRay x4x, x5x Flashpatching 17 10-15-2005 08:26
"Bugs" in Thread SLIKv56: Flash patches trustkill Siemens-Benq Flash Patching 2 07-13-2004 07:33
M55 Flash Patch -Anyone´s got full modded flashes ready for flash--?? Uvedovle x4x, x5x Flashpatching 0 04-27-2004 10:32
Where can i download riza's SLIKv56: Flash Patching (3rd part) Gabriel_he Siemens-Benq Flash Patching 2 04-04-2003 03:20
Page generated in 0.33563 seconds with 11 queries
