Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 02-06-2003, 09:27   #16 (permalink)
Member: 20543
Thanks Meter: 2
Overwrite selectable "User Group" shortcut/hotkey with "Archive"
Firmware: SL45 v56
Author: RizaPN
0x18E388 : 8B 00 -> DE 03
0x18E3BC : 8C 00 -> DE 03
0x18E4B8 : 8B 00 8B 00 -> DE 03 DE 03
0x3AE311 : D7 02 45 -> D9 02 0B
Old 02-12-2003, 23:53   #17 (permalink)
Member: 9891
Thanks Meter: 2
ADDITIONAL FIX SHORTCUT PATCHING SUMMARY
Firmware : SL45 v56
Author : RizaPN
Let me, one again, wrote the updated fix shortcut patching here :
1) Use LEFT Arrow key as a "SIM-Location" shortcut :
0x3B03B0 : EA 20 0A 05 46 FC 14 00 -> 8D 04 46 FC 15 00 EA F0
0x3B03B8 : EA 20 0A 05 46 FC 15 00 -> 0A 05 46 FC 23 00 2D 5D
0x3B0474 : E0 0C E0 0D -> DA DB 3C EF
0x3B0478 : E0 0E -> 0D 02
0x3B047A : DA D4 AC 70 -> DA DB 46 EF ... (see table)
2) Use RIGHT Arrow key as a "Card-Explorer" shortcut :
0x3B0368 : 3C -> 54
0x3B0450 : F0 C4 DA E5 -> EA 00 EE 07
0x3B0454 : 24 3A EA 00 -> DA D8 CA E1 ... (see table)
0x3B0458 : F4 07 -> 0D 23
3) Modify 0[UpperRight] from "Select Line" to "Archive" :
0x3B309E : 48 40 -> E0 14
0x3B30C4 : 7B 03 -> DE 03 ... ***
0x3B3322 : DA A0 AC 15 -> DA D9 02 0B ... (see table)
0x3B3326 : 48 40 -> E0 04
4) Modify #[UpperRight] from "View New CB" to "Java"
0x3B31AC : 7D 03 -> B0 0D ... ***
0x3B3398 : DA D9 1A 49 -> DA D8 B4 E1 ... (see table)
5) Use * 0 and # followed by [GREEN] as another shortcut :
(*: Inbox, 0: Write SMS, #: Outbox)
0x3AD7A4 : E6 FC 0A 00 E6 FD 36 00 -> E6 00 36 00 F3 FC 0A 00
0x3AD7B2 : 2D 19 -> 2D 12
0x3B3000 : F0 ED 70 EC 2D 0B DC 4D -> E0 14 27 FC 23 00 3D 03
0x3B3008 : A9 2C 47 F2 -> DA D9 F8 0A ... # button, (see table)
0x3B300C : 30 00 2D 06 47 F2 -> 0D 09 29 C7 3D 03
0x3B3012 : 2A 00 2D 03 -> DA D9 EE 0A ... * button, (see table)
0x3B3016 : 47 F2 23 00 3D 02 -> 0D 04 29 C6 3D 03
0x3B301C : E0 04 DB 00 -> DA D9 62 0A ... 0 button, (see table)
0x3B3020 : E0 14 -> E0 04
Those patches use almost all unused fix key as a shortcut.
If you see "(see table)", it means you can modify their values with values shown in this table (Entry-Point), based on the function you like to assign to that particular fix shortcut. If you see also "***" before that remark, it means you also need to modify the text index with the new value (Text) :
Entry-Point : Text : Functions
DA D8 B4 E1 : B0 0D : Java
DA D8 B8 E1 : 53 03 : Internet
DA D8 C4 E1 : B8 01 : MP3Player
DA D8 CA E1 : 81 05 : Card-Explorer
DA D8 CE E1 : B0 0D : Chronometer
DA D8 D6 E1 : D7 02 : Currency
DA D8 DA E1 : 59 02 : Games
DA DB 3C EF : 16 00 : Addressbook
DA DB 46 EF : 33 02 : SIM-Location
DA DB 50 EF : 58 01 : Calendar
DA DB 5C EF : 9D 02 : Appointments
DA DB 68 EF : B7 00 : Dictaphone
DA DB 6C EF : 56 00 : Answer-Message
DA DB 70 EF : D2 02 : BussinessCard
DA DB 7C EF : 8A 02 : Calculator
DA DB 80 EF : 80 03 : VoiceControl
DA DB 80 F2 : E7 00 : Call-Missed
DA DB 84 F2 : 44 00 : Call-Received
DA DB 88 F2 : 22 01 : Call-Dialed
DA DB 8C F2 : E8 00 : Alarm-Missed
DA DC 16 06 : 9C 01 : Compose-Melody
DA DC 04 79 : BE 04 : Game-SuperMind
DA DC 10 79 : C0 04 : Game-MoveTheBox
DA DC 14 79 : 87 05 : Game-Wacko
DA DC 08 79 : C2 04 : Game-HomeRun
DA DC FC 78 : 99 04 : Game-Reversi
DA DC 00 79 : 9B 04 : Game-Quattropoli
DA DC 0C 79 : C4 04 : Game-TheMaze
DA D9 62 0A : 3C 02 : Write-Message
DA D9 EE 0A : D3 00 : Incoming-Message
DA D9 F8 0A : 69 00 : Outgoing-Message
DA D9 02 0B : DE 03 : Archive
DA DC 12 42 : 6C 04 : Contrast
DA D5 5A F2 : 5B 02 : Language
DA D5 6A F2 : 5F 00 : Display
DA D5 82 F2 : 7E 02 : T9-Input
EXAMPLE :
See patch no.3 ...
If you want to assign "Game-SuperMind" instead of "Archive" into your 0[UpperRight] keys, then you just need to use :
0x3B30C4 : 7B 03 -> BE 04 (Game-Supermind text)
0x3B3322 : DA A0 AC 15 -> DA DC 04 79 (Supermind entry-point)
instead of the original patch values.
Old 02-12-2003, 23:55   #18 (permalink)
Member: 9891
Thanks Meter: 2
*) Short # to unlock keypad, UP arrow and PTT button for VoiceDial when keypad is locked :
Firmware : SL45 v56
Author : RizaPN
0x3B0384 : CE -> D8
0x3B038C : CE -> D8
0x3B0394 : CE -> D8
0x3B04CA : D6 -> D8 ... (don't modify if it was 0D)
0x3B07BD : 4F D4 8E -> 7F 98 8E
0x3B07C0 : 02 00 46 F8 1E 00 2D 03 -> 98 8E 98 CE 98 DE 46 F8
0x3B07C8 : 46 F8 1F 00 3D 07 -> 14 00 2D 09 46 F8
0x3B07CE : DA A2 -> 21 00 ... (see remark1)
0x3B07D0 : 18 4C 48 40 2D 10 DA E6 -> 2D 03 46 F8 1E 00 3D 07
0x3B07D8 : 82 AB 0D 0C DC 5F D4 CE -> DA E6 82 AB 0D 0C DA DA
0x3B07E0 : 04 00 D4 DE 06 00 -> EC F6 0D 09 CC 00
remark1:
If you don't like to use UP Arrow to activate VoiceDial when keypad is locked, then use this :
0x3B07CE : DA A2 -> 14 00
Old 02-12-2003, 23:56   #19 (permalink)
Member: 9891
Thanks Meter: 2
ADD NEW OPTION MENU FOR SL45 FW56 - > BAND SELECTION
Firmware : SL45 v56
Author : Wind
0018D6BA: 04 02 -> F9 01
Menu->Setup->Network->Setup->Band selection
) Automatic
) GSM 900
) GSM 1800
Old 02-12-2003, 23:57   #20 (permalink)
Member: 9891
Thanks Meter: 2
*** Short UP arrow to unlock keypad, and PTT button for VoiceDial when keypad is locked :
Firmware : SL45 v56
Author : Yurgen1
0x3B07C4 : 1E -> 21 ... UP arrow unlock keypad
0x3B07C7 : 03 -> 04
0x3B07CA : 1F -> 1E ... PTT button for VoiceDial
0x3B07CE : DA A2 18 4C 48 40 2D 10 -> 0D 03 DA DA EC F6 0D 0F
Old 02-12-2003, 23:59   #21 (permalink)
Member: 9891
Thanks Meter: 2
Turn off Aeroplane Check :
Firmware : SL45 v56
Author : RizaPN
0x4522F2 : 3D -> 0D
Old 02-13-2003, 00:01   #22 (permalink)
Member: 9891
Thanks Meter: 2
*** Toggling between SIM-Location and Addressbook when entering SMS Recipient No. ***
Firmware : SL45 v56
Author : RizaPN
0x341EAB : 09 -> 11
0x341EBC : 0D 0F F0 C8 -> E6 FC FF FF
0x341EC0 : F0 D9 E0 8E DA D4 FC 33 -> D7 40 34 00 54 FC 1C 3E
0x341EC8 : 48 40 EA 20 -> CD 09 0D 01
Remark:
It is rather dirty patch. SIM Location and Addressbook data will be toggled if there is data inside the Addressbook. For example : first time, pressing Left soft key will enter to Addressbook, then 2nd time (press RED then press Left soft key again), it will enter to SIM Location, ...
It also happened if we select "Insert From" option ...
Old 02-16-2003, 07:32   #23 (permalink)
Member: 9891
Thanks Meter: 2
Assign Any Melody to Any Phone Number
*** Assign Any Ringtone to Any Phone Number ***
Firmware : SL45 v56
Author : RizaPN
*) This is very long patch, please be very carefull
*) This patch will use VIP group setting for distinguishing each number's ringtone. Set VIP melody to the 1st discreet (Menu - Audio - Melodies - VIP - Discreet - 1 - OK), otherwise it will not be used.
*) Each name should be ended by 1 additional character which is related directly to the ringtone ID. Usually, SL is using "!" char for VIP group. It will be listed as a VIP in the Phonebook or Addressbook. See the list ...
0x3EC1F2 : DA F1 90 9E -> DA C7 80 D0
0x3EFDAC : DA F1 90 9E -> DA C7 80 D0
0x27D080 : FF FF FF FF FF FF FF FF -> DA F1 90 9E 88 60 E6 F6
0x27D088 : FF FF FF FF FF FF FF FF -> B0 10 D7 40 1F 03 99 96
0x27D090 : FF FF FF FF FF FF FF FF -> 2D 0B 41 98 3D FA 26 F6
0x27D098 : FF FF FF FF FF FF FF FF -> B1 10 D7 40 34 00 F6 F6
0x27D0A0 : FF FF FF FF FF FF FF FF -> 1A 3E E6 F4 21 00 0D 01
0x27D0A8 : FF FF FF FF FF FF FF FF -> E0 04 98 60 DB 00 CC 00
0x27D0B0 : FF FF FF FF FF FF FF FF -> 23 40 5C 26 A7 2E 2C 3F
0x27D0B8 : FF FF FF FF FF FF FF FF -> 21 2B 2D 3A 22 27 3B 2A
0x27D0C0 : FF FF FF FF FF FF FF FF -> 2F 28 29 3C 3D 3E 25 20
0x27D0C8 : FF FF FF FF FF FF FF FF -> A3 24 A5 C9 E9 E8 F6 F1
0x27D0D0 : FF FF FF FF FF FF FF FF -> F2 C6 D8 C5 E6 F8 E5 DC
0x27D0D8 : FF FF FF FF FF FF FF FF -> FC F9 C4 E4 E0 00 00 00
0x4646F2 : E1 12 F0 6D -> DA C7 F0 D0
0x27D0F0 : FF FF FF FF FF FF FF FF -> E1 12 F0 6D 46 F6 1B 00
0x27D0F8 : FF FF FF FF FF FF FF FF -> 3D 04 D7 40 34 00 F2 F6
0x27D100 : FF FF FF FF -> 1A 3E DB 00
Melody and Characters Group :
Standard (1-5) : # @ \ & (key #)
Classical (1-18) : . , ? ! + - : " ' ; (key 0) * / ( ) < = > % (key *)
Traditional (1-4) : space $ (key 1)
Discreet (1-6) : (key 3) (key 6)
Pop music (1-6) : (key 9)
If you want to modify them, just modify the values started from address 0x27D0B0 ...
RizaPN
Old 02-17-2003, 14:37   #24 (permalink)
Member: 9891
Thanks Meter: 2
Slow and Dirty Animated Screen Saver
Firmware : SL45 v56
Author : RizaPN
*** Use Screen Style Images as a Screen Saver when Keypad is Locked ***
0x3B37F6 : E6 F9 55 01 F0 C8 5C 1C -> E6 F8 3C 4E DA C7 20 D1
0x3B37FE : 00 C0 B8 9C -> EA 00 50 3A
0x27D120 : FF FF FF FF FF FF FF FF -> D7 40 34 00 F2 FC 1C 3E
0x27D128 : FF FF FF FF FF FF FF FF -> 08 C1 46 FC 0A 00 8D 01
0x27D130 : FF FF FF FF FF FF FF FF -> E0 0C D7 40 34 00 F6 FC
0x27D138 : FF FF FF FF FF FF FF FF -> 1C 3E 00 8C E0 0C DB 00
RizaPN
Jakarta - Indonesia
Old 02-19-2003, 07:18   #25 (permalink)
Member: 9891
Thanks Meter: 2
Keypad lock and unlock patch
*** Use only long press of # to unlock keypad ***
Firmware : SL45 v56
Author : RizaPN
If you already apply short # unlock patch, please reset them back to the original values.
0x3AF6F4 : DA D6 6C 2C -> DA DA E2 F6
0x3B06E0 : DC 45 -> 0D 06
*** Eliminate "Keylocked" message box when locking the keypad ***
Firmware : SL45 v56
Author : RizaPN
0x3AD2B4 : DA DB -> 0D 01
RizaPN
Old 02-23-2003, 13:06   #26 (permalink)
Member: 9891
Thanks Meter: 2
Slow Animated Operator Logo
*** SLOW Animated Operator Logo when Keypad is locked ***
Firmware : SL45 v56
Author : RizaPN
*** It will overwrite Screen Saver Patch ***
0x3B37F6 : DA E5 02 4B -> DA C7 20 D1
0x27D120 : FF FF FF FF FF FF FF FF -> D7 40 34 00 F2 FE 1C 3E
0x27D128 : FF FF FF FF FF FF FF FF -> 08 E1 46 FE 0A 00 8D 01
0x27D130 : FF FF FF FF FF FF FF FF -> E0 0E D7 40 34 00 F6 FE
0x27D138 : FF FF FF FF FF FF FF FF -> 1C 3E 06 FE 87 02 E0 0C
0x27D140 : FF FF FF FF FF FF FF FF -> E0 8D DA C1 EC 22 E6 F9
0x27D148 : FF FF FF FF -> 55 01 DB 00
0x4BB8EF : 50 -> 2F
0x4BB8F7 : 50 -> 2F
0x4BB8FF : 50 -> 2F
0x4BB907 : 50 -> 2F
0x4BB90F : 50 -> 2F
0x4BB917 : 50 -> 2F
0x4BB91F : 50 -> 2F
0x4BB927 : 50 -> 2F
0x4BB92F : 50 -> 2F
0x4BB937 : 50 -> 2F
Remark:
- After applying that patch, you must use ffmod or any other PictureChanger to modify firmware image no. 648 until 657. This patch use those images sequence.
RizaPN
Jakarta, Indonesia
Old 02-24-2003, 00:06   #27 (permalink)
Member: 9891
Thanks Meter: 2
*** Unhide Calendar Menu while Call in progress ***
Firmware : SL45v56
Author : RizaPN
Entering from Call Menu - Main Menu - Organiser ...
0x1A0814 : 1E - 1C
RizaPN
Old 02-25-2003, 04:23   #28 (permalink)
Member: 9891
Thanks Meter: 2
*** SLOW Animated Operator Logo v04 ***
Firmware : SL45v56
Author : RizaPN
Reset any old operator logo patch before applying this patch version
Corrected Bugs (from previous version) :
- Incoming Call display problem,
- Voice Dial display problem,
0x3AC464 : F2 F6 76 3F -> DA C7 84 D1
0x3B0362 : 46 FC 22 00 -> DA C7 70 D1
0x3B0E54 : DA F0 A2 D5 -> DA C7 60 D1
0x3B36C0 : DA E5 02 4B -> DA C7 20 D1
0x27D120 : FF FF FF FF FF FF FF FF -> D7 40 34 00 F3 F8 1B 3E
0x27D128 : FF FF FF FF FF FF FF FF -> 49 80 2D 13 D7 40 34 00
0x27D130 : FF FF FF FF FF FF FF FF -> F2 FE 1C 3E 08 E1 46 FE
0x27D138 : FF FF FF FF FF FF FF FF -> 0A 00 8D 01 E0 0E D7 40
0x27D140 : FF FF FF FF FF FF FF FF -> 34 00 F6 FE 1C 3E 06 FE
0x27D148 : FF FF FF FF FF FF FF FF -> 87 02 E0 0C E0 8D DA C1
0x27D150 : FF FF FF FF FF FF FF FF -> EC 22 DA E5 02 4B DB 00
0x27D160 : FF FF FF FF FF FF FF FF -> DA F0 A2 D5 E0 16 D7 40
0x27D168 : FF FF FF FF FF FF FF FF -> 34 00 F7 FC 1B 3E DB 00
0x27D170 : FF FF FF FF FF FF FF FF -> 48 C1 FD 05 E0 04 D7 40
0x27D178 : FF FF FF FF FF FF FF FF -> 34 00 F7 F8 1B 3E 46 FC
0x27D180 : FF FF FF FF -> 22 00 DB 00
0x27D184 : FF FF FF FF FF FF -> F2 F6 76 3F 0D F5
0x4BB8EF : 50 -> 2F
0x4BB8F7 : 50 -> 2F
0x4BB8FF : 50 -> 2F
0x4BB907 : 50 -> 2F
0x4BB90F : 50 -> 2F
0x4BB917 : 50 -> 2F
0x4BB91F : 50 -> 2F
0x4BB927 : 50 -> 2F
0x4BB92F : 50 -> 2F
0x4BB937 : 50 -> 2F
RizaPN
Old 02-25-2003, 14:38   #29 (permalink)
vikado77's Avatar
Member: 13636
*** unlock mp3-auto-play with dobbleclick on the Play-button, when keypad is locked :
Firmware : SL45 v56
Author : Vikado77
0x3B07C4 : 1E -> 62
0x3B07C7 : 03 -> 04
0x3B07CA : 1F -> 1E
0x3B07CE : DA A2 18 4C 48 40 2D 10 -> 0D 03 DA DA E2 F6 0D 0F
edit:
This patch contains:
--> see the last 2 lines
(without that it is not working!)
Old 02-27-2003, 06:18   #30 (permalink)
Member: 9891
Thanks Meter: 2
*** Unhide "Send Via IrDA" Options for JAR file ***
Firmware : SL45v56
Author : RizaPN
There was old patch for adding "Send Via IrDA". Please reset them. This is better patch than the previous ones ...
0x388624 : F0 C8 -> 0D 11
SLIKv56: Flash Patching (3rd part) ... rizapn x4x, x5x Flashpatching 2900 12-24-2007 09:51
TOC for Sticky: SLIKv56: Flash patches. StevieRay x4x, x5x Flashpatching 17 10-15-2005 08:26
"Bugs" in Thread SLIKv56: Flash patches trustkill Siemens-Benq Flash Patching 2 07-13-2004 07:33
M55 Flash Patch -Anyones got full modded flashes ready for flash--?? Uvedovle x4x, x5x Flashpatching 0 04-27-2004 10:32
Where can i download riza's SLIKv56: Flash Patching (3rd part) Gabriel_he Siemens-Benq Flash Patching 2 04-04-2003 02:20
Page generated in 0.57573 seconds with 9 queries
