05-12-2005, 20:46 | #2626 (permalink) |
Insane Poster Join Date: Nov 2004 Location: Poznan, Poland Age: 37
Member: 94448 Status: Offline Thanks Meter: 0 | Code: write_file: mov r13, #p(file_name) ;r13:r12 = pointer to ASCIIZ filename mov r12, #q(file_name) calls fileOpen ;r4 = Open result, if success r4=fileHandle, if failed, r4=FFFF cmp r4, #0ffffh jmpr cc_Z, return push r4 mov r12, r4 ;r12=fileHandle mov r15, #filesize ;r15=size mov r14, #p(game_start) ;r14:r13 = pointer to buffer mov r13, #q(game_start) calls fileWrite pop r12 ;r12=fileHandle calls fileClose return: rets |
05-13-2005, 01:10 | #2627 (permalink) |
No Life Poster Join Date: Mar 2002 Location: -[r0]- Age: 53
Member: 9891 Status: Offline Thanks Meter: 2 | @cyperghost: - what do you mean with graphical separator? Something like line separator in the SL menu? @sc0ty: - please read the discussion in the Technical topics. All file functions is not call-able directly. Need some unknown initial procedures. And the trick is using FAM patch ... for FAM usage example, download from my z-soft site ... |
05-13-2005, 02:48 | #2628 (permalink) |
No Life Poster Join Date: May 2004
Member: 66040 Status: Offline Thanks Meter: 14 | @Master Riza: Do you know what the RAM loc 0C830C to 0C830E points to? Ive noticed that 0C830E is always 0Ch if it is normal sms and different if from network provider. The other 2 loc i dont know. Is there a sms RAM loc for knowing the CI of the sms sender? |
05-13-2005, 09:12 | #2629 (permalink) |
No Life Poster Join Date: Oct 2003
Member: 42457 Status: Offline Thanks Meter: 1 | @riza Yes as you descriped... Shutdown Phone Restart Phone --------------------- Set mute Set beep --------------------- Set Profile 1 Set Profile 2 . . Should be possible imho. We just need a textstring with "------" and a "patch" that calls only "return" command? I never tried therefore I asked you ___________ EDIT: Okay I tried and it works, just searched for ANY db00 (Return command) I tried 128.c7d078 and 129.c7d078 and it results the ----help---- string, if we select the entry nothing happens ___________ EDIT2: This method lacks in byte saving because we can write only 11 commands for each FAV entry and every seperator needs one command Better would be a shortcut like @2d6.d8e1d6, results --------------- Currency converter . . That the reason I asked the question And it would be possible to overjump the sperator? Shutdown phone <--- Now selected ---------------- Currency Converter press 1 time arrow down Shutdown phone ---------------- Currency Converter <--- Now selected I know it's just cosmetic Last edited by cyperghost; 05-13-2005 at 09:32. |
05-14-2005, 18:09 | #2631 (permalink) |
Member: 42457 Status: Offline Thanks Meter: 1 | @charlie Your latest patch is cool Thank you But it would be better to use the "Main Screen Patches" as entrypoint. If you use the entrypoint DeadmanS provided then number is overwritten by SOL patches Does anybody know how to toggle profiles and ringer settings (Mute Beep Normal) via entrypoint. Would be perfect for latest FAV patch |
05-16-2005, 01:29 | #2632 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | @sc0ty: - download file rizapn_asm.zip (little old archive but containing some usefull asm files) from http://groups.yahoo.com/group/z-soft...ens/0.Patches/ - extract sl45c.asm, check at least "ICD" patch, and you will get the code. - you can also read DeadMan's lrt.asm. rizapn |
05-16-2005, 02:30 | #2633 (permalink) |
Member: 66040 Status: Offline Thanks Meter: 14 | @Cyper: But it would be better to use the "Main Screen Patches" as entrypoint. If you use the entrypoint DeadmanS provided then number is overwritten by SOL patches Try this EP for MSP: 0x27D700: FFFFFFFF CC00CC00 ; free for further usage |
05-16-2005, 13:34 | #2635 (permalink) |
Member: 94448 Status: Offline Thanks Meter: 0 | thx master riza, but can you tell me, whot is this data: Code: cdr_append: mov r14, #010Ah mov r13, #pag(cdr_filename) mov r12, #pof(cdr_filename) mov r15, #0100h calls fileOpen mov r12, r4 add r4, #1 jmpr cc_Z, cdr_rets mov [-r0], r12 mov r13, #pof(cdr_string) mov r14, #pag(cdr_string) extp r14, #1 movb rl4, [r13+] movbz r15, rl4 calls fileWrite mov r12, [r0+] jmps fileClose |
05-18-2005, 05:40 | #2638 (permalink) |
Member: 66040 Status: Offline Thanks Meter: 14 | @sc0ty: Can you please tell me also how to make a patch to read a txt file in the MMC? I cant understand you discussion with Master Riza because its too "technical" for me Ive been looking into Master's ICD patch but cant understand it. Thanks |
05-18-2005, 14:42 | #2639 (permalink) |
Member: 94448 Status: Offline Thanks Meter: 0 | @charlie: Maybe this simple example give you some info: Code: mov r14, #0100h mov r13, #pag(filename) mov r12, #pof(filename) mov r15, #0100h calls fileOpen push r4 mov r12, r4 mov r13, #pof(buf) mov r14, #pag(buf) mov r15, #80 ;file size calls fileRead pop r12 calls fileClose rets |
05-19-2005, 01:16 | #2640 (permalink) |
Member: 66040 Status: Offline Thanks Meter: 14 | @sc0ty: To read file using fileOpen proc. you dont need #pag and #pof of a file, but you need #pag and #pof of file name in asciiz how do i get the #pag and #pof of file name in asciiz if i have this from assembler? 61 3A 5C 66 69 6C 65 2E 74 78 74 00 : db 'a:\file.txt',0 ; 12.00.0 Last edited by charlielao; 05-19-2005 at 03:07. |
SLIKv56: Flash patches. | arman68 | x4x, x5x Flashpatching | 685 | 10-02-2011 10:56 |
TOC for Sticky: SLIKv56: Flash patches. | StevieRay | x4x, x5x Flashpatching | 17 | 10-15-2005 08:26 |
"Bugs" in Thread SLIKv56: Flash patches | trustkill | Siemens-Benq Flash Patching | 2 | 07-13-2004 07:33 |
SLIK v56: Flash Patching (2nd part) ... | rizapn | x4x, x5x Flashpatching | 329 | 09-07-2003 10:28 |
Where can i download riza's SLIKv56: Flash Patching (3rd part) | Gabriel_he | Siemens-Benq Flash Patching | 2 | 04-04-2003 03:20 |
