07-09-2004, 16:02 | #1516 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Italy Age: 49
Member: 50673 Status: Offline Thanks Meter: 2 | Well, version 1 was made by Master Riza just for SLIK, than he "adapted" his patch for SME45i too. This is SLIK version 1. ;*** HBP. Hourly Beep *** ;Firmware : SL45v56 ;Author : RizaPN ;Release : November 4, 2003 ;Modified : November 8, 2003 ;It will produce hourly alarm at every hh:00 0x3B36BC: 26F00C00 DAC740DC 0x27DC40: FFFFFFFFFFFFFFFF D7400E00F3F8423A 0x27DC48: FFFFFFFFFFFFFFFF D7400D00F2F2DC25 0x27DC50: FFFFFFFFFFFFFFFF 9AF4126048203D0B 0x27DC58: FFFFFFFFFFFFFFFF D7401100F3F84038 0x27DC60: FFFFFFFFFFFFFFFF 49813D0AE01CDAC3 0x27DC68: FFFFFFFFFFFFFFFF B600E0040D01E014 0x27DC70: FFFFFFFFFFFFFFFF D7401100F7F84038 0x27DC78: FFFFFFFFFFFFFFFF 26F00C00DB00FFFF ;Alarm could be turn ON/OFF through the Setup->Application menu. ;Alarm type could be modified from the value of address 0x27DC65 ;Use this : ;0x27DC65: FF 1C (tut-tut-tut) ;0x27DC65: FF 2C (high-tiit) ;0x27DC65: FF 3C (battery-empty) ;if you want, just try some other values ... If you want I can make a v.2, but I've to relocate because there is no space to enlarge there. (at 0x27DC80 start ICF patch, and also before 0x27DC40 I think space is busy). Do you want me to make it or is enough v1? |
07-09-2004, 17:46 | #1517 (permalink) | |
Freak Poster Join Date: Jun 2003
Member: 30834 Status: Offline Thanks Meter: 0 | @lalo.lerry I know about it Riza's v.1 (I use it) but in your version we can get some nice futures: Quote:
Best regards MacKam | |
07-09-2004, 19:10 | #1518 (permalink) |
No Life Poster Join Date: Mar 2004
Member: 60520 Status: Offline Thanks Meter: 0 | @lalo.lerry: The v2 of hourly beep with features 3 and 4 would be nice. If you need free space, try either 27D9B0 (up to 27DA60, that overwrites Password SMS from RizaPN wich no one really uses) or start from 40CE40, since 27-Block is nearly full and reserved for Master Riza. |
07-09-2004, 19:22 | #1519 (permalink) |
Major Poster Join Date: Apr 2003 Location: Poland Age: 44
Member: 26593 Status: Offline Thanks Meter: 0 | @lalo.lerry if you could make the HBP beep as many times as the time is for example when it is 4 o'clock it would beep four times @rizapn could you make your patch BLR. Blinking Light when Ringing work when the backlight is off and maybe it is time to make another application menu Last edited by totopol; 07-09-2004 at 21:46. |
07-10-2004, 11:52 | #1521 (permalink) |
Member: 30834 Status: Offline Thanks Meter: 0 | @rizapn Riza I don't know how to thx. You! If I'll go to Indonesia we go on beer @rc-flitzer Is it possible to change this: http://mackam.fm.interia.pl/tmp/rizas_clock.GIF to: http://mackam.fm.interia.pl/tmp/rizas_clock_center.GIF I used Your center patch but it no work |
07-10-2004, 12:13 | #1522 (permalink) |
Freak Poster Join Date: Jun 2004 Location: Romania Age: 43
Member: 67838 Status: Offline Thanks Meter: 0 | Hi all, is there any possibility to swap the positions of date and temperature (I have show temp instead of clock & show clock in right softkey patch installed)? (thought me smart, tried using the *** Remove, center etc. Date & Clock *** patch by rc-flitzer with clock set to left and date to right, but it doesn't work ) I would like to have the date on the right above the softkey clock and the temp on the left. Thanks, Andrei |
07-10-2004, 12:36 | #1524 (permalink) | |
No Life Poster Join Date: May 2003 Location: GERMANY Age: 49
Member: 27745 Status: Offline Thanks Meter: 0 | Quote:
0x3B00AA: E6FE1DE0 E6FE1CE0 ; move clock to "left" position 0x3B0110: E6FE1CE0 E6FE1DE0 On my mobile this works fine ! | |
07-10-2004, 15:59 | #1525 (permalink) |
Member: 67838 Status: Offline Thanks Meter: 0 | trustkill, thanks for the reply on mine doesn't appear to work. the date moves indeed to the right, but the temperature is not displayed anymore (left side is blank). this is exactly what I've tried before, with the same results. I'll fiddle around with the patches for a while, maybe there are some incompatibilities. Andrei |
07-10-2004, 17:11 | #1526 (permalink) |
Member: 60520 Status: Offline Thanks Meter: 0 | @adancau: Did you tried out the date/time swapping without temperature patch? Maybe there's some I produced two months ago... @KTL: Maybe lalo.lerry could do this. The adaption is easy, but needs to find the right entrypoints. @lalo.lerry: If you need source code and EP's from temperature patch, let me know. @MacKam: I think the first one looks better. It is possible to get both strings in the center (as only one string), but I don't know how I can get this f*** alarm clock there, too. (I removed it in my phone). Maybe lalo.lerry or riza know more about these string routines. Where did you get the nice font (for "SMS" softkey e.g.)? |
07-10-2004, 17:56 | #1527 (permalink) |
Crazy Poster Join Date: Oct 2003 Location: Poland, Osno Age: 39
Member: 41290 Status: Offline Thanks Meter: 0 | The best would be if temperatur will be moved on other place on idle screen (maybe near profil logo by acid) and clock will loked like it looks normal, I think that must be difficult if it isn`t done yet but if you (great patch makers) could make it i`ll be very gratefull |
07-10-2004, 18:14 | #1528 (permalink) |
Member: 30834 Status: Offline Thanks Meter: 0 | @rc-flitzer I see. OK it's nothink big, just question. About fonts: My friend from Poland made it there is a link: http://mackam.fm.interia.pl/tmp/SL45...PL_v03-MrK.vkp but You must change some it because it's mede for Polish users. |
07-10-2004, 18:55 | #1529 (permalink) |
Member: 30834 Status: Offline Thanks Meter: 0 | @deschek Riza slove this problem in his *** MBT. Menu Button Text *** I appled rc-flitzer's 1st. temperature verision (no selectable) and MBT. I don't need it selectable because I always have a time on Right Softkey button. |
07-10-2004, 19:30 | #1530 (permalink) |
Member: 41290 Status: Offline Thanks Meter: 0 | MacKam I don`t mean to make it selectable but leave the clock on his place and make another patch that will show temperature in other place than place where is now clock or on right soft key, rc-flitzer (as i remember the temperature patch is made by you) what do you think about it? |
SLIKv56: Flash patches. | arman68 | x4x, x5x Flashpatching | 685 | 10-02-2011 10:56 |
TOC for Sticky: SLIKv56: Flash patches. | StevieRay | x4x, x5x Flashpatching | 17 | 10-15-2005 08:26 |
"Bugs" in Thread SLIKv56: Flash patches | trustkill | Siemens-Benq Flash Patching | 2 | 07-13-2004 07:33 |
SLIK v56: Flash Patching (2nd part) ... | rizapn | x4x, x5x Flashpatching | 329 | 09-07-2003 10:28 |
Where can i download riza's SLIKv56: Flash Patching (3rd part) | Gabriel_he | Siemens-Benq Flash Patching | 2 | 04-04-2003 03:20 |
