07-23-2004, 19:27 | #1621 (permalink) |
Freak Poster Join Date: May 2003 Location: Tehran Age: 52
Member: 27936 Status: Offline Thanks Meter: 0 | @RizaPN |
07-23-2004, 20:56 | #1622 (permalink) |
Major Poster Join Date: Apr 2003 Location: Poland Age: 44
Member: 26593 Status: Offline Thanks Meter: 0 | Is there any easy way (just changing some hex values in patches) to move the existing patches to another profile in new APPv3 hope you understand what I mean |
07-24-2004, 00:23 | #1623 (permalink) |
Insane Poster Join Date: May 2002 Age: 39
Member: 12407 Status: Offline Thanks Meter: 0 | @Mackam: try this, but i can't promise it will work, im to sleepy to test this... Profile 1(000E:3A42h): 52713C: 0E 527140: 423A Profile 2(0036:096C): 52713C: 36 527140: 6C09 Profile 3(0036:096Eh): 52713C: 36 527140: 6E09 |
07-24-2004, 01:30 | #1624 (permalink) |
No Life Poster Join Date: Mar 2002 Location: -[r0]- Age: 53
Member: 9891 Status: Offline Thanks Meter: 2 | @APP menu: The story why I relocate "Menu Mode" instead of changing --Help-- menu was: I want to minimize the deletion of menu item (maybe somebody still need Help). But, now, I think, nobody use Help anymore, especially sub-Help inside the Setup menu, so I did modify the APP v3 (to become v3b) menu as in the Sticky posting (change --Help-- to Application). Please reapply, and sorry not to keep the v3 patch in that Sticky (for someone who really do not want to loose their Setup-Help menu) ... Siemens Flash Explorer 'sfe': New sfe v2.26, downloadable from http://www.geocities.com/rizapn with these modification and improvement : *) bug correction for disassembler function with 'p' options. Some org was not displayed correctly. *) remove 'mem_' output display for disassembler with 'p' options, make the output more assembler-able without any modification. *) add 'base' mnemonic and baseAddr options for assembler (usefull in 'p' options). Firmware address will be automatically convert to fullflash file offset, for example "org 0c70000" will produce "0x270000: ..." patch output with base 0A00000h. *) add original files as a parameter for assembler with 'p' options to create a full patch output. *) add 'modify' firmware text capability as a subfunction of 'l' command. *) add 'dump' firmware in hexa-and-ascii format as a subfunction of 'f' command. rizapn Last edited by rizapn; 07-24-2004 at 04:41. |
07-24-2004, 08:57 | #1625 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Russia inc. Age: 51
Member: 48199 Status: Offline Thanks Meter: 0 | Hello people! Here`s some interesting bytes: 1.Vertical coordinate and font style of date/time string in several modes. The zero level is the first line under net/battery indicators string, (-1) level is FF, (-2) is FE etc. 18E67A: 31 XX ; Netsearch 18E67C: 07 XX ; Font style 18E6A2: 31 XX ; Normal 18E6A4: 07 XX ; Font style 18E6C2: 31 XX ; Logo 18E6C4: 07 XX ; Font style 2.Vertical coordinate and font style of the operator name string 18E692: 09 21 ; operator name 18E694: 03 XX ; Font style 18E672: 09 21 ; net search 18E674: 03 XX ; Font style So, data in the location 18E650-18E6D4 is table of coordinate, font style etc for main screen mesages in some modes. I`m not trying everything of this, only several ones. |
07-24-2004, 10:49 | #1626 (permalink) |
No Life Poster Join Date: Oct 2003
Member: 42457 Status: Offline Thanks Meter: 1 | Could there be an error in the current APP patch? If I choose Settings/Application the mobile crashes, the old version works with now problems. I think there's an error in the entrypoint |
07-24-2004, 12:35 | #1627 (permalink) | |
No Life Poster Join Date: May 2003 Location: GERMANY Age: 49
Member: 27745 Status: Offline Thanks Meter: 0 | Quote:
07-24-2004, 12:44 | #1628 (permalink) | |
07-24-2004, 12:53 | #1629 (permalink) |
Freak Poster Join Date: Mar 2003
Member: 25285 Status: Offline Thanks Meter: 0 | hello, i have no problem with APPv3a patch. trustkill&cypher: "This v3 use also the old SCI 'SMS Counter Info' patch area, so use the latest ;version of SCI if you want to apply both." maybe this is the answer? k-mac |
07-24-2004, 12:59 | #1630 (permalink) | |
07-24-2004, 13:41 | #1631 (permalink) |
Member: 27745 Status: Offline Thanks Meter: 0 | Its me again (hattrick!): Can somone tell me the values that I have to change for the "Y" coordinates of the following patches (must be moved to the old "Date" line: -Profile Logo -Improved Net-Indicator (solved/ thank you ashor) -Battery in % (only values -f , I need more !) Last edited by trustkill; 07-24-2004 at 19:55. |
07-24-2004, 17:20 | #1632 (permalink) |
Freak Poster Join Date: Jun 2003
Member: 30834 Status: Offline Thanks Meter: 0 | @APP. Application Menu v3b :/ when I want go to APP (instead Help) phone turn off. BTW. It's possible to set default position in Setup menu to APP no "Menu mode" @arsh0r Thx. Your cusomization (APP3) works perfect! |
07-24-2004, 17:26 | #1633 (permalink) |
Member: 42457 Status: Offline Thanks Meter: 1 | The entrypoint and textstring for app3b seems to be okay - I checked this. I think it's the submenu the old APP and APP3a created/creates. Maybe the routines to get the submenu were not all clearly deleted - that's my suggestion... Anyway I can't help because my knowledge in assembler goes hardly to zero btw is there any siginificant difference between APPa und APPb? I mean that in future we must use the b version because patches don't use the same byteadress to be checked (stupid question)? I think a working menu is better than a dead one |
07-24-2004, 18:16 | #1634 (permalink) |
Member: 27936 Status: Offline Thanks Meter: 0 | i'm asking RizaPN to make the application menu v3a the major one for applying new patches. I think this is better one than 3b and undoing version 3a makes some defects in firmware. |
07-24-2004, 19:22 | #1635 (permalink) |
Member: 42457 Status: Offline Thanks Meter: 1 | Defects in firmware? Explain! I think that's nonsense. I reinstalled 3a more than 10 times and there wasn't ANY errormessage (except as I changed the values for loading textstrings )) But I don't care |
SLIKv56: Flash patches. | arman68 | x4x, x5x Flashpatching | 685 | 10-02-2011 10:56 |
TOC for Sticky: SLIKv56: Flash patches. | StevieRay | x4x, x5x Flashpatching | 17 | 10-15-2005 08:26 |
"Bugs" in Thread SLIKv56: Flash patches | trustkill | Siemens-Benq Flash Patching | 2 | 07-13-2004 07:33 |
SLIK v56: Flash Patching (2nd part) ... | rizapn | x4x, x5x Flashpatching | 329 | 09-07-2003 10:28 |
Where can i download riza's SLIKv56: Flash Patching (3rd part) | Gabriel_he | Siemens-Benq Flash Patching | 2 | 04-04-2003 03:20 |
