07-31-2004, 10:15 | #1666 (permalink) |
No Life Poster Join Date: Oct 2003
Member: 42457 Status: Offline Thanks Meter: 1 | |
07-31-2004, 16:15 | #1667 (permalink) |
Crazy Poster Join Date: Jun 2004 Location: Szczecin (Poland) Age: 41
Member: 68809 Status: Offline Thanks Meter: 0 | I think that "BFP. Bitmap File Preview" has a bug. When I preview a bitmap and then press 'Cancel' (not 'Open') my old bitmap, the one that was situated on my display, is removed. |
07-31-2004, 16:31 | #1668 (permalink) | |
Member: 42457 Status: Offline Thanks Meter: 1 | Quote:
08-01-2004, 00:05 | #1669 (permalink) | |
Member: 68809 Status: Offline Thanks Meter: 0 | Quote:
08-01-2004, 01:38 | #1670 (permalink) |
No Life Poster Join Date: Mar 2002 Location: -[r0]- Age: 53
Member: 9891 Status: Offline Thanks Meter: 2 | No, my dirty word means, the trick/method used in the patch is not good enough (due to a limited knowledge of course). But, the result should not be dirty. The h3ct0r report is really bug. @H3ct0R: what do you mean with : "When I preview a bitmap and then press 'Cancel' (not 'Open') my old bitmap", becuase in my phone the button is : [Save] and [Cancel], there is no [Open] button (maybe [Open] is in the previous screen if we patch the rightSoftKey button for CardExplorer). So, which screen did you mean? After previewing, or the one before? Also, in my phone, everything is working fine. If we press [Cancel] then the old bitmap will not be changed, and still there, not removed. Does someone else using this patch has a same problem with H3ct0r? rizapn |
08-01-2004, 05:19 | #1671 (permalink) |
Insane Poster Join Date: Jun 2003 Location: Tehran Age: 48
Member: 32346 Status: Offline Thanks Meter: 0 | @Rizapn I have the same problem as H3ct0r!!! In the preview screen, If I choose "Save" everything is ok but if I choose "Cancel" the previous picture in my display will be deleted and it goes back to the operator logo!! Of course before testing this I disabled "animated operator logo" and "digital clock" from the application menu. |
08-01-2004, 09:17 | #1672 (permalink) | |||
08-01-2004, 09:38 | #1673 (permalink) | |
No Life Poster Join Date: May 2003 Location: GERMANY Age: 49
Member: 27745 Status: Offline Thanks Meter: 0 | Quote:
08-01-2004, 10:03 | #1674 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | Ups, 3 people reporting the same bugs is more than enough (for me). But, really, I have check the source again and again (yes, "only" twice, I'll do it again ), nothing could make that happened. I think about other patch combination also, but ... BTW... 1/ How if you guys quit from that screen by pressing another button (not the Cancel ones) ? 2/ Is there anyone applying that patch with no problem? (Cancel is not delete the previous op.logo)... rizapn |
08-01-2004, 10:12 | #1675 (permalink) |
Member: 42457 Status: Offline Thanks Meter: 1 | Okay I was wrong Well...I've got the same "bug" but really the patch is good enough even if it's a bit dirty. 1./ I press the cancel button to quit the preview (I think the others too), after pressing cancel it jumps back to the bitmap folder and if you quit the card-explorer, voila the picture is deleted........ |
08-01-2004, 10:26 | #1676 (permalink) |
Member: 9891 Status: Offline Thanks Meter: 2 | Very-very strange ... that is not happened in my phone. Goto CardExplorer - Bitmap - Open - Cancel - RED - RED, and ... everything is back, just like the original condition ... OK, I change a little ... please try to UNDO the existing ones, and apply this : ;~~~~~~~~~~~~~~~~~~~~~~~~~~ 0x02D5C0: E6FCBB00 DB00CC00 0x3874E2: E6F61D00 DAE4C049 0x38CD46: DAE638F1 DAE4DA49 0x4449C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6F44828E0C5E6FB2000E00AE6F38001 0x4449D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAC70AEEE6F61D00DB0088908880E6FD 0x4449E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 5028E0CE88E088D026FD0800E6FC214E 0x4449F0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAC1543F0804E6FC5AF5E6FDD800E6FE 0x444A00: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 96F5F0FDDAF03CFDF084F095F0C8F0D9 0x444A10: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E6FE4E0AE6FF9103DAF024FFFADBBC70 0x444A20: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DC4FD44E020046F41F002D0CE004E6F5 0x444A30: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2000E6FA4828E0CBE6F38001DAC70AEE 0x444A40: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FAE64EF6E6FCBB00DAA2C4D50DF90000 0x444A50: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0000204AE40000000000D849E400DA3D 0x444A60: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E302BA3DE2020000080065002F00780A 0x444A70: FFFFFFFFFFFFFFFFFFFF 9103000000000000214E ;~~~~~~~~~~~~~~~~~~~~~~~~ rizapn |
08-01-2004, 10:35 | #1677 (permalink) |
Member: 42457 Status: Offline Thanks Meter: 1 | Okee I've applied that patch AND AND AND AND AND It seems to be fixed... The OPLogo isn't deleted by cancel anymore and save still works also as it should be Man you're quick Thank you |
08-01-2004, 11:44 | #1679 (permalink) |
Freak Poster Join Date: May 2003 Location: Tehran Age: 52
Member: 27936 Status: Offline Thanks Meter: 0 | For Me the bug exists.everytime I load bitmap then press cancel and go to main menu with red button, The background bitmap disapears. I must load and save the pic again.it automatically unloads the screen bitmap when only viewing it. |
08-01-2004, 11:47 | #1680 (permalink) |
Member: 27936 Status: Offline Thanks Meter: 0 | @RizaPN Thanks for Screen Capturer program. but How long it takes to capture screen with this sw? I saw that the video Ram is 160C, does it mean it must read till 160C address? |
SLIKv56: Flash patches. | arman68 | x4x, x5x Flashpatching | 685 | 10-02-2011 10:56 |
TOC for Sticky: SLIKv56: Flash patches. | StevieRay | x4x, x5x Flashpatching | 17 | 10-15-2005 08:26 |
"Bugs" in Thread SLIKv56: Flash patches | trustkill | Siemens-Benq Flash Patching | 2 | 07-13-2004 07:33 |
SLIK v56: Flash Patching (2nd part) ... | rizapn | x4x, x5x Flashpatching | 329 | 09-07-2003 10:28 |
Where can i download riza's SLIKv56: Flash Patching (3rd part) | Gabriel_he | Siemens-Benq Flash Patching | 2 | 04-04-2003 03:20 |
