04-12-2003, 22:13 | #166 (permalink) |
Junior Member Join Date: Mar 2003 Location: Moscow Age: 50
Member: 23628 Status: Offline Thanks Meter: 0 | 620AD900 ;Write-Message 780AD900 ; Predef. message EE0AD900 ;Incoming-Message F80AD900 ;Outgoing-Message 020BD900 ;Archive 2C0BD900 ;Setup DEFFEB00 ;Help F20DD900 ;Voice message Predef. message E609D900 ;Late 000AD900 ;Appointment 1A0AD900 ;Anniversary |
04-12-2003, 23:56 | #167 (permalink) |
Major Poster Join Date: Nov 2002 Age: 46
Member: 17718 Status: Offline Thanks Meter: 0 | Hello RizaPN My brother RizaPN : (i found the patch below in the FW V.55 patching section in this forum and i think it is very useful patch and many users need it for FW V.56 , can u made it for us my brother RizaPN plz ???) >>>the short alert when dialing in 50 seconds, 110seconds, 170seconds, -------, so that you can avoid talking over one minutes and be charged more: 001F62 : E6 FC 3C 00 -> DA BF 00 00 1F0000 : FF FF FF FF FF FF FF FF -> 46 F4 32 00 05 26 F4 1F0008 : FF FF FF FF FF FF FF FF -> 32 00 E6 FC 3C 00 DB 00 1F0010 : FF FF FF FF FF FF -> E6 FC 32 00 DB 00 ========================================== Second : for the great patch (Modify MultiLine Indicator to become Vibra Indicator): when i apply this patch i foud that the picture for vibration always appears on the top of my screen either vibration is active or not , can u find what is the problem plz and correct it for us?? ========================================== 3rd : the patch (#[RightSoft] as Vibra Toggle ) is not working with me, when i press #[RightSoft], java works ( i reset all values to its original values) , plz find what is the problem or change the shortcut |
04-13-2003, 02:10 | #168 (permalink) | |
Crazy Poster Join Date: Mar 2003
Member: 24557 Status: Offline Thanks Meter: 0 | Re: Hello RizaPN Quote:
And if you want to change the vibra-shortcut you can modify the patches already made by riza, like Toggling vibra with [0]+[RightSoft] 003B309E : 48 40 -> E0 14 003B30C4 : 7B 03 -> C8 02 003B3322 : DA A0 AC 15 -> DA C7 30 D6 003B3326 : 48 40 -> E0 04 or another like this. Just use the vibra entry point DA C7 30 D6 and text C8 02 | |
04-13-2003, 10:25 | #170 (permalink) |
Freak Poster Join Date: Mar 2003
Member: 25285 Status: Offline Thanks Meter: 0 | @Gurgy you be right. for my profiles only one line needed. thanks again! @Austin316: thanks but i`m looking sth else. in english menu when you go to messages you can see: SMS<<< voice message cell broadcast. and i need exactly SMS. because from this menu i use often more then oe position so i dont wanna i gfx menu 4new position when i can have only one regards k-mac sorry 4my poor english |
04-13-2003, 17:49 | #173 (permalink) |
Freak Poster Join Date: Jul 2002
Member: 13636 Status: Offline Thanks Meter: 0 | @RizaPN & ALL: Thanks for your new Vibra-toggle with Vibra Indicator! It works great! But i think, it is better, if the indicator is shown, if the vibrator is off, like the speaker indicator. Now it is the opposite! |
04-13-2003, 19:21 | #175 (permalink) |
Freak Poster Join Date: Jan 2003 Location: Croatia Age: 43
Member: 20219 Status: Offline Thanks Meter: 0 | @RizaPN What about the patch showing both caller number and name? You say that you have some problem to finish that patch. That it will be very nice patch.. Thanks. |
04-13-2003, 19:32 | #176 (permalink) | |
No Life Poster Join Date: Mar 2001 Location: Earth
Member: 3506 Status: Offline Thanks Meter: 6 | that will be great !!! Quote:
04-14-2003, 00:25 | #177 (permalink) |
No Life Poster Join Date: Mar 2002 Location: -[r0]- Age: 53
Member: 9891 Status: Offline Thanks Meter: 2 | *** 54. Call Minutes Beep Modification *** Firmware : SL45v56 Author : RizaPN Release : April 14, 2003 It will give you call minutes beep at 10 seconds before each minutes (just another version). 0x001F20 : F2 F4 0C FE -> DA C7 10 D1 0x27D110 : FF FF FF FF FF FF FF FF -> F2 F4 0C FE 46 F4 32 00 0x27D118 : FF FF -> DB 00 If you want to modify the margin, just modify byte 32 in the address 0x27D116 to become your own value (hexa 32 = decimal 50). ~~~~~~~~~~~~~~~~ RizaPN |
04-14-2003, 13:54 | #179 (permalink) |
Junior Member Join Date: Mar 2003 Location: hihkjh Age: 45
Member: 25193 Status: Offline Thanks Meter: 0 | can anybody tell me how to change patch: ************************** ;Create new shortcut for Inbox SMS (located on the SIM card) ;Firmware: SL45 v56 ;Author: RizaPN ;* overwrite 'Profile' shortcut ;* use your full-flash file +0 18E3AC: 2A08 5A03 18E3E0: 0B02 D300 18E524: 2A082A08 5A035B03 3AE412: DADF944C DAD9EE0A ******************************* I need shortcut for Inbox SMS and for Profil (how change that patch to overwrite "IrDA" with Inbox SMS?? ) |
04-14-2003, 13:58 | #180 (permalink) |
Member: 17688 Status: Offline Thanks Meter: 0 | small problem with gfx menu From the GFX menu I went to Time/Date and when pressed OK directly exits to the idle menu. Then pressed the right-soft key for normal Main-Menu > Red key > returns to Date/Time entry menu (This should be the position to exit after pressing the OK key to set the date & time). Anyone got the same problem? Nasym |
SLIKv56: Flash patches. | arman68 | x4x, x5x Flashpatching | 685 | 10-02-2011 10:56 |
TOC for Sticky: SLIKv56: Flash patches. | StevieRay | x4x, x5x Flashpatching | 17 | 10-15-2005 08:26 |
"Bugs" in Thread SLIKv56: Flash patches | trustkill | Siemens-Benq Flash Patching | 2 | 07-13-2004 07:33 |
SLIK v56: Flash Patching (2nd part) ... | rizapn | x4x, x5x Flashpatching | 329 | 09-07-2003 10:28 |
Where can i download riza's SLIKv56: Flash Patching (3rd part) | Gabriel_he | Siemens-Benq Flash Patching | 2 | 04-04-2003 03:20 |
