08-27-2004, 07:19 | #1996 (permalink) |
Freak Poster Join Date: Jun 2004 Location: Romania Age: 43
Member: 67838 Status: Offline Thanks Meter: 0 | I notice that in the logs generated by Call Detail Record v2.3, the duration for the call is written as m:ss. What happens when the actual duration is greater than 10:00 minutes? I'm developing a(nother) log readed midlet, and I'm trying to find out all possible details. Also, what happens when the incoming/missed call number is hidden? I came across a situation where I think an incoming hidden number call was logged as Number:+ and Name: a name from the address book. Thank you for your work. Kind regards, Andrei |
08-27-2004, 07:31 | #1997 (permalink) |
Freak Poster Join Date: May 2003 Location: Russia, Ekaterinburg Age: 44
Member: 29316 Status: Offline Thanks Meter: 0 | LRT 1.2 compatible whith ICD2.2 and needed the ICD2.2 instaled, with assign any ringtone i think is compatible too. whith ICF is compatible too Last edited by DeadManS; 08-27-2004 at 08:12. |
08-27-2004, 07:50 | #1998 (permalink) |
No Life Poster Join Date: Mar 2002 Location: -[r0]- Age: 53
Member: 9891 Status: Offline Thanks Meter: 2 | @adancau: - The complete duration output should be hh:mm:ss - Hidden number : + (small bugs), it should be empty, name should be blank @memViewer: - The bin file is updated. Download it from the Sticky topics. rizapn |
08-27-2004, 10:11 | #1999 (permalink) | |
Freak Poster Join Date: May 2004
Member: 65231 Status: Offline Thanks Meter: 0 | Quote:
08-27-2004, 11:49 | #2000 (permalink) | |||
No Life Poster Join Date: Oct 2003
Member: 42457 Status: Offline Thanks Meter: 1 | Hmm... Sorry I just post the core of Patches I use Quote:
But I think one or two weeks later I decided to use the "Battery in Percent" patch so... Quote:
Last but not least the BCI patch... I use the readressed version and use the entrypoints provided by the "Main Screen Patch" that are free for further usage Quote:
Hope that will help you know... I think the best would be if someone changes Rizas' indicator to be able to show also Battery in Percent! | |||
08-27-2004, 11:50 | #2001 (permalink) |
Member: 42457 Status: Offline Thanks Meter: 1 | There's a small mistake, I think we must change the entrypoints of BSI patch but I'm in hurry. Just try out...as I said before, the best would be if someone changes rizas patch to be able to also show Battery in %, then we have the little battery indicator viewable with % sign Okay I found my "mistake" just enter this data if you want to use Rizas advanced Net Indicator: 0x3B36EA: DAC1EC22 DAE4464E For setting the # in percent patch to y-coordinate: Look for e00d (this byte pattern exits 4 times so look 4 times for that!) and change it to e0yd, y is a value between 0 and f, sorry you can set the Battery in % Patch only max 15 pixles. Naransula posted a better one but I was unable to get that thing running But now it's 100% tested and running (You've luck, my girlfriend just send me an SMS that she's working a bit longer!) Last edited by cyperghost; 08-27-2004 at 12:17. |
08-28-2004, 08:40 | #2002 (permalink) |
Member: 67838 Status: Offline Thanks Meter: 0 | @RizaPN: Is there any possibility of CDR v2.3 switching the phone off after a conversation, without writing in the call logs? It happens now and then on my phone, I was wandering if this could be it. Also got the ICD v2. Kind regards, Andrei |
08-28-2004, 10:53 | #2004 (permalink) |
Freak Poster Join Date: May 2003 Location: Tehran Age: 52
Member: 27936 Status: Offline Thanks Meter: 0 | @Riza after applying changed BCI and SCI patches, and from yesterday till now, I have not wrong sent message report. and some wishes: is it possible to have AM/PM Time selectable? and Auto Power on when charger is connected? |
08-28-2004, 18:33 | #2005 (permalink) |
Member: 65231 Status: Offline Thanks Meter: 0 | @cyperghost: I used Profile Logo as well as Free SMS in Collection of patches, with BSI, and that combination doesn't work. You say that it works with Free SMS. Good. However, since I need profile logo more than BSI, I'm reverting to Battery in percentage. Idea to have small picture by battery in percentage is great. Maybe it would be easier to modify Battery in percentage patch, instead of BSI? |
08-28-2004, 19:12 | #2006 (permalink) |
Member: 42457 Status: Offline Thanks Meter: 1 | @vizionar I hope you don't applied this 0x27D704: CC00CC00 DAE4464E ;--> new entrypoint for NetIndictor, I don't use that so I remark, if yes then it doesn't work - you'll loose net indicator ability use 0x3B36EA: DAC1EC22 DAE4464E that instead. Well I don't use the profile logo but the profile logo is applied before SMS indicator and that means that it must work! |
08-28-2004, 19:27 | #2007 (permalink) | |
Member: 42457 Status: Offline Thanks Meter: 1 | Sorry for posting that huge thread @vizinar I tested again and it works in my phone, maybe I wrote a bit to sluggy....but here is my patch configuration that should work now. I don't know in how far you've changed the patches, I used the orignal ones now So write a small feedback I'm a bit in hurry, sorry Quote:
08-28-2004, 21:02 | #2008 (permalink) |
Member: 65231 Status: Offline Thanks Meter: 0 | I tried what you posted and it worked for free sms, profile logo and net indicator, but I had nothing for battery indicator, no picture, no number, nothing, empty space. This is because I commented line: Code: ;0x27D6F0: FFFFFFFF DAE0CECA ; battery in percent Ma idea was to leave net normal, just pictures, and to change battery to mV and small bat pics as in BSI. Plus, of course, free sms an dprofile logo from Collection of mainscreen.... Sorry for making you have a mental breakdown, that is not my intention, even though it may seem as it is Just trying to solve this because battery in percentage is not good for me. Don't know when the charge is over (battery full) since it reaches 100 % very quickly (from empty to 100 in 15 mins) and then just varies from 97 to 113, sometimes even 199 % . So I never know when it's full completely. I have to stopwatch 2,5 hrs to be sure battery is charged Thanks for all help, I appreciate it very much! |
08-29-2004, 11:58 | #2009 (permalink) | |
Member: 42457 Status: Offline Thanks Meter: 1 | @Vizionar: I've tested the patch now and it works like it should Greetings from: germany also no problem If you use normal battery indicator then apply this patch I think we "kill" the normal battery indicator of the MSP Collection and make a direct jump to the other patches "SMS Indicator, Profile Logo...." Therefore: Offset for Profile Logo=0x27D6F4 + A00000 =C7D6F4 --> new entrypoint = DAC7F4D6 Quote:
Last edited by cyperghost; 08-29-2004 at 19:44. Reason: Tested, approved, working! | |
08-29-2004, 12:00 | #2010 (permalink) |
Freak Poster Join Date: Jun 2003
Member: 30834 Status: Offline Thanks Meter: 0 | @RizaPN One more about APP3a How delete "menu mode" from 3a version? Only delete no move to help in setup. And about CRD v2.3 add option for create LOG not only from 01 do 31 e.g. but make customization like 16 to 16. regards MacKam |
SLIKv56: Flash patches. | arman68 | x4x, x5x Flashpatching | 685 | 10-02-2011 10:56 |
TOC for Sticky: SLIKv56: Flash patches. | StevieRay | x4x, x5x Flashpatching | 17 | 10-15-2005 08:26 |
"Bugs" in Thread SLIKv56: Flash patches | trustkill | Siemens-Benq Flash Patching | 2 | 07-13-2004 07:33 |
SLIK v56: Flash Patching (2nd part) ... | rizapn | x4x, x5x Flashpatching | 329 | 09-07-2003 10:28 |
Where can i download riza's SLIKv56: Flash Patching (3rd part) | Gabriel_he | Siemens-Benq Flash Patching | 2 | 04-04-2003 03:20 |
