09-24-2004, 10:48 | #2117 (permalink) |
Insane Poster Join Date: Apr 2003
Member: 27506 Status: Offline Thanks Meter: 0 | the patches LTR- Loadable RingTones and ICD. Incoming Call Display v2.2 doesn't work for me at all, i have a lot of other patches installed in my phone, though there was no conflict in installing them in the phone could there be a incompatibility issue? Did enyone else happened that? |
09-30-2004, 09:01 | #2119 (permalink) |
No Life Poster Join Date: May 2003 Location: GERMANY Age: 49
Member: 27745 Status: Offline Thanks Meter: 0 | About "long Date" The "Date via language pack" is a nice patch ! But when I try to change my language pack as you mentioned to "Januar" & "Monday" etc. ist shows the string like this one: Monday13Januar Ok, I solved the "problem" by changing the day string to "Monday, [CommaSpace]" and "._[DotSpace]Januar" but is it normal ? |
09-30-2004, 17:05 | #2120 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Russia inc. Age: 51
Member: 48199 Status: Offline Thanks Meter: 0 | Yes, you can insert Space or any ASCII symbol before or after name of day and month. You can see example in the patch - I use one Space by put this text: "<95> " - space between > and ". |
09-30-2004, 20:13 | #2122 (permalink) |
Freak Poster Join Date: Jun 2003
Member: 30834 Status: Offline Thanks Meter: 0 | Derar Riza! I write in name of all Polish users form forum.siemensinfo.pl. (not only) and my own. We need Your help! As we know FAM is heavily buggy We loss our addressbooks too often (e.g. today I 3 times! ) Pls. try to fix it! And one more thing, our SMS logs are about 30KB! So any midlet can't work with that file Can you make write SMS logs in separate files too? Sorry for disturb you, but it's very important for us, just simple SLIK users. regards MacKam |
09-30-2004, 21:57 | #2123 (permalink) | |
Member: 27745 Status: Offline Thanks Meter: 0 | Eehm, I have SMS in a seperate log file... Quote:
10-01-2004, 11:39 | #2125 (permalink) |
Freak Poster Join Date: May 2004
Member: 65231 Status: Offline Thanks Meter: 0 | That's really big problem. I don't have that problem, but have problem of java applets loading file from MMC. It's also CDR/FAM related problem, riza told us so. Byt how is it possible to have so different sympoms? Is it possible that some other patches also make this FAM bug appear more frequently, or appear in different form? It just crossed my mind today, is it possible that Skip Addressboook when viewing sms patch can cause some problems with FAM...? Has anyone tried FAM without this Skip... patch? What are your experiences? |
10-01-2004, 12:48 | #2126 (permalink) |
No Life Poster Join Date: Oct 2003
Member: 42457 Status: Offline Thanks Meter: 1 | No "Skip Adressbook when viewing SMS" has NOTHING in common with FAM If you view an SMS it first searches for the sender in adressbook (making the viewing annoying slow) and if there's no content then it searchs second the SIM location (much much faster) So the patch expressed in easy words just skips the adressbook. There are some configurations for that patch * Skip Adressbook in list and viewing mode (you can get it from this forum - but has some bugs if you want to send an SMS and your SIM is empty you can't enter a reciepient) * Skip Adressbook in list but use it in viewing mode (I use that variant and the bug written above is canceled) |
10-01-2004, 23:41 | #2127 (permalink) |
Member: 65231 Status: Offline Thanks Meter: 0 | OK. But aren't you wondering how come that different people have different "symptoms" in their SL's 45, even though the origin of the problem is the same - FAM? I never lost an addressbook, but if I want to have java working normally, I have to turn phone on and off more than 10 times a day. So, both problems appear often, but what is the cause of these two different problems appearing - why not only one? Or both, but in every SL45? Maybe that answer could lead to idea which would enable riza or someone else, to fix fam... |
10-02-2004, 11:53 | #2129 (permalink) |
Member: 27745 Status: Offline Thanks Meter: 0 | Once again: I had the problem with the "disappearing adressbook" only once (after installing fam). Now my mobile runs without any errors. And I use CDR/FAM/ANM etc... |
10-03-2004, 17:35 | #2130 (permalink) |
Member: 42457 Status: Offline Thanks Meter: 1 | sorry for being late Here the patch with comments Code: ;*** Skip Addressbook for SMS Viewing *** ;Firmware : SL45v56 ;Author : RizaPN ;Release : May 11, 2003 ; By applying this, SMS sender number will only be searched in the ;SIM-Location when you viewing the list of SMS. ; When you viewing text of SMS, the name of SMS sender will be searched ;in the Addressbook. ; This patch make SMS viewing faster in some conditions. 39995A: 88908880 DAC770DA 399A7A: 66FCFF3F DAC760DA 27DA60: FFFFFFFFFFFFFFFFFFFF D7400C00F68E521ADB00 27DA70: FFFFFFFFFFFFFFFFFFFFFFFFFFFF D7400C00F68F521A88908880DB00 ;~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ;RizaPN but I've the same symptoms as you. Sometimes Java does not run - I've to turn off phone and then switch it on. And as trustkill mentioned I also lost my adressbook as I installed the FAM patch. There was a discussion of that topic. FAM kills Adressbook - Let's discuss the reasons. If you have any experience or suggestion use that topic to post please |
SLIKv56: Flash patches. | arman68 | x4x, x5x Flashpatching | 685 | 10-02-2011 10:56 |
TOC for Sticky: SLIKv56: Flash patches. | StevieRay | x4x, x5x Flashpatching | 17 | 10-15-2005 08:26 |
"Bugs" in Thread SLIKv56: Flash patches | trustkill | Siemens-Benq Flash Patching | 2 | 07-13-2004 07:33 |
SLIK v56: Flash Patching (2nd part) ... | rizapn | x4x, x5x Flashpatching | 329 | 09-07-2003 10:28 |
Where can i download riza's SLIKv56: Flash Patching (3rd part) | Gabriel_he | Siemens-Benq Flash Patching | 2 | 04-04-2003 03:20 |
