10-16-2004, 02:41 | #2147 (permalink) | |
Freak Poster Join Date: Jun 2004 Location: Russia, Zelenograd Age: 35
Member: 70080 Status: Offline Thanks Meter: 2 | Quote:
Init -> left panel: load -> select 5168.txt -> button ">" -> right panel: select block 5168 -> save selected | |
10-16-2004, 07:19 | #2148 (permalink) | |
Freak Poster Join Date: Jan 2004 Location: Russia inc. Age: 51
Member: 48199 Status: Offline Thanks Meter: 0 | Quote:
10-16-2004, 13:21 | #2149 (permalink) |
No Life Poster Join Date: May 2003 Location: GERMANY Age: 49
Member: 27745 Status: Offline Thanks Meter: 0 | If I apply the newest Rx Battery Level 2.1 patch, my phone always crashes. I installed the A1P & LPE withot any erroe & installed the eeprom block too. Anyone else has this problem ? |
10-17-2004, 05:24 | #2150 (permalink) |
Freak Poster Join Date: May 2003 Location: Russia, Ekaterinburg Age: 44
Member: 29316 Status: Offline Thanks Meter: 0 | some info about install RBL, before install this patch, uninstall ABA patch and after them install RBL, and after install ABA. 2trustkill : do you uninstall LPF and previos RBL patches 2vizionar: try tochange coordinates with options midlet, my value 01 00 01 50 00 18 00 4B |
10-17-2004, 20:53 | #2151 (permalink) |
Freak Poster Join Date: Jan 2003 Location: Croatia Age: 43
Member: 20219 Status: Offline Thanks Meter: 0 | Hi all! Can some copy/paste patch version who work normaly? Automatic recording for incoming & outgoing voice calls for SL45 v56 It a few versions, but every version on outgoing call (when the dictaphone must start record) shutdown my phone.. So if you applay this patch, and it work normaly on your phone please copy paste your applayed patch here. Please help. |
10-21-2004, 10:26 | #2155 (permalink) | |
Member: 27745 Status: Offline Thanks Meter: 0 | Quote:
Code: base 000000h mov r12, #2Fh ; or #00h calls 0C30014h rets I have now "VibraOn.bin" & "VibraOff.bin", it´s a great sample for the BFA.Binary File Access Patch. For everyone who´s interested, here is a link to the patch2bin perl script: LINK to patch2bin | |
10-24-2004, 14:03 | #2156 (permalink) |
Member: 20219 Status: Offline Thanks Meter: 0 | Hi all. Can someone insert text on this functions in first application Riza menu: Function 9 ---- BlinkLight Function 13 ---- MenuButton Function 14 ---- RecordAll Function 15 ---- Temp. Second: About "RAC-Record All Calls V3" patch from DeadManS (14. 08. 2004.) When I call someone the auto record start fine and there is no problem. When I want finish the call first I must press left soft key button to save. I automaticly (before when I applay this patch) press red button to end the call. And now (with patch) when I whant to end call and I press red button, phone goes off from dictaphone and I lose my record conversation. First I must click on left soft key button to STOP then to SAVE, and then with red butoon break the line. My question is.. Can someone make patch that be red button be first stop then save button (like left soft key)? I hope you understand what I mean. I know for Riza patch "RBD. RED Button in Dictaphone" but than again I must press two times left soft button and one time rigt soft button to save, and than press red button to end call. I want press only red buton: 1. time: for stop 2. time: for Save 3. time: for Save in that name 4. time: for end call Or maybe someone can do it all in one or two times with new patch? Thanks to all patches and thanks DeadMeanS for this great patch) Thered: With VWO patch I got vibration when I established telephone line with person I called. Could someone remove that vibration? Thanks all again. Last edited by Fabi_Kc; 10-24-2004 at 15:05. |
10-26-2004, 19:36 | #2158 (permalink) |
No Life Poster Join Date: May 2004 Location: Colombia Age: 35
Member: 64398 Status: Offline Thanks Meter: 153 | I need the location and how to use this functions: LightsOn() LightsOff() Im making a patch to power on and power off the ilumination of screen in a specify time (as AutoProfile) I need to this other function: EndActualCall() |
10-26-2004, 20:32 | #2159 (permalink) | |
;*** APS+ALF Automatic Profile Swapping and Auto Backlight Function *** ;This patch add two functions to Application Menu ;Firmware: SL45v56 ;Author : A_Alex ;Version : 1.00 ;Release : November 26, 2003 ;This patch will add two new function in ("Application" under Setup ;Automatic Profile Swapping - this function automaticaly switching ;between Normal Evinronment profile and Profile 1 in define time. ;Default time for Normal Evinronment from 07:00 - 20:00 and ;time for Profile 1 from 20:00 to 07:00. ;Auto Backlight Function works with backlight similarly. ;Time then backlight is turned ON 17:00 to 08:00 ;You must have RizaPN APP Patch for use this. ;After apllying this patch follow Main Menu->Setup->Application-> ;Function 8 will be Auto Backlight. ;Function 9 will be Auto Profiles. ;This patch is run with no problem under English Menu (only). ;If you are using another Language Pack, please use ;Siemens_Language_Tool by Skylord for modify your language ;--------------------------------------------------- ;Next 2 lines will modify your langpack, please comment this if ;you give warning message: The new data not found in flash ;4E6A6A: 08D7E56DC986100218A92824 0C7CBBB754A36A2518345F22 ;4E6B1A: 08D7E56DC986102C 087CBBB768FFB067 ;---------------------------------------------- 3B36C6: 46FCFFFF DAE000C7 40C700: FFFFFFFFFFFFFFFF 88C088D088908840 40C708: FFFFFFFFFFFFFFFF D7400E00F2F9423A 40C710: FFFFFFFFFFFFFFFF D7400D00F2FDDE25 40C718: FFFFFFFFFFFFFFFF 9AF90180BB0A9AF9 40C720: FFFFFFFFFFFFFFFF 0170BB1C98409890 40C728: FFFFFFFFFFFFFFFF 98D098C046FCFFFF 40C730: FFFFFFFFFFFFFFFF DB00E6FC030346FD 40C738: FFFFFFFFFFFFFFFF 14009D0446FD0700 40C740: FFFFFFFFFFFFFFFF 8D0150CCD7400D00 40C748: FFFFFFFFFFFFFFFF 42FC88242D06D740 40C750: FFFFFFFFFFFFFFFF 0D00F6FC8824DAA4 40C758: FFFFFFFFFFFFFFFF 4A98CB00E6003600 40C760: FFFFFFFFFFFFFFFF CC00F3F8F90A46FD 40C768: FFFFFFFFFFFFFFFF 11008D0666F40400 40C770: FFFFFFFFFFFFFFFF 3D02DADE2617CB00 40C778: FFFFFFFFFFFFFFFF 46FD08008DF766F4 40C780: FFFFFFFFFFFFFFFF 04002D02DADE3817 40C788: FFFFFFFFFFFFFFFF CB00FFFFFFFFFFFF ;---------------------------------------- ;If You DON'T want use Auto Swap Profiles function UNCOMMENT next line ;40C71Ñ: FFFF CC00 ;If You DON'T want use Auto Backlight function UNCOMMENT next line ;40C722: FFFF CC00 ;---------------------------------------- ;Note: You can't switch manualy to other profile while Auto Profiles is checked ;And you can't turn on/off backlight while Auto Light is checked. ;For Advanced users: ;If you want change time you must change one byte at address: ;40C738 - Time to activate Profile 1. Default value #14h (20:00) ;40C73E - Time to activate Normal Profile. Default value #07h (7-00) ;40C768 - Time to turn Illumination ON. Default value #11h (17-00) ;40C77A - Time to turn Illumination OFF. Default value #08h (8-00) ;Please remember time to activate Profile 1 MUST BE GREATER than ;activation time Normal profile, îtherwise this would be work incorrectly ;Similarly time to turn illumination ON must be greater then time to turn OFF ; ;Thanks to RizaPN for your GREAT work. ;Auto Profil switching set to: ;"activate Profile 1: 23:00" ;"activate Normal Profile: 09:00" 40C738: 14 17 40C73E: 07 09 ;Auto Backlight function set to: ; "turn Illumination on: 20:00" ; "turn Illumination off: 08:00" 40C768: 11 14 40C77A: 08 08 | |
10-26-2004, 22:46 | #2160 (permalink) | |
No Life Poster Join Date: Jan 2004 Location: Italy Age: 49
Member: 50673 Status: Offline Thanks Meter: 2 | Quote:
I have all of them (for S45i) | |
SLIKv56: Flash patches. | arman68 | x4x, x5x Flashpatching | 685 | 10-02-2011 10:56 |
TOC for Sticky: SLIKv56: Flash patches. | StevieRay | x4x, x5x Flashpatching | 17 | 10-15-2005 08:26 |
"Bugs" in Thread SLIKv56: Flash patches | trustkill | Siemens-Benq Flash Patching | 2 | 07-13-2004 07:33 |
SLIK v56: Flash Patching (2nd part) ... | rizapn | x4x, x5x Flashpatching | 329 | 09-07-2003 10:28 |
Where can i download riza's SLIKv56: Flash Patching (3rd part) | Gabriel_he | Siemens-Benq Flash Patching | 2 | 04-04-2003 03:20 |
