10-30-2004, 17:35 | #2178 (permalink) |
Freak Poster Join Date: Jan 2003 Location: Croatia Age: 43
Member: 20219 Status: Offline Thanks Meter: 0 | Can someone translate this patch from S45 to SL45? Thanks. ;*** BSI. Battery Status in % or mAh in Idle v0.14b *** ;Firmware : S-ME45i v04 ;Author: ntcn ;Release: 20.08.04 (english version) ;This patch replace battery icons in idle scree with it's capacity in % or it's current in mAh if recharging. ;This patch uses and changes original fw pictures 410,420,421 for % or mAh, ;and 253-262 for numbers in SPC numeration. ;Knowing bug: numbers are incorrect if charging with phone off 56533C: E00DF0E7 DA8E7E50 595394: E00DF0E8 DA8E8850 0E5000: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7404200F2F8E43E4881ED08E6F89A01 0E5010: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 8880D7404000F2F86A3F0D0648852D2E 0E5020: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88E0DAC9B854F084E00E26F864008D02 0E5030: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 08E10DFB06F8640006FEFD00E6FC4800 0E5040: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E00DDAC89C43E00E26F80A008D0208E1 0E5050: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0DFB06F80A0006FEFD00E6FC4D00E00D 0E5060: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAC89C43E6FEFD0000E8E6FC5200E00D 0E5070: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF DAC89C4398E0E6FC5800E00DDB00E00D 0E5080: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F0E7DA8E0050DB00E00DF0E8DA8E0050 0E5090: FFFF DB00 ; ##### Picture 410 ##### -- '%' ; ##### Picture 420 ##### -- 'mAh' ; ##### Picture 421 ##### -- inverse 'mAh' 0DEC00: 19070100 0D080100 0DEC50: 19070100 0D080100 0DEC58: 19070100 0D080100 0D93AD: 3FFFFE7F5FFFFF7FEFFFFFFFEFFFFFFF 00074407A807AA075507150722070007 0D93BD: EFFFFFFF5FFFFF7F3FFFFE7F 0F0F0F0F0F0F0F0F0F0F0F0F 0D94C5: 3FFFFE7F5102AB7FE98555FFEFCAAAFF 0007012702A752B7ABAFAAAFAAAF0007 0D94D5: E99555FF512AAB7F3FFFFE7F 0F0F0F0F0F0F0F0F0F0F0F0F 0D94E1: 3FFFFE7F50102B7FE81855FFEBFCAAFF FFFFFEDFFD5FAD4F545755575557FFFF 0D94F1: E81955FF5012AB7F3FFFFE7F 0F0F0F0F0F0F0F0F0F0F0F0F ; ##### Picture 253-262 ##### -- numbers 0..9 (5x8) 0x0D4E6C: 06D03F09283F1004 3048484848483000 0x0D4ECF: 00407F0AA87F1514 1030101010103800 0x0D4F35: 06D00F09280F1004 3048080830407800 0x0D4F95: 018006D009281004 3048081008483000 0x0D4FD7: 06D0092810042006 0818282878080800 0x0D5017: 00101F02AA1F0545 7840700808483000 0x0D507D: 01001F0AA81F1454 3040407048483000 0x0D50E3: 01000302D003042C 7848081010101000 0x0D5149: 0006010005F90018 3048483048483000 0x0D519D: 000081000B410034 3048483808083000 0x0DE718: 1221 0508 0x0DE720: 1122 0508 0x0DE728: 1420 0508 0x0DE730: 1021 0508 0x0DE738: 1020 0508 0x0DE740: 1322 0508 0x0DE748: 1322 0508 0x0DE750: 1622 0508 0x0DE758: 171C 0508 0x0DE760: 1720 0508 |
10-31-2004, 17:12 | #2179 (permalink) |
Junior Member Join Date: May 2004 Age: 40
Member: 65343 Status: Offline Thanks Meter: 0 | about call detail record.. i use this patch (;*** CDR. Call Detail Record v2.2 ***) to my lovely sl45.. and now i have 2 log files in my mmc (folder misc), one for sms detail and another one for call details, and my question is : 1. does name only shows up in call details log 2. or it also shows up in sms details log because in my phone, name only shows up in call details log.. thanks before.. -mushu- |
11-03-2004, 20:52 | #2180 (permalink) |
Crazy Poster Join Date: Sep 2004 Location: Czech Republic, Prague Age: 41
Member: 82312 Status: Offline Thanks Meter: 1 | Two small patches idea hi, i`v got small ideas 1. when is set beep as sounds and vibra is ON, and someone is calling, then pressing star will disable vibra. (in normal condition, whem sound is ON, pressing star disable ringing and vibra, but when is soung set on bepp, no) 2. make different sound for income calls and income sms`s when sound is set on beep (for example, one beep SMS, two beeps income calls |
11-03-2004, 23:24 | #2182 (permalink) | |
No Life Poster Join Date: Jan 2004 Location: Italy Age: 49
Member: 50673 Status: Offline Thanks Meter: 2 | Quote:
It's easy to adapt to SL45i... | |
11-04-2004, 12:01 | #2183 (permalink) |
Freak Poster Join Date: May 2004
Member: 65231 Status: Offline Thanks Meter: 0 | Can someone explain to me what do last two patches do? GPS and multiSIM... I've no clue what they d, yt many people are happy with it, so, I'd like to know if I'd be happy with ithem also @smartmushu: Names do not show in sms log. Only in call logs. |
11-04-2004, 15:01 | #2184 (permalink) |
Freak Poster Join Date: May 2003 Location: Tehran Age: 52
Member: 27936 Status: Offline Thanks Meter: 0 | Question from DeadMans To DeadMans regarding to your MiniGPS, I have applied your patch, insert the 5169.eep into EEPROM and made a text file called CI.txt and put it in a:\ now I have a few problems: first: although I put my CI number (898F) and location (Home) in CI text, phone shows only 898F and not Home. second: everytime I put my txt file in a:\ it becomes CI.smo. I changed the extension via phone, but there was no solution for displaying the location text. third, after changing the extension, when I copy the CI.txt file from MMC to computer and open the file, it has nonesense characters without CI numbers and Location Texts. forth, Would you explain me the correct way to insert eep file into eeprom, maybe I did a wrong way for this. fifth, finally when I put my CI.txt file into my java microreader folder and edited the numbers and texts by microreader, and then moved it from storage folder to root a:\ , after switching on my phone, it crashed. |
11-04-2004, 15:27 | #2185 (permalink) |
Freak Poster Join Date: May 2003 Location: Russia, Ekaterinburg Age: 44
Member: 29316 Status: Offline Thanks Meter: 0 | hm... starnge problems.... for inserting 5169.eep i use Siemens EEPROM tool last version. do you end all records in you ci.txt whith enter (and lastrecords too ?) if you use last version no need to swap bytes in CellID, for not have smo file turn off converting options in you DES program |
11-04-2004, 18:54 | #2186 (permalink) |
Member: 27936 Status: Offline Thanks Meter: 0 | to Deadmans yes, I do not swap bytes and I put the exact CI number in Netmonitor, and I press Enter after any record in my CI.txt. my CI.txt is like this: 898F Home 6D78 Office is there any problem? |
11-04-2004, 19:58 | #2188 (permalink) |
Member: 29316 Status: Offline Thanks Meter: 0 | hrfonouni: i don't understand what hapens in you fone ^( sorry , in my fone all work fine. try to see the memory from 80000h after boot you fone and write what you see in this memory, you whel see you ci.txt file if it's load fine deschek: try to change font |
SLIKv56: Flash patches. | arman68 | x4x, x5x Flashpatching | 685 | 10-02-2011 10:56 |
TOC for Sticky: SLIKv56: Flash patches. | StevieRay | x4x, x5x Flashpatching | 17 | 10-15-2005 08:26 |
"Bugs" in Thread SLIKv56: Flash patches | trustkill | Siemens-Benq Flash Patching | 2 | 07-13-2004 07:33 |
SLIK v56: Flash Patching (2nd part) ... | rizapn | x4x, x5x Flashpatching | 329 | 09-07-2003 10:28 |
Where can i download riza's SLIKv56: Flash Patching (3rd part) | Gabriel_he | Siemens-Benq Flash Patching | 2 | 04-04-2003 03:20 |
