11-15-2004, 19:53 | #2268 (permalink) |
Freak Poster Join Date: May 2003 Location: Tehran Age: 52
Member: 27936 Status: Offline Thanks Meter: 0 | @vBartek your patch "miniGPS v1.2" - supplement 1" collides with "More fix shortcuts v3.0" patch in these addresses: This is from MFS v3.0: 27D2E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 46FE55003D06DAC700D3DAC788EEFADA 27D2F0: FFFFFFFFFFFF 04DAFADA14DA and this is your miniGPS supplement: 27D2E0: FFFFFFFFFFFFFFFF 88C0D7403600F2FC 27D2E8: FFFFFFFFFFFFFFFF 6C099AFC033098C0 27D2F0: FFFFFFFFFFFFFFFF FAC700D398C0FAC7 |
11-15-2004, 21:53 | #2269 (permalink) |
No Life Poster Join Date: May 2003 Location: GERMANY Age: 49
Member: 27745 Status: Offline Thanks Meter: 0 | @ Selkth: Your patch "LWC. Light When Charging" collides with an older patch "CLST.Call List via GREEN button" CLST: 0x27DF90: FFFFFFFFFFFFFFFF 3700F3F2FF39F7F2 LWC: 0x27DF90: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 46F846012D0846F847012D0546F84801 |
11-16-2004, 09:07 | #2272 (permalink) | ||
Member: 27745 Status: Offline Thanks Meter: 0 | Quote:
11-17-2004, 10:56 | #2273 (permalink) |
Major Poster Join Date: Oct 2004 Age: 45
Member: 85188 Status: Offline Thanks Meter: 0 | about SOL3 and Big Digital Clock!? I have install graphical menu, and after install the SOL(and LOL and big digital style number), I can't find the application menu to set in IDLE the big digital clock? Maybe why I have graphical menu don't view the application menu? Where is the application menu to set in IDLE the big digital clock? Or have some other patch to set the big digital clock!? Thanx |
11-17-2004, 14:38 | #2274 (permalink) |
Freak Poster Join Date: Nov 2004 Location: Poland Age: 41
Member: 91303 Status: Offline Thanks Meter: 0 | When you've got graphical menu you must enter the settings menu. Ther you will find APP Menu. If you made your GFX Menu on yourown and skipped settings you will need to enter regular menu somehow and from there go to Settings. Here you've got two lines which are responsible for entering GFX menu by right softkey and right arrow: 3B0368: 3C 54 3B036E: 3C 54 If you applied both of them undo one, I don't remember which is which - experiment... I personally have got regular menu as one of the pictures in my GFX. This is the entrypoint responsible for running regular menu (ready to paste to the gfx code): DC42DB. I hope that you will find the answer in what I've written. Regards Froster |
11-17-2004, 21:36 | #2275 (permalink) |
Freak Poster Join Date: Jan 2003 Location: Croatia Age: 43
Member: 20219 Status: Offline Thanks Meter: 0 | Is possible that this patch shutdown my phone after call? Phone is shutdown when I reject with red button, or when other side stop waiting for my answer. Not for every call, sometimes after 10, 15 or 20.. call. When I undo this it work ok. Somebody here see a problem? Thanks ;*** ISK. Invert SoftKey Text Selectable *** ;Firmware : SL45v56 ;Author : RizaPN ;Release : November 8, 2003 ;Update : March 12, 2004 by rc-flitzer ;This patch will invert the soft key display, black text with ;white background ;Update: Patch now selectable through application menu via function 13. ;Please undo previous version. 0x27D6C0: FFFFFFFFFFFFFFFF D7400E00F2F1423A 0x27D6C8: FFFFFFFFFFFFFFFF 9AF102C0E0010D02 0x27D6D0: FFFFFFFFFFFFFFFF E6F16000DB00D740 0x27D6D8: FFFFFFFFFFFFFFFF 0E00F2FC423A9AFC 0x27D6E0: FFFFFFFFFFFFFFFF 01C0E007E6FC4000 0x27D6E8: FFFF DB00 0x20DFFE: E6F16000 DAC7C0D6 0x20E10A: 8870E6FC4000 DAC7D6D68870 0x27D6CB: c0 b0 ;fkt 13 to fkt 12 |
11-17-2004, 22:10 | #2276 (permalink) |
Member: 20219 Status: Offline Thanks Meter: 0 | I think that I ask before.. but again.. PLEASE I have this: ;****RAC-Record All Calls V3*** and that need this: Based on RizaPN entrypoint from VWC patch, so you need to install it. In this: ;*** VWC. (just another) Vibra When Connected *** is this line: ;Turn on vibra when the outgoing call is connected (only if Vibra flag is on). So, what I want? I want no vibra on incoming and outgoing call when I record calls! Can someone help? Thanks. |
11-18-2004, 11:55 | #2277 (permalink) |
Member: 91303 Status: Offline Thanks Meter: 0 | You need also this patch: Code: ; *** Modify MultiLine Indicator to become Vibra Indicator (with pic). ; **** Version 3 *** ;Firmware : SL45v56 ;Author : RizaPN, ValeraVi ;Release : April 10, 2003 ;Revision : Jun 15, 2003 ; You can select when to show the indicator: when vibra is OFF or ON ; ____________________ ; ValeraVi ; This patch will provide an ability to display firmware image no. 339 ;in the top screen for displaying a state of Vibra. Please modify the ;image (original image is like up-arrow) as you like. ; In this patch image is modified to picture with vibrating phone. ;patch 3B3708: DAA0AC1548402D08 D7400D00C2FD8924 3B3710: DAA0CA15F0C4DACB 5C1DD7400D00D4ED 3B3718: 38CA48402D0D0D05 9A2466FE100056FE ;3B3720: E0 00 ;display icon if Vibra is ON. 3B3720: E0 10 ;display icon if Vibra is OFF. 3B3721: 1CDACB38CA4840 00CC00CC00CC00 ;picture 4B22A4: 00501F00B01F01101F02081F05141F01101F01F01F 01000025E48049124025148049B24025548000E000 If you have already applied this patch you will only need to change the line responsible for displaying the icon. Regards Froster |
11-18-2004, 12:42 | #2278 (permalink) | |
Junior Member Join Date: Aug 2004
Member: 79994 Status: Offline Thanks Meter: 0 | Quote:
;*** VWC. (just another) Vibra When Connected *** ;Firmware : SL45v56 ;Author : rizapn ;Published : July 03, 2004 ;Turn on vibra when the outgoing call is connected (only if Vibra flag is on). 0x3AC4C8: F0C8F0D9 DAC7C0E6 0x3AC51C: F0C8F0D9 DAC7C4E6 0x27E6C0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF E03C0D0DD7403700F2FC043ACD0CDADE 0x27E6D0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF A6172D0988C0DAC36C0298C028C1D740 0x27E6E0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3700F6FC043AF0C8F0D9DB00FFFFFFFF ;if you want to change the number of vibration (my default is 3 times), use this: ;0x27E6C1: FF xC ; x is 0..F ;if you want to skip Vibra flag (always vibrate when connected), use this: ;0x27E6D3: 09 00 ;****RAC-Record All Calls V3*** ;Firmware : sl45v56 ;Author : DeadManS ;Created : August 14, 2004 ; ;Version Changes - v3 - No more need java midlet. Based on RizaPN entrypoint from ; VWC patch, so you need to install it. ;Uninstall any previos version of patch ; ;patch selectable trough Profile1/Function 14 3AC51C: DAC7C4E6 DAE060D2 02F56E: DAE66653 DAE08CD2 0040D260: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF D7400E00F2FC423A9AFC0DD0D7400300 0040D270: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FCFE048AFC07000FFCD7400300F6FC 0040D280: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FE04DAD414F3DAC7C4E6DB00D7400300 0040D290: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2FCFE040EFCD7400300F6FCFE04F0C8 0040D2A0: FFFFFFFFFFFF DAE66653DB00 | |
11-18-2004, 20:57 | #2280 (permalink) |
Member: 91303 Status: Offline Thanks Meter: 0 | But if you have "Record ALL Calls" patch my previous solution is just right for you. If you turn off vibra and in this way turn on the indicator you will enable RAC. So... I think that this is what you want. I don't know what to do else. |
SLIKv56: Flash patches. | arman68 | x4x, x5x Flashpatching | 685 | 10-02-2011 10:56 |
TOC for Sticky: SLIKv56: Flash patches. | StevieRay | x4x, x5x Flashpatching | 17 | 10-15-2005 08:26 |
"Bugs" in Thread SLIKv56: Flash patches | trustkill | Siemens-Benq Flash Patching | 2 | 07-13-2004 07:33 |
SLIK v56: Flash Patching (2nd part) ... | rizapn | x4x, x5x Flashpatching | 329 | 09-07-2003 10:28 |
Where can i download riza's SLIKv56: Flash Patching (3rd part) | Gabriel_he | Siemens-Benq Flash Patching | 2 | 04-04-2003 03:20 |
