Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #16 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2003 Location: Latvia, Riga Age: 35
Member: 20879 Status: Offline Thanks: 2
| I am happy with it.. No need to edit midlet patch ![]() But I have another request ![]() 1. I`d like to add in Records>>Calls Dialed>>Options>>Delete, or redo Delete all, so I can delete numbers one by one, not all at once ![]() 2. And I still need MORE GROUPS ![]() 3.Dear Riza or someone, ho undrstand, please check the entry point for: String 688:<95> Send Ringtone .... String 1173:<95> Minesweeper .... String 1175:<95> Labyrinth It is possible, than functions are disabled, like Net Monitor, I think It`s possible to turn it on Last edited by DjCook; 03-28-2003 at 22:46. |
| | #18 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2002 Location: -[r0]- Age: 42
Member: 9891 Status: Offline Thanks: 0
| @miriddin: To make it clear, yes, you need to reset the old patch if the new version of that patch is coming or there is another patch with very similar function. @ValeraVi: OK. Let me think about that profile functionality (no promise, but I'll try) @Rojer: I still remember that patch. But, there is some problem to finish that patch. I already know the entry-point of displaying name and number function, but I still have no idea how to move one of them to the next line, so they will displayed together. @pgiersz: No, I will not do that ... About "Screen Saver Midlet" patch: @gosicnarf, @vikado77 That patch use a normal midlet. So, all midlet running habbit is present. There is *NO* possibility (as far as I know) to combine midlet with some standard phone function, just like : accessing main menu, displaying text message, or using VoiceCommand throught the PTT button. If we want to have *ALL* normal function, then we can not use midlet as a screen saver, we have to use the firmware built-in function to create a new screen saver function. @ProjectZero: And about the midlet, if we want to use another button for exiting from midlet, we need to modify the midlet, not the patch. So, modify the midlet, or use another midlet, or ask about that midlet modification. @by_men: Are you sure that you can not receive a call? @DjCook: - I still try to find that Delete possibility. - More Group? Sorry (maybe somebody else want to provide this?)... - Thanks about that string index. Let me search ... RizaPN |
| | #20 (permalink) |
| Insert Timbre Options for MP3Player *** 41. Insert "Timbre" Options for MP3Player *** Firmware : SL45v56 Author : RizaPN Release : March 29, 2003 While MP3 Player is running, press button '8' will change the BASS setting, and press '0' will change the PITCH setting. 0x3BA196 : EA 00 C8 A3 -> FA C7 80 D4 0x27D480: FF FF FF FF FF FF FF FF -> 46 F1 30 00 3D 15 DA D0 0x27D488: FF FF FF FF FF FF FF FF -> CE 5C 2D 02 E0 0C 0D 01 0x27D490: FF FF FF FF FF FF FF FF -> E0 1C DA D0 98 5C DA D0 0x27D498: FF FF FF FF FF FF FF FF -> CE 5C 2D 03 E6 FD FE 03 0x27D4A0: FF FF FF FF FF FF FF FF -> 0D 02 E6 FD 83 06 E0 1C 0x27D4A8: FF FF FF FF FF FF FF FF -> DA E6 98 F1 FA DB C8 A3 0x27D4B0: FF FF FF FF FF FF FF FF -> 46 F1 38 00 3D FB DA D0 0x27D4B8: FF FF FF FF FF FF FF FF -> C2 5C 2D 02 E0 0C 0D 01 0x27D4C0: FF FF FF FF FF FF FF FF -> E0 1C DA D0 7A 5C DA D0 0x27D4C8: FF FF FF FF FF FF FF FF -> C2 5C 2D EB E6 FD FD 03 0x27D4D0: FF FF -> 0D EA ~~~~~~~~~~~~~~~~~~~ RizaPN |
| | #21 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Mar 2003 Location: Roma (Italy)
Member: 24322 Status: Offline Thanks: 3
| @RizaPN: Thanks for your help. I think the better midlet to use during keylock would be your clock midlet and, as you told us before and if you can, the best solution to the "PTT problem" can be mapping PTT command as "RPNClock EXIT command " in your midlet(if it could be done). Please,take this as a possible advice from someone with no midlet programming knowledge: i'm more than happy with your actual great job! ;o) |
| | #23 (permalink) |
| Junior Member ![]() ![]() Join Date: Mar 2003 Location: PolAnd
Member: 25513 Status: Offline Thanks: 0
| Sorry RizaPN ,When who call 4me the screen screensaver is turn off . But J have problem You say "Midlet format is same with the one used by "Midlet Shortcut" patch, but this patch use only "a:/java/s/x.jad" (real x.jad filename, no need to rename it) midlet caller." What is that X ?? The name of middlet is x.jad ?? Because if J have name x.jad its not working ... Can somebod make 4me *.vkp file with this patch ?? |
| | #24 (permalink) |
| And J have problem with This patch *** 41. Insert "Timbre" Options for MP3Player *** If J try insert this patch 4 my phone in V_Klay ,Program display " Line 9; Bad symbol after data " Where is problem ?? |
| | #25 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2001 Location: Czech Republic Age: 30
Member: 4514 Status: Offline Thanks: 0
| Quote:
(Surf-fun>Games) I have 6688>SL45i and i have it. | |
| | #28 (permalink) |
| @by_men You need to choice the midlet, then copy the midlet.jad file into the "S" directory and rename it"X.jad" NOw, edit the midlet jar url in the x.jad file to point to your choosen midlet location. |
| | #29 (permalink) |
| @ RizaPN: i can't apply the "Midlet as screensaver v03" patch because i have different data at the following ad*******: 0x3AD470 0x3AD478 As i have no problems with your v02 patch, i would like to know if is the possibility to use or not the patch by pressing the # key the only difference. Thanks for your help! |
| | #30 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2003 Location: London Age: 26
Member: 24408 Status: Offline Thanks: 0
| i'm aware of the *** Modify MP3 Player's Fast Forward to become Skip or Quit Function *** patch but it's no good for me as i want to be able to fast forward. i was just wondering if it's possbile to use the button on top of the volume buttons to skip to the next track. this will mean i can use it when the keypad is locked and still fast forward by holding the play button. as far as i know it has no function whilst in mp3 player mode and therefore is a "spare" button, ie no other function would be lost. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| SLIKv56: Flash patches. | arman68 | x4x, x5x Flashpatching | 685 | 10-02-2011 10:56 |
| TOC for Sticky: SLIKv56: Flash patches. | StevieRay | x4x, x5x Flashpatching | 17 | 10-15-2005 08:26 |
| "Bugs" in Thread SLIKv56: Flash patches | trustkill | Siemens-Benq Flash Patching | 2 | 07-13-2004 07:33 |
| SLIK v56: Flash Patching (2nd part) ... | rizapn | x4x, x5x Flashpatching | 329 | 09-07-2003 10:28 |
| Where can i download riza's SLIKv56: Flash Patching (3rd part) | Gabriel_he | Siemens-Benq Flash Patching | 2 | 04-04-2003 02:20 |
