03-03-2006, 18:17 | #16 (permalink) | ||
No Life Poster Join Date: May 2003 Location: GERMANY Age: 49
Member: 27745 Status: Offline Thanks Meter: 0 | Quote:
"Some Graphical Patches donst work" -> Thats right, but thats only because of PIT relocation. You can change the pictures via SPC2 (do not use SPC3 its very very buggy). Which Patches dont work, too ? Quote:
03-03-2006, 21:17 | #17 (permalink) | |||
No Life Poster Join Date: Mar 2004
Member: 60520 Status: Offline Thanks Meter: 0 | Quote:
So, question stays. Calling Images v3 still not works with Uni2. I know, it's just the line "4BB556:", but I don't know anything about pictures and PIT and such things. Maybe someone can tell how to put Calling Images into Uni2? | |||
03-03-2006, 23:18 | #18 (permalink) |
Member: 27745 Status: Offline Thanks Meter: 0 | Aren´t that details enough ? And, you can use animated images... But you are right, using some "older/other" patches together with UNI would be good. |
03-06-2006, 02:37 | #19 (permalink) | |
Junior Member Join Date: Jan 2006
Member: 219376 Status: Offline Thanks Meter: 0 | Quote:
ive had already undone ICDv2.2 together with Addon for usage wtih FAM3..coz when incoming call the phone automaticly shutdown i dont know to fix it.. someone can show me how to fix it and make an animation image caller for ICD v.2.2? | |
03-06-2006, 02:49 | #20 (permalink) | |
and i still wait some master can make Calling Images v3 works wtih UNI2..plus animation images maybe | |
03-06-2006, 13:22 | #21 (permalink) | |
There's still no solution for Calling Images v3 in Uni2 patch. And I said, I have no knowledge about picture moving and so on - if you know, please let me know, too. | |
03-06-2006, 14:44 | #22 (permalink) |
Member: 27745 Status: Offline Thanks Meter: 0 | No, you did not understand me. "Arent that details enough" -> I dont want to affront you, i mean 101x38 are enough details for ME. I dont need bigger images and dont have the knowledge to include CIv3 in UNI. |
03-07-2006, 05:20 | #23 (permalink) | |
03-07-2006, 14:09 | #25 (permalink) |
Member: 27745 Status: Offline Thanks Meter: 0 | OK. I tried ICD v2.2 in all details: 1st: It is possible to do bigger gfx than 101x38 ! Code: ;v2->no more conflict with java & use any height of image Animated Images can be done easy, "tutorial" is written in the patch description: Code: ;Maximum size of animated images is 3,646 bytes. ;It can be any number of images sequences with 101 pixel width. ;The images sequence is stored in a single BMP file, 1 images followed ;by the next in the vertical structure. Each part should have same height. ;After saving the images as a monochrome bitmap, you MUST edit this ;BMP file address (use any HexaEditor): ;0x0036: number_of_images (1 byte) ;0x0037: Y position of images in the incoming call screen And a HexEditor is "must have" for patchers like us :-) Also a perl-script for doing this is possible. |
03-08-2006, 02:34 | #26 (permalink) | |
07-27-2006, 08:16 | #27 (permalink) |
Junior Member Join Date: Nov 2005
Member: 196259 Status: Offline Thanks Meter: 0 | hi ! i'm a completly new with UNI2, and have some troubles, hope someone help me to solve I own a SL45i, Slik56, after applied serveral patches, my phone work great, but i heart about UNI2, a set of very useful patches, so i reflash my phone to original Slik56 with winswup from siemens and then activate Java. Follow the readme instruction in UNI2 0.64, i applied two first patch (1_ISS.vkp and 2_PIT.vkp ) with v_klay 3.3, no error found, and turn on the phone to UNI2 setup. But i can't find that UNI2 menu, the fone stay the same as before? Anyone can help me, tell me how can i install UNI2 to my SL45 with original firmware ver56? Thanks |
07-27-2006, 09:20 | #28 (permalink) | |
Major Poster Join Date: Jul 2004 Location: 2 x SL45 Age: 49
Member: 72073 Status: Offline Thanks Meter: 0 | Uni2 is on Menu/Device/UNI2 setup Don't forget to apply the uni2 language file (uni2_eng.lng) first! Quote:
@-:=:-:=:-:=:-:=warning for UST-PRO2 TEAM -:=:-:=:-=:-@ | nejm | UST Pro II | 5 | 01-26-2010 09:30 |
X6x Flash patching(THE Thread for discussing) : | zdob | x6x and x7x Flashpatching | 196 | 09-04-2006 19:12 |
..:!!! Important For Chinese Customers !!!:.. | Thunderstorm | ThunderStorm Box | 0 | 06-10-2005 11:05 |
