06-10-2004, 23:58 | #1 (permalink) |
Junior Member Join Date: Jun 2004 Age: 47
Member: 68376 Status: Offline Thanks Meter: 0 | TOC for Sticky: SLIKv56: Flash patches. I copied and pasted them all so everyone has an easier time to search through the sticky without having to go through each page. I create some sort of index and remove duplicates when I get the chance. Maybe even create a database so that similiar things / diff versions are collected together. Probability: very highly unlikely =) Anyways.. I hope this makes it easier for people to search for patches. Page 1 Create new shortcut for Inbox SMS (located on the SIM card) Create new shortcut for Outbox SMS (located on the SIM card) Eliminate the additional "_nnn_nnn" string when moving SMS to the archive folder Get access to "SIM Location" directly using front UP Arrow key Add "Send via IrDA ..." options in CardExplorer Overwrite "VoiceDialling" shortcut with "Display" shortcut Overwrite "VoiceDialling" shortcut with "Illumination Toggle" Use # short button to release the key-lock Use[*][GREEN] as an Illumination Toggle shortcut Disable "Do you want to copy all SIM Card content to the phonebook" message when change SIM Card Use[*] [0] and [#] followed by [GREEN] button as shortcuts Use LEFT Arrow key as a "SIM-Location" shortcut Use RIGHT Arrow key as a "Card-Explorer" shortcut Long press of left side [+] button for "Illumination Toggle" and its short press for IrDA Page 2 Overwrite selectable "User Group" shortcut/hotkey with "Archive" ADDITIONAL FIX SHORTCUT PATCHING SUMMARY 1) Use LEFT Arrow key as a "SIM-Location" shortcut : 2) Use RIGHT Arrow key as a "Card-Explorer" shortcut : 3) Modify 0[UpperRight] from "Select Line" to "Archive" : 4) Modify #[UpperRight] from "View New CB" to "Java" 5) Use * 0 and # followed by [GREEN] as another shortcut : Short # to unlock keypad, UP arrow and PTT button for VoiceDial when keypad is locked ADD NEW OPTION MENU FOR SL45 FW56 - > BAND SELECTION Short UP arrow to unlock keypad, and PTT button for VoiceDial when keypad is locked Turn off Aeroplane Check Toggling between SIM-Location and Addressbook when entering SMS Recipient No. Assign Any Ringtone to Any Phone Number Use Screen Style Images as a Screen Saver when Keypad is Locked Use only long press of # to unlock keypad Eliminate "Keylocked" message box when locking the keypad SLOW Animated Operator Logo when Keypad is locked Unhide Calendar Menu while Call in progress SLOW Animated Operator Logo v04 unlock mp3-auto-play with dobbleclick on the Play-button, when keypad is locked Unhide "Send Via IrDA" Options for JAR file Page 3 Make melody for earphone same with the normal speaker Hide SIM Application Menu Doing something else while playing MP3 Add Menu item under Voice Command More Fixed Shortcut Enabling NetMonitor Doing something else while playing MP3 (v02) Use SIM-Location for SMS while playing MP3 Modify MP3 Player's Fast Forward to become Skip or Quit Function Unhide Card-Explorer Menu for Phone without SIM Card RED Button Modification Assign a shortcut to concrete midlets Page 4 More shortcut, 0-9,#, and + followed by [RIGHT Arrow] for Midlet Access Assign a shortcut to concrete midlets - version 2 Left Arrow for SIM-Location (During Calls Mode) 39. Right Soft Key for SIM-Location (Saving Number) 40. Modify Characters for Filename Input 43. Using midlet for Screen Saver when Keylocked v03 41. Insert "Timbre" Options for MP3Player 42. Graphical Menu 50. Use Graphical Menu in the MP3 Player 51. #[RightSoft] as Vibra Toggle 52. 0[RightSoft] for Profile swapping (Normal/Quiet) 53. Modify MultiLine Indicator to become Vibra Indicator press of left side [+] button for "Profile-menu“ Set[*][RightSoft] for Profile swapping (Normal/Quiet) Page 5 the short alert when dialing in 50 seconds 54. Call Minutes Beep Modification Show an icon "home/office/mobile" on incoming call "Overwrite Menu mode and Help options inside configuration menu by Time/Charge and Divert" Show an icon "home/office/mobile" on incoming call - v3 56. Modify LeftSoft Key Text for More Shortcut Patch 63. Password for Functions Access Modify surf/fun menu options D03. Modify AT+CGSN Command to do Debug 55. Skip Addressbook for SMS Viewing v03 Advanced debugging with AT+CGSN Access to GFX menu instead normal menu during a call 69. Modify Date Display Format Page 6 Read New SMS While Key Locked Read New SMS, Missed Calls While Key Locked V02 66B. Selectable Operator Logo Allow Java midlets to access root folders 72. No Temporary Light After Key Unlocked v02 Read New SMS While Key Locked V03 Calling Images (Picture on an entering bell) V.1 Calling Images - V2a (stable) Disable Java-classes verification Selectable Operator Logo + default pictures. Version 4 Page 7 Modify MultiLine Indicator to become Vibra Indicator. Version 3 Show icon of current profile. Version 2; (extended customization possibility) Calling Images (Incoming call pictures) V3 Left-Arrow-Key for as a "Profile" shortcut Overwrite "VoiceDialling" shortcut with "Profile swapping" press of left side [+] button for "Profile Swapping" Overwrite "VoiceDialling" shortcut with "Inbox SMS" Overwrite "Conceal ID" shortcut with "Inbox SMS" Assign any ringtone to any number - v2 View time by green key on playing MP3 Display number on adjust volume Add more Timbre for MP3Player Assign any ringtone to any number + blacklist - v3 Assign any ringtone to any number + blacklist - v3a Pseudo Polyphonic Ringtones Instead Discreet View time by green key on playing MP3 v1.1 Fix a bug in some phones switching off in several midlet on click on messages directly goto SMS menu Page 8 invert display No Temporary Light After Key Unlocked v03 NOKIA_BATTERY_AND_NET_SYMBOL Prevent phone switching off on receiving SMS ***Modify playlist extension from *.mpl to *.m3u add support of Kingmax v02 and v03 MMC 74. Selectable Display Invert 73. Just Another Additional Display for MP3Player Mirror Screen Horizontally & Vertical Flip 75. Flash SMS Directly from the Phone Modify date on standby screen to be "DD,dd.mm." (No year) Unhide AddressBook for phone without SIM card Page 9 76. Just Another Funny Display ADD NEW OPTION MENU FOR SL45 FW56 - > BAND SELECTION 77. Modify Auto KeyLock Time-Out 78. Modify Battery Empty Warning Sound MPX. Skip and Exit button for MP3Player SOL. Selectable Operator Logo (New version) HBP. Hourly Beep ICF. Incoming Call Filter Images for Incoming Call Filter by RizaPN Set of patches (c) mamaich. Version 0.6 beta Correction - Show an icon "home/office/mobile" on incoming call v3 BSK. Blank Screen for KeyLock by long pressing # Button BSA. Blank Screen for Battery Saving v2 APP. New Setup->Application Menu for Patch Setting ISK. Invert Soft Key Text Page 10 BST. Blank Screen Test ICI. Incoming_Call_Images SOL. Selectable Operator Logo (New version) SOL. Little custom tricks Offline SMS - Archive AFA. Another_Function_of_Appointment LOL. Loadable_Operator_Logo Set of patches (c) mamaich. Version 0.7 beta APS+ALF Automatic Profile Swapping and Auto Backlight Function LOL. Loadable_Operator_Logo change call active sound BEW. Modify Battery Empty Warning Sound Do not allow to enter '112' in keylocked mode Page 11 no dialtone in silent mode DIG. Digital Clock when KeyLocked C45 Digital Clock sample pictures I have modified the CatClock patch so that it is compatible with the SOL(new version) patch from RizaPN. CLST. Call List via GREEN button MSC. More fixed Shortcut v2.0 JACT. Just Another CallingTime CLST. Call List via GREEN button SRB. SMS RED Button Redefinition MSM. More Shortcut for Midlet Access Midlets through entrypoints Page 12 SOL3. Selectable Operator Logo S3TC. Application Menu - SOL3 Text Correction SOL3˛ Selectable Operator Logo VDL. Voice Dial/Command Light CatClock for SOL3 - Nice work Riza ISK. Invert SoftKey Text Selectable CMB. Call Minutes Beep Modification v2 RWNSM. Read & Write New SMS in Mp3 These patch allow to record only outgoing calls Short press recod button start recording without promt, long press record button start ;playng last recorded message whith promt Starting midlet then new sim-card is installed in SL45 Start dictaphone recording at start of outgoing calling v0.2 Auto record Voice call Automatic recording for incoming & outgoing voice calls Page 13 Show both name & phone number at incoming call Drawing signal level in dB and battery level in mV No battery sound in silent or beep mode (like in S/M45) Turning on/off backlight while writing SMS Here's an update for the auto record patch. You have to apply it additionally to the previous patch. Voltage of battery in MP3 by Green button Date as Mo,12 Apr Round Softkeys v1 Round Softkeys v1 - other round corners Buttons Animation 'Menu' and left SoftKeys v 1.2 Patch combination: ; some actions during MP3 listening ; shows voltage of battery by pressing green button ; switches illumination by pressing record button Indicators: volume, bass, treble, clock and change bass and treble in MP3 and digital clock (on Info button) Mp3 while keylocked Automatic recording for incoming & outgoing voice calls v2.1 Page 14 Shutdown melody Eliminate message "New text message recieved" Round Softkeys v1 - selectable Autoredial with constant pause Compression of SMS, beta 2 Show both name & phone number at incoming call v2 Shows battery status in percent No sound on start of recording Change logon-sound Remove, center etc. Date & Clock Change logon-sound v2 Show current temperature instead of time Compression of SMS, final version Selectable Hourly Beep Page 15 Flip Screen switch hotkey SDS. SMS Delete Shortcut APO. Auto Power ON Improved Net Indicator for SL45 SVS. SMS View Shortcut Last edited by StevieRay; 06-12-2004 at 04:09. |
06-12-2004, 00:25 | #4 (permalink) |
No Life Poster Join Date: Mar 2002 Location: -[r0]- Age: 53
Member: 9891 Status: Offline Thanks Meter: 2 | Yes, TOC idea is very helpfull, but I think it is better to modify the 1st page of each Flash patch topics to become a TOC ones, rather than put another Sticky (there will be too many) for ... So, everybody who need to go to the specific patch, just need to check the 1st page and then get the correct link ... I will do it for some Sticky which was started by me ... rizapn |
06-12-2004, 01:08 | #5 (permalink) |
Junior Member Join Date: Feb 2004 Age: 41
Member: 52459 Status: Offline Thanks Meter: 1 | OH MY GOOOD!thx man.. if you put all these patches in to few pages, All of us will be very very very happy. cos while searcing for a patch i could be blind,i checked nearly 90 pages to find what is function 15. i hope we can see these pages soon.1000 of thx again ps: i saw some patches that i missed while looking, lets see |
06-12-2004, 01:16 | #7 (permalink) |
Member: 52459 Status: Offline Thanks Meter: 1 | To master Riza i wanna ask can we have the call logging patch soon? i know trustkill was masking this patch but,im not sure, maybe with your help.Also is it possible to write logs in sl45 into a txt file( like c55) i hardly need this patch(cos friends nagging my head like" I call you 20 times but you just did a ring" Of course because of my sl45 cant count how many times he call,just see who and when) thx |
06-30-2004, 07:14 | #9 (permalink) |
Member: 68376 Status: Offline Thanks Meter: 0 | Hmmm for some reason I am not given the privilege or access rights to modify my own posts???? I am wanting to add to my original post and add links to the actual pages. I'll put the links here for now but was hoping I could place them in original post Page 1 Page 2 Page 3 Page 4 Page 5 Page 6 Page 7 Page 8 Page 9 Page 10 Page 11 Page 12 Page 13 Page 14 Page 15 Page 16 Page 17 EDIT: I was able to edit this one but still no luck with original post???? |
08-12-2004, 05:54 | #11 (permalink) |
Member: 68376 Status: Offline Thanks Meter: 0 | Thx Trustkill. I might just start a new one up every few months or so. I still cannot edit my own posts. I have seen the threads re: New adminitrator And I saw the reply how they do not see why someone would want to edit a post that is older than 2 days =/ What are your thoughts? |
08-17-2004, 09:43 | #12 (permalink) |
Junior Member Join Date: May 2003
Member: 29824 Status: Offline Thanks Meter: 0 | RoadMap and more... The TOC is a GREAT idea.. One other idea (for my opinion) is a "roadmap of patches".. I see a lot of patches revised and impoved.. That is you have to undo the old patch in order to apply the new.. The roadmap may be like this ... ... [Patch xxx by aaa v.1]-> [Patch xxx by aaa v.2] .... [Patch uuu by bbb v.1].... .... .... of course the [xxxxxx] are links to the patches... Also, a big thing that is missed from the pathes is a patch memory map like this : |Address From - to | Comments | |------------------|------------------------------| |0x30000-0x30040 | used by xxx patch by YYYY | |0x30060-0x30090 | used by cccc patch by aaaa | I think this will help any future patch conflicts.. Regards Chris |
08-21-2004, 08:41 | #14 (permalink) |
Member: 68376 Status: Offline Thanks Meter: 0 | I could do that.... Take a lot of time though... Cross referencing will be a PAIN! Not inlcined v/ much due to lack of edit feature in forums. Any word on this yet? What I might do is create a new thread. Every week or so I shall just add post to thread for 12 weeks. After 12 weeks I shall re-create thread with all updates and links. I am off on holidays in a week for 2 months soooo...... this task is still up for anyone else interested. Just don;t expect anything from me while on holidays. =) |
08-21-2004, 16:03 | #15 (permalink) |
Freak Poster Join Date: Oct 2003
Member: 41707 Status: Offline Thanks Meter: 1 | I started (half a year ago) to organize all the patches in an SQL db. Then I created a php script to display all patches with tickboxes that displays all the patches that were ticked. However the db is quite old (and i cannot update it, we have OLYMPICS here in greece) Once i update it i will repost... |
SLIKv56: Flash patches. | arman68 | x4x, x5x Flashpatching | 685 | 10-02-2011 10:56 |
Here Correct method for unlock u700 flash patch | zakryia | UST Pro II | 36 | 05-14-2008 13:38 |
SLIKv56: Flash Patching (3rd part) ... | rizapn | x4x, x5x Flashpatching | 2900 | 12-24-2007 10:51 |
"Bugs" in Thread SLIKv56: Flash patches | trustkill | Siemens-Benq Flash Patching | 2 | 07-13-2004 07:33 |
Where can i download riza's SLIKv56: Flash Patching (3rd part) | Gabriel_he | Siemens-Benq Flash Patching | 2 | 04-04-2003 03:20 |
