Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > Siemens-Benq Flash Patching > x4x, x5x Flashpatching
Old 06-21-2005, 08:28   #1 (permalink)
Member: 151292
Two questions about the Firmware
1. Where is the firmware stored? on the MMC ?
2. When updating the firmware, the transfer speed is quite high. But when copying mp3s/etc in a normal manner the transfer speed is very low. Why is that? Can it be changed? firmware got updated (+3mb) in just a few minutes, whereas a 3mb song can take about 20 minutes.
Old 06-21-2005, 08:55   #2 (permalink)
Froster's Avatar
Member: 91303
1. Firmware is not on MMC it's in the flash memory of your phone. Try to take the MMC card out of your phone and it still works - that's the easiest justification of this fact.
2. It takes usually about 10-12 minutes to update full firmware in the phone so you probably just copied the file to the MMC card, am I right? To update you need to use V_Klay or Freia not just DES. In that case it is normal that the files are copied in such a low transfer because this is the COM port capability - it can copy more data per second. Well, there is of course a patch increasing the transfer but not much.
Regards
Froster
Old 06-21-2005, 09:14   #3 (permalink)
Member: 60520
Using a card reader for getting MP3 files onto MMC is best method.
Old 06-21-2005, 19:12   #4 (permalink)
Member: 151292
no Foster.. you have me wrong here. I didnt copied the firmware on the MMC. I have updated my firmware successfully, no problems at all. I just asked this question because when I took the Properties of all the files on the MMC, it showed that they aquire only 28 MB.. whereas the Data Exchange software and even the Card Explorer shows that the MMC is full. Now I recall that the firmware was of 3MB so I thought that firmware might be using the space. I wonder why my mobile is showing full space when all the files are taking only 28 mb.
rc-flitzer: would you please explain a bit more.. I didnt understand you properly.
Old 06-21-2005, 21:11   #5 (permalink)
Froster's Avatar
Member: 91303
OK, sorry
The same phenomenon can also be observed on your hard drive. Try to click on the properties of for example drive C and take a look how much space does Windows show. I've got a 20 GB drive and Windows shows it's got only 18.4 GB. The same ist in the phone. I have 128 MB MMC card and I've got 122,1 MB available. I's absolutely normal thing.
As far as rc's post, he mant taht there are card readers that are connected to USB ports and they have much larger transfer of data. Take a look at ebay for example and search for MMC readers.
Old 06-26-2005, 23:38   #6 (permalink)
Member: 93204
I suppose, that this problem depends of cluster size (besides producers' lies pointed out by Froster). The fact is, that the real size of ringtone is few bytes, whereas it blocks 512 or more bytes of space.
Old 06-27-2005, 11:55   #7 (permalink)
Member: 60520
About MMC sizes:
1) in most cases the manufacturer of the card gives size information in million bytes, so e.g. a 32MB card has 32 000 000 bytes. But in computer's scale, a megabyte is 1024 * 1024 = 1 048 576 Bytes. Therefore in Card explorer you'll only get the info "30.5 MB' free.
2) The file system also needs some bytes. It's FAT32, so I think it will use 500 to 1000 KByte
3) If you have already data on your MMC, each file needs at last 512 Bytes, depending on cluster size. Many small files like sms or ringtones therefore need more space than their original size is.
Old 06-27-2005, 20:08   #8 (permalink)
Member: 93204
Very good compilation, rc-flitzer, but file system is FAT16, not 32.
Two questions about 1100 and 3230 IvailoShopov Nokia Hardware & Hardware-Repair Area 1 09-26-2007 19:04
Two question about HWK.... fingusio HWK 4 04-20-2006 22:13
two questions about smart clip. .:bono:. Smart-Clip 8 11-15-2005 16:28
question about the latest firmware version? waleedy SYSOL Platform 1 09-13-2004 08:59
Page generated in 0.26921 seconds with 11 queries
