03-11-2003, 11:32 | #1 (permalink) |
Junior Member Join Date: Mar 2003
Member: 24058 Status: Offline Thanks Meter: 0 | Upgrade or repair a 6618/S45 (3318/ME45) to S45i if you have a C489 flash eeprom My phone and status till 11/03/03 : a siemens 6618 (the S45i chinese version) with C489 flash. Became dead after using sme45toolsV12 and a fubuS45i backup !!! Since 11/03/03 : works perfectly, happy to have the new game (they all suck ;-) ) and to be able to use french !! My problem came because SME45ToolsV12 can't be used with C489 Flash ! How to know that you have this flash or what kind of flash you have : - use ALL34 2.1.0 cracked version : connect your phone, select it in the controlbox (list of phone), dont check anything, just press 'init' and press briefly the power on button of your phone. ALL34 then gives you information like the type of flash !! easyyyyyyyyy Softwares that I used and comments : to repair I used plenty softwares like: (They all work fine only on win98 even if this MS-OS is very unstable and needs some DLL and the comctl32.OCX): - logger4.03: to read log -> good result but only COM1 works !! (delete the string ' version 4' on the first line with notepad) - map calculator (SPUNLOCKSIEMANSCALC.exe) : used to calculate MAP (still don't know if the map was good or not, see under) - Imei writer: used to write MAP created with map calculator (only COM1 works) : phone didn't work, still DEAD (maybe bad calculated map maybe bad soft) - all34 v209 by zak : used but was not part of my repairing process. it has not the function IMEI in this version, take the v2.10 if you want use ALL34 !! - ksie5.1: excellent. has read the log of logger403 and created a MAP and writed it in the phone : phone works after -> OK !!!! - unisiemens 4 with dongle emulator: good but with tricks - S45i_040101.EXE (winswup32): excellent ! it didnt care that i stopped all34 while it was writing, wrote the S45i v4 lg1 perfectly - S45iactivator (to patch): didnt work with 6618 - bytepatcher 1.1 ou 1.01 (dont remember): error - bytepatcher 1.0: patch the file perfectly with S45i V4 patch (included in the pack) - winhex: used to concatenate and then to split big bin files (you have to be registered) !! excellent but to split it is better to create a block and to write it to file (split function doesn't work well). Good method to follow (if your phone is OK and you want to upgrade OR if you want to repair): - Upgrade with phone OK : please note your EMEI number (with the phone enter *#06#) - you need a good battery or to have a friend with the same phone. I had a battery problem, Unisiemens stopped reading ... I used the siemens deskop charger for C45/S45/ME45 which contain a socket for a second battery, it saved my life). If you have a friend with the same phone it is better than to buy this charger like I did. - S45i_040101.EXE, used on Win XP (ok): skip pre test and post test, press red button briefly (power on) of the phone when winswup is scanning COM port - unisiemens 4 with dongle emulator: > could use dongle emulator only on win98, not on W2000 and XP !!! > copy initboot.bin and loadboot.bin of "S ME45" directory to "C30" directory and in the two change property (not read checked) > copy Vkeyprod.vxd and Stub.vxd from dongle emu subdirectory to "windows/system" > you have to use usimload.exe in the unisiemens directory to launch Unisiemens on any OS (but because you need W98 for dongle..) > I advise you to create for better use the necessary shortcut of - siemens emmulator.exe - usimload.exe - winhex > start siemens emmulator.exe, open and choose the only file, wait for a msgbox, press ok, then enable the emulator, let the program working in background (green LED in systray) > start usimload and wait (green led then Red then green again so now it works and you can move the mouse normally !!) > remove battery from phone, put it again (hope it is charged) > connect a none siemens cable (it is the same for any siemens before S55/C55 so you can find it for S25 easily) to the phone and to any COM port (works good on COM1 and 2) > select C30 phone, in flash frame start address 000000 size 200000 ! > press read flash, when scanning press briefly red button of the phone and wait 100% done and message 'ready' and save the file (call it "xxxx 2MB.bin") > start winhex and verify that you can find the string "9999:59:59" in the begining of the file but not right begining (mine was at the address 0x50 or 50h or offset 50) > remove battery from phone (yes again), put it again (hope it is charged) > select S ME45 phone, in flash frame start address 200000 size 400000 ! > press read flash, when scanning press briefly red button of the phone and wait 100% message 'ready' and save the file (call it "xxxx 4MB.bin") > you can backup them if you want !! > charge your battery again > start winhex and in the menu file manager choose 'concatenate' and follow the process easy (choose first 2MB and then 4Mb) and create a file called "xxxx 6MB.bin" > start bytepatcher 1.0, choose you 6MB bin file then the patch "S45i v4 fьr S,ME45 patch.txt" and then save the patched file (call it "xxxx 6MB patched") > start winhex and open this patched file > in winhex menu Edit->define a block. In msgbox: begining 0, end 1FFFFF, OK > winhex: ALT+N or Edit->copy block into new file (call it "xxxx 2MB patched.bin") > in winhex menu Edit->define a block. In msgbox: begining 200000, end 5FFFFF, OK > winhex: ALT+N or Edit->copy block into new file (call it "xxxx 4MB patched.bin") > remove battery from phone, put it again (hope it is charged) > unisiemens : select C30 phone, in flash frame start address 000000 size 200000 ! > open file "xxxx 2MB patched.bin" > press write flash, when scanning press briefly red button of the phone and wait 100% message ready > remove battery from phone, put it again (hope it is charged) (yes remove if you dont you could not write the 4MB bin file) > select S ME45 phone, in flash frame start address 200000 size 400000 ! > open file "xxxx 4MB patched.bin" > press write flash, when scanning press briefly red button of the phone and wait 100% message ready > that's finish for flashing !!! > now the MAP > start logger 4.03. in "port settings" choose your COM port and 115200 for the speed > logger 4.03: in "logger" choose S45 phone and read phone, press red button of the phone when opening or scanning the com port > logger 4.03 : enter the new IMEI (I hope you have it somewhere) (we doont care about the old one, you can let 0000...) > logger 4.03: save the log ("xxxx.log"). Open this file with notepad and remove the string " VERSION 4.." on the first line > start KSIE 5.1: Menu secuty->create MAP from Log (call it "xxxx.MAP") > KSIE 5.1: Menu secuty->write MAP to phone, press red phone button and wait !!! > Now you can detach your phone and power on it normally, your phone (C489 flash) is upgraded or repaired !!! > Hrushka (March 2003) with help of : - Tatiana, Grrrrrrr ;-p (translation from Russian to English) - http://www.o45m.ru./index.html?/sitemap.html : Dimitri solution for C489 plus lots of stuff on the site for siemens S/ME45 and others - a russian forum : http://forum.siemens-club.ru/viewboa...ardID=9&page=2 - a russian website with docs : http://www.gsmtricks.com.ua/S45.shtml - a good german website (s45iactivator and bytepatcher) : http://www.gsm-dev.com/ - an another german website (full of tools and update) : http://www.gsm-iq2000.com/index2.htm - a german forum (german but they reply to english question, very good, thank you Demm) : http://www.gsmfreeboard.com/http://w...freeboard.com/ - a bible site for siemens phone (flash, doc to repair, tools) : http://www.illegal_link.com/index2.html - GSM forum (excellent) : https://forum.gsmhosting.com/vbb/ - a very good french forum : http://vincka.zaphebergeur.net/phpBB2/index.php - you know what you want ? go here to direct directory : http://www.tongzweb.com/mobiles/siemens/ - All for zi S25 (really good) with cable till S45 : http://web.tiscali.it/no-redirect-ti...rminal_en.html - known and legal : http://www.club-siemens.net - henrich page : arg dont remember(easy to find) - good Polish website (tools) : http://www.axnet.pl/ramki/soft.htm Last edited by hrushka; 03-13-2003 at 00:02. |
04-15-2003, 13:56 | #2 (permalink) |
Junior Member Join Date: Apr 2003
Member: 26456 Status: Offline Thanks Meter: 0 | c489 flash upgrade to s45i Hi, I tried the step that u post to gsmhosting.com to upgrade my 6618 to become s45i. after i done all the procedure and power up the phone i just hear the "bzzzzzz" sound. and then i try re-flash the phone with siemens all3/4, that is no respond all !! what should i do now to recover my phone, the phone is totally dead. kindly help. thanks Rgds, C.H.Aw Yeong |
04-16-2003, 18:59 | #3 (permalink) | |
No Life Poster Join Date: Sep 2002 Location: Portugal
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | Re: c489 flash upgrade to s45i Quote:
It was all he needed. | |
How to Upgrade Or Downgrade 6131,6233 Ect.then Unlock With Bb5 Box. | alhajikoroma | BB5BOX | 2 | 04-08-2008 18:04 |
Who can help with full flash for S45i C489 (8Mb) original? | Chuk | x1x to x45/x50 | 0 | 11-15-2004 15:29 |
PLZ, help! Need fullflash Sie S45 C489 flash type | vetas | x1x to x45/x50 | 0 | 05-15-2004 10:16 |
I need 6618/S45 Lcds | Sinta | Wanted Products | 0 | 07-25-2003 13:26 |
Siemens 6618 (s45i C489 flash Type) dead | vlad48 | x1x to x45/x50 | 3 | 05-20-2003 00:50 |
