CF62T patching problem Can anyone help me please to patch cf62, its saying cannot create class in system or something similar to that, whre am i going wrong???? :confused: :confused: :confused: |
I am having the same problem |
In latest SW releases you can't make the java access to low level ... Sorry! |
remove t9 ball........ |
Can we have a diagram on how to remove this T9 ball? |
Yes... the CF62T is version 84- not patchable... Anyone want to help us with the solution? |
Well versions before 11 can be unlocked via java patch so I guess it is old x55/x60 CPU. That is why I wonder if the Martech adaptors work for the new versions like 11 and 84. Has anyone tested? |
where is the testpoint then??? |
Still Waiting For Sst,martech Or Griffin Team |
So do the Martech adaptors work for new versions of CF62??? |
Yes, i remove t9 ball and unlock phone with Griffin CRD - 100% work perfectly. And now possible to read fullflash or boot area 2Mb or eeprom without problem and make CF62 repair kit :) p.s.: cpu is old x60/x55 type |
what is t9 ball??? how can i remove! anyone has a picture??? regards |
@[Rod] You can count from CPU dot mark A, B, C ... ect counterclockwise (exclude I and O letters, because in parts signing there is not used to not mismatch with digits 1 and 0) and 1, 2, 3 ... ect - clockwise from dot mark. Numbering must be looked from top view, not from BGA pins side. Removing - easy - take out CPU, reball it, remove now ONLY T9 ball and put CPU back to PCB - he, he, heeeee - now you can play with your phone, without to think about boot protection. |
