x6x and x7x Flashpatching x6x and x7x Flashpatching (and newer phones). |
12-28-2005, 20:29 | #1 (permalink) |
Freak Poster Join Date: Mar 2003
Member: 25285 Status: Offline Thanks Meter: 0 | Compression of SMS does anybody of you think about adapt rc-flitzer "Compression of SMS" patch from sl45(v56), where is usefull, to x65 x75 series?? below you can see source code, description and example: ----------------- ; *** Compression of SMS, final version *** ; Firmware: SL45i v56 ; Author: rc-flitzer ; Release: May 24th, 2004 ; ! Uninstall the previous beta 2 patch if installed ! ; The patch should be more stable than beta 2 version. ; With this patch you can compress your SMS to save signs while the text ; is still readable. The text is replaced in that kind: ; "I invite you to my party. Will you come?" ; becomes to "IInviteYouToMyParty.WillYouCome?" ; So all spaces will be removed. ; You call the compression with the "---Help---" option from your options ; menu while writing SMS. Multiple calls are okay, the patch will then start ; at the first changed char since the last call. ; It's difficult to explain, just try it out. ; If the first character is a space, it won't be removed because of ; compatibility with the "Flash SMS" patch. 3A80CE: DAEBDEFF DAE090CC ; These two lines aren't tested yet. If you have problems with the patch, ; comment this short block (it's not neccassary, but runs faster) 390A70: DAD92263 DAE0B2CD 40CDB2: FFFFFFFFFFFFFFFFFFFFFFFF D7400600F6FC0002FAD92263 40CC90: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 88B088C088D088E08870886068C0D740 40CCA0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3500A87C46F725E02D0508C246FC0040 40CCB0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3DF60D78F0DC08D226FC1600D7403500 40CCC0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF A9FCE1BE27FF0B002D51F0ED6860D740 40CCD0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0600F2FB00022D1AE6FE0402D7400600 40CCE0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF A86ED7403500A8BD406B3D0608E208D2 40CCF0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 09E129F12D3B0DF2F0ED686046FB4100 40CD00: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 8D0C46FB5F002D0908610D07D7403500 40CD10: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF A8BD46FB20002D220D08D7403500A8BD 40CD20: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 46FB20003D02E0060D1E46FB41008D15 40CD30: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 46FB5F002D124860ED0A086146FB6100 40CD40: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 8D0D46FB7A00ED0A26FB20000D0746FB 40CD50: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 5A00ED0406FB20000D01E006D7403500 40CD60: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF B8BE08E209E108D229F13DD7D7403500 40CD70: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF B87CD7400600F6F7000206FC1800E6FE 40CD80: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 040227FE0B00D7403500A8BCD7400600 40CD90: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF B8BE08C208E229E13DF6E6FBFFFFD740 40CDA0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0600B8BE9860987098E098D098C098B0 40CDB0: FFFF DB00 |
backup of sms messages in N70 | ferhanz | Nokia Multimedia | 5 | 07-22-2010 10:32 |
SMS format of sms sent via SIM Operator Menu | ashokjp | GSM Programming & Reverse Engineering | 0 | 01-17-2009 12:54 |
Help with Recovery of SMS/ADN and Call Logs on Nokia 6310 | TriumphTT | UFS - Pro | 2 | 07-30-2007 14:04 |
Changing Storage area of sms from phone memory to MMC card | srivt | WD2 & APE (Symbian Phones) | 15 | 11-15-2006 19:23 |
Two Bugs in Compression of SMS, final | Pawel W | Siemens-Benq Flash Patching | 1 | 01-12-2005 11:03 |
