Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x6x and x7x Flashpatching
x6x and x7x Flashpatching x6x and x7x Flashpatching (and newer phones).
Old 08-19-2005, 13:34   #1 (permalink)
Member: 81726
s65 Bootcore patch
Hi mates !
I have a S65 and I have runned px65v3. S65 did a beep and went off which means that the patch runned succesfuly I suppose... The problem is that when I try to patch the phone with V_Klay 3.3 nothing happens. When it asks to press the red button, I press it but V_Klay doesn't recognize it...
Old 08-19-2005, 13:42   #2 (permalink)
Member: 172344
im not sure, but if you started px65 it should write OK, or something like that on your screen.
Greetings
Old 08-19-2005, 15:19   #3 (permalink)
Member: 81726
When I try to run px65 again it writes : " Bootcore already patched ". I have tried to patch one CX65 with V_Klay but the same problem ! I use DCA-510 but it is resoldered in some parts of its circuit because of some problems in the past... But it works fine with Software update or Papua Utilities or every other software which needs pressing the red button. Is it possible that the cable works fine with these progs but not with V_Klay ? I don't have another cable to test it...
Old 08-19-2005, 16:05   #4 (permalink)
Member: 172344
HI!
Which version of V_klay you have ?? Mayby thats a problem. Anyway, if i were you I would download driver that emulate COM port form USB and try then.
But i may be wrong.
Greetings
Old 08-19-2005, 16:10   #5 (permalink)
Member: 81726
V_Klay 3.3. I have installed the cable's drivers which attribute a virtual com port to the original USB port...
Old 08-19-2005, 16:22   #6 (permalink)
Member: 172344
hmm, thats wird.... I dont have a problem, cause i have COM DCA-500 and it dont make any problems.
Java bootcore patch don't work on M65v12. Any solution? bazmeg x6x and x7x Flashpatching 1 04-25-2005 13:27
MC60/C60/M55 unlock with Java and bootcore patch Falck x4x, x5x Flashpatching 15 09-28-2004 17:53
To mods: Could you guys make sticky the topic about bootcore patching on C/MC60, M55 SKAS_2002 E-Gold Based Phones 0 08-04-2004 09:09
m55 bootcore patch error @160 moonfighter E-Gold Based Phones 9 05-24-2004 10:23
Bootcore patch tested gsm2k2 x4x, x5x Flashpatching 2 05-07-2004 05:59
Page generated in 0.19165 seconds with 10 queries
