Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > Siemens-Benq Flash Patching > x6x and x7x Flashpatching
x6x and x7x Flashpatching x6x and x7x Flashpatching (and newer phones).
Old 01-05-2006, 18:52   #1 (permalink)
Member: 216352
Question Writing patches in C (using ADS or gcc)
Hello!
I recently decided to progress in C, as asm-code becomes too unreadable too soon...
I tried it with ADS 2.2.. It compiles, alright, but somehow I can't get the hang of it... How can I tell it to use my own base address (and not 0x0)? And how can I get the code out of this ELF-Binaries it produces? (And I don't want it to use any (.data...) segments beside the code-segment!)
Can somebody give me some hints or point out some (important) settings for me I have overlooked?
(I have in mind the x65 series with ARM926EJ-S (and I've set this). Further I've set ARM/Thumb Interworking and turned all options what to include in the .o binary off.
For linking, I tried "Simple" setting with RO-Base as 0x0800xxx my wanted base address (is that the right option to set?!) )
I am thankful for any hint how to use this (or the gcc) compiler properly for the ARM926EJ-S...
Thanks in advance
KKaul
PS: Even some russian links would help me atm...
Edit: I finally found "fromelf" that seems to do something like code-extraction from elf-binaries... So I've compiled miniGPS and compared with the bytecode I had... There's something going wrong.. its code is much longer (a0c bytes to 6f3), it does not use some instructions (although the cpu-type ist set to ARM926EJ-S..) and it uses some data-segments!
So I am doing something wrong....
need help in write rpl for 6021 using jaf jeffleesc Nokia Hardware & Hardware-Repair Area 0 07-09-2009 10:10
A707 after write patch file, show error... msantar NSPRO 2 03-23-2009 15:47
Are any people who write patches yet? GoLL@B x4x, x5x Flashpatching 3 08-02-2008 21:57
how to use patch in v1.4d 99026 Twisterflasher 4 02-17-2006 06:09
can't write flash in 3220 using UFS3 dj_mseal UFS2 + UFS3-Tornadoflasher 1 06-02-2005 07:08
Page generated in 1.87857 seconds with 11 queries
