Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens-Benq Flash Patching > x6x and x7x Flashpatching
x6x and x7x Flashpatching x6x and x7x Flashpatching (and newer phones).
Old 04-15-2005, 09:06   #1 (permalink)
Acidmrp's Avatar
Member: 15315
x65 patching technical discussion
Ok, I do the beginning. Please Post only technical articles here.
@Mod please make this sticky
File Handling
fopen
typedef int (*g_fopen)(const char * cFileName, unsigned int iFileFlags, unsigned int iFileMode, unsigned int *ErrorNumber);
g_fopen fopen = (g_fopen)(0xA1230050); // S65 FW47
// Pattern: FE402DE90270A0E10160A0E10350A0E10040A0E1????????0030E0E304308DE500508DE52CC090E5
fclose
typedef void (*g_fclose)(int FileHandler, unsigned int *ErrorNumber);
g_fclose fclose = (g_fclose)(0xA122FFA4); // S65 FW47
// Pattern: 38402DE90150A0E10040A0E1????????00C090E5
fflush
typedef void (*g_fflush)(int FileHandler, unsigned int *ErrorNumber);
g_fflush fflush = (g_fflush)(0xA122FFD4); // S65 FW47
// Pattern: 38402DE90150A0E10040A0E1????????08C090E5
lseek
typedef unsigned int (*g_lseek)(int FileHandler, unsigned int offset, unsigned int origin, unsigned int *ErrorNumber);
// g_lseek lseek = (g_lseek)(0xA1230004); // S65 FW47
// Pattern: FF412DE928509DE50280A0E10170A0E10360A0E10040A0E1
fread
typedef void (*g_fread)(int FileHandler, char *cBuffer, int iByteCount, unsigned int *ErrorNumber);
g_fread fread = (g_fread)(0xA1230090); // S65 FW47
// Pattern: FE402DE90270A0E10160A0E10350A0E10040A0E1????????0030E0E304308DE500508DE530C090E5
fwrite
typedef void (*g_fwrite)(int FileHandler, const char * cBuffer, int iByteCount, unsigned int *ErrorNumber);
g_fwrite fwrite = (g_fwrite)(0xA1230178); // S65 FW47
// Pattern: FE402DE90270A0E10160A0E10350A0E10040A0E1????????0030E0E304308DE500508DE55CC090E5
SetFileSize
typedef void (*g_SetFileSize)(int FileHandler, unsigned int iNewFileSize, unsigned int *ErrorNumber);
g_SetFileSize SetFileSize = (g_SetFileSize)(0xA12300D0); // S65 FW47
// Pattern: 7C402DE90160A0E10250A0E10040A0E1????????0030E0E300308DE544C090E5
Constants
Seek
#define S_SET 0
#define S_CUR 1
#define S_END 2
Permissions
#define P_WRITE 0x100
#define P_READ 0x80
Access
#define A_ReadOnly 0
#define A_WriteOnly 1
#define A_ReadWrite 2
#define A_NoShare 4
#define A_Append 8
#define A_Exclusive 0x10
#define A_MMCStream 0x20
#define A_Create 0x100
#define A_Truncate 0x200
#define A_FailCreateOnExist 0x400
#define A_FailOnReopen 0x800
#define A_TXT 0x4000
#define A_BIN  0x8000
Sample - File Read
	int iFileHandler
        unsigned int iError;
        unsigned int iFileSize;
        unsigned int iFilePos;
        char *cFileOutput = (char*)0xA8100000;
	// file read example:
	iFileHandler = fopen("0:\\test.bin\0", A_ReadOnly, P_READ, &iError);
	if (iFileHandler != -1) {
		// get the file size:
		iFileSize = lseek(iFileHandler, 0, S_END, &iError);
		if (iFileSize > 0) {
			// seek the beginning of the file:
		    iFilePos = lseek(iFileHandler, 0, S_SET, &iError);
	            // read complete file:
		   fread(iFileHandler, cFileOutput, iFileSize, &iError);
		// close the file
		fclose(iFileHandler, &iError);
	} else {
		// File not found
Sample - File Write
	int iFileHandler
	// create file if it does not exist:
	iFileHandler = fopen("0:\\outfile.txt\0", A_Create, P_WRITE, &iError);
	iFileHandler = fopen("0:\\outfile.txt\0", A_WriteOnly, P_WRITE, &iError);
		// search the end of the file
		// add an line
  		fwrite(iFileHandler, "new line\x0D\x0A", 10, &iError);
		// close the file
Old 04-18-2005, 14:45   #2 (permalink)
Member: 12407
i also collected some functiones in my databse here: http://d23.2chaos.de/index.php?page=...&lang=en&mid=2
i added acid's functions. they are so cool, thx acid
Old 04-20-2005, 15:17   #3 (permalink)
Member: 12407
@acid: i want to read a unicode text file. to make sure it is only loaded to ram once i want to check the first 2 bytes of the file (if it is unicode: first word in file is 0xFFFE). i did it like this:
if (iFileHandler != -1 && cFileOutput[0] != 0xFE && cFileOutput[1] != 0xFF) {
compiles with no problems, but when i test it on the phone it crashes. if i remove "&& cFileOutput[1] != 0xFF" it works. it doesn't seem to like "cFileOutput[1]". i also can't declare another pointer to ram in the function, even if i don't use the pointer the phone crashes. what did i do wrong? sexit code says Data_Abort! at address 0xA128D51C...
thx in advance
Old 04-21-2005, 06:49   #4 (permalink)
Member: 104514
Test it as follows:
if (iFileHandler != -1 && *(unsigned short*)cFileOutput != 0xFFFE) {
if memory need bound allign to WORD, it possibly crashes!
Old 04-21-2005, 07:55   #5 (permalink)
Member: 48709
Or something like that:
(*(unsigned long*)cFileOutput >> 16) != 0xFFFE
Old 04-21-2005, 08:56   #6 (permalink)
Member: 104514
why to right shift this DWORD? X65 is little-endian. so it Should be
(*(unsigned long*)cFileOutput & 0xFFFF) != 0xFFFE
Old 04-21-2005, 09:10   #7 (permalink)
Member: 12407
thanks guys! "&& *(unsigned short*)cFileOutput != 0xFFFE" works, but i can't increment the cFileOutput pointer, f.ex. "cFileOutput += 2;" or "cFileOutput[2]". should i use a const char* instead? i need to access the data that are copied to ram. compiles correctly, but phone crashes with Data_abort. maybe the compiler messes something up...
another way: does any of these functions return a pointer to the beginning of the file in FFS? single said it won't be fragmented for small files. then i won't have to copy it into ram...
Old 04-21-2005, 09:26   #8 (permalink)
Member: 48709
Oh, of course .
Old 04-21-2005, 09:52   #9 (permalink)
Member: 104514
You can read it into stack if It is a small file.
e.x
char buf[1024];
fread(iFileHandler, buf, iFileSize, &iError);
because i don't known something about X65 memory map, like some can access at 1-byte allign, another must be at 2-byte or 4-byte allign.
you should not access file skip system file process!
Old 04-21-2005, 14:12   #10 (permalink)
Acidmrp's Avatar
Member: 15315
yes, it's possible to access the files directly from file system, but it's no good
idea to do this. Because you can't write this file without implement an flasher.
And you don't know if the file is already opened.
Better use only 4 Bytes aligned Access if you want to be shure. Or even better, do
some tests what addesses can be accesses in what way.
Old 04-24-2005, 10:45   #11 (permalink)
Member: 12407
i didn't succed in reading files correctly, but i made an addition to at+cgsn:
void Binary(const char* str) {
	char buf[128];
	int iFileHandler;
	dword addr = strtoul(&str,8);
	char* paddr = (char *)addr;
	word blocks = strtoul(&str,4);
	sprintf(buf, "0:\\%08X.bin\0", addr);
	iFileHandler = fopen(buf, A_Create, P_WRITE, &iError);
	iFileHandler = fopen(buf, A_WriteOnly, P_WRITE, &iError);
		while (blocks != 0) {
			// add an line
			fwrite(iFileHandler, paddr, 0x400, &iError);
			paddr += 0x400;
			blocks--;
	// close the file
	sprintf(buf, "%08X.bin saved\r\n", addr);
	SendATAnswerStr(buf);
	return;
it can dump n x 0x400 bytes from ram. when i dump 0x400 * 0x400 bytes = 1MB, phone freezes for about 10 seconds. the maximum size that can be written by one fkb.write is 0xF00 = 60 any idea to make this faster and not freezing the phone? by the way how large is the RAM?
Old 04-25-2005, 05:28   #12 (permalink)
Acidmrp's Avatar
Member: 15315
I think it's hard to make the phone not freezing. Because you would have to write
an routine running in background and calling itself by an timer for example, if routine
is finished don't setup the timer at it's end.
The big problem: You want to do this in an AT Command. I don't know what the
phone will do if we just call SendATAnswerStr() while other AT Actions already
finished. Can we call this from any routine? Or do we need some Init?
Maybe use an AT Progress? (Sending some dots)
Do anyone know how to access the Display?
EDIT:
@arsh0r
do we really need this:
in every loop? I think the file pointer is increasing with the write routine.
Maybe this will make it little faster.
And the other thing: Why do you search the end of the file? It would be
better to search the start.
- create file if it don't exists
- open
- search start
- LOOP WRITE
because you are appending the data to an file if it already exists so we
don't have an exact memory map, because we don't know the old file size.
Old 04-25-2005, 22:31   #13 (permalink)
Member: 12407
dump ram to binary file
it works, at+cgsn:bA8000000 dumps 1 MB of RAM to binary file in less than 10secs. does anyone know how to write files to mmc, it'll be slower, but we can dump full 8MB ram to file on mmc? because my FFS is mostly occupied *g*.
but sadly SendATAnswerStr, can't send anything during this operation (output is 0A...)
@acid: you're right lseeking everytime is nonsense
Old 04-28-2005, 10:18   #14 (permalink)
Acidmrp's Avatar
Member: 15315
@arsh0r try to send status with this routine:
SendCommChar
typedef void (*g_SendCommChar)(unsigned char cChar);
g_SendCommChar SendCommChar = (g_SendCommChar)(0xA119E176 + 1); // S65 FW47
// Pattern: 01B568460121????????08BD10B5
I only have tested this routine with ATCGSN Debug but it should work in C too
Old 04-28-2005, 10:32   #15 (permalink)
Acidmrp's Avatar
Member: 15315
SendCommString
typedef void (*g_SendCommString)(unsigned char *cString);
g_SendCommString SendCommString =
(g_SendCommString)(0xA119DFA6 + 1); // S65 FW47
// Pattern: 10B5041C????????0106090E201C
BB5 - Technical Discussion adihack Nokia Base Band 5 ( BB-5 ) 220 10-14-2011 05:31
Iphone 3G Technical Discussion and SP Unlocking theory GraveSlayer iPhone 2 / iPhone 3G / iPhone 3GS 8 11-15-2008 06:04
Technical discussion sharp705sh celluniversal Sharp 0 05-17-2007 17:26
Technical discussion BB5 unlocking twisterfan Nokia Base Band 5 ( BB-5 ) 0 05-16-2007 19:36
Patching: Technical Discussion ... rizapn x4x, x5x Flashpatching 282 10-03-2006 19:23
Page generated in 0.24865 seconds with 10 queries
