x6x and x7x Flashpatching x6x and x7x Flashpatching (and newer phones). |
11-10-2004, 12:01 | #16 (permalink) |
Junior Member Join Date: Jul 2003 Age: 46
Member: 33749 Status: Offline Thanks Meter: 0 | ;CX65v25 1359928: 00 01 all patches in one www.asterix.com.ru Last edited by zdob; 11-11-2004 at 22:04. |
11-11-2004, 12:30 | #17 (permalink) |
Member: 33749 Status: Offline Thanks Meter: 0 | M65v25 ;* ** Open closed EEPRom blocks * © Skylord, § Grafic ;!6 blocks are opened 13590E4: 00 01 ;* ** Disk selection menu * © SiNge, § Grafic ;!at Card Explorer push 1 for second and get access to disk ;from Native Menu we can access to Developer menu by "#" 092A6B4: 0900000A 000055E3 092A710: 3534 2000 ;* ** Enable Developer Menu * © SiNgle, § Grafic ;!MUST BE OFF(S)Exit ;!this is for get Dev. Menu on HOT key 1334A51: 00 04 ;* ** Opened Discs Forever * © SiNgle, § Grafic 1359D94: 02 03 ;* ** Setup illumination by 2% * © SiNgle, § Grafic 089625A: 0A 02 ;02 or another digit at HEX 0896264: 0A 02 ;02 or another digit at HEX ;* ** Disable keypad light * © SiNgle, § Grafic 0B3A806: 01D5 0028 edited by zdob(deleting russian lang)!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Last edited by zdob; 11-11-2004 at 22:11. |
11-11-2004, 12:43 | #18 (permalink) |
Member: 33749 Status: Offline Thanks Meter: 0 | S65v25 ;* ** Open closed EEPRom blocks * © Skylord, § KiRiK ;!6 blocks are opened 1380B70: 00 01 ;* ** Disk selection menu * © SiNge, § Athlonfreak ;!В Card Explorer ...push 1 for second and get access to disk ;from Native Menu we can access to Developer menu by "#" 093BEE8: 0900000A 000055E3 093BF44: 3534 2000 ;* ** Enable Developer Menu * © SiNgle, § Athlonfreak ;!MUST BE OFF(S)Exit ;!this is for get Dev. Menu on HOT key 1352598: 0400 0804 ;* ** Opened Discs Forever * © SiNgle, § Athlonfreak 1381820: 02 03 ;* ** Setup illumination by 2% * © SiNgle, § Athlonfreak 0889C06: 0A 02 ;02 or another digit at HEX 0889C10: 0A 02 ;02 or another digit at HEX ;* ** Disable keypad light * © SiNgle, § Smelter by avkiev 0B6EDCB: D5 24 edited by zdob(deleting russian lang)!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Last edited by zdob; 11-11-2004 at 22:09. |
11-12-2004, 10:13 | #19 (permalink) |
Member: 33749 Status: Offline Thanks Meter: 0 | C65v25 ;* ** Open closed EEPRom blocks * © Skylord, § AsteriX ;!6 closed blocks are availible 12AECB8: 00 01 ;* ** Disk selection menu * © SiNge, § AsteriX ;!Push key 1 at Card Explorer menu and wait for 1 second and get access to dselection menu. ;from Native Menu we can access to Developer menu by pushing "#" 091ED14: 0900000A 000055E3 091ED70: 3534 2000 ;* ** Enable Developer Menu * © SiNgle, § AsteriX ;!THIS ITEM MUST BE OFF(S)Exit ;!Dev. Menu 'll be availible by hot keys: 1316D0D: 00 04 ;* ** Opened Discs Forever * © SiNgle, § AsteriX 1339EB8: 02 03 ;* ** Setup illumination by 2% * © SiNgle, § AsteriX 089432A: 0A 02 ;02 or random digit in HEX 0894334: 0A 02 ;02 or random digit in HEX ;* ** Disable keypad light * © SiNgle, § AsteriX 0B21ABA: 01D5 0124 ;edited and translated by zdob!!!! use english text only!!!!!!!!!! Last edited by zdob; 11-12-2004 at 23:56. |
11-14-2004, 13:01 | #20 (permalink) |
Freak Poster Join Date: May 2004 Age: 61
Member: 66180 Status: Offline Thanks Meter: 0 | SL65 Flash patching NO QUESTIONS HERE pure!!!(translated by anuroj_007) ;Open Disks Forever ;CX65v16 (C)SiNgle ;SL65v25 "Smelter" auto patch (C)avkiev 1358258: 02 03 ;Open EEPROM Blocks ;CX65v16 (C)Skylord ;SL65v25 (p)KiRiK 13575A8: 00 01 ;Enable Developer Menu ;CX65v16 (C)SiNgle ;SL65v25 (p)KiRiK ;thanks to Gley, bstallion and others 1335289: 00 04 ;Enable Disks & Hidden Folders Menu ;CX65v16 (C)SiNgle ;SL65v25 (p)KiRiK 092346C: 0900000A 000055E3 09234C8: 3534 2000 ;Disable Keypad Illumination ;CX65v16 (C)SiNgle ;SL65v25 "Smelter" auto patch (C)avkiev 0B33963: D5 24 ;Setup Illumination By 2% ;CX65v16 ฉSiNgle ;SL65v25 "Smelter" auto patch (C)avkiev 0897A72: 0A 02 0897A7C: 0A 02 |
11-14-2004, 16:33 | #21 (permalink) |
Insane Poster Join Date: May 2002 Age: 39
Member: 12407 Status: Offline Thanks Meter: 0 | How to find native (superfast) menu: author: arsh0r exapmle: S65v25 use sfe to find entry in softkey commands table: type: "sfe f s65v25.bin 43,4B,4C,4B,5F,43,4B,5F,4D,41,49,4E,4D,4E,55,00,,, ,A?" output: File s65v25.bin (pos=0x0,sz=0x2000000,rd=0x2000000) buffered FirmwareID: Unknown_v00-?-? (default memory mapping) 1. 0x8CADEC (3FF2:2DEC): 43 4B 4C 4B 5F 43 4B 5F 4D 41 49 4E 4D 4E 55 00 75 29 86 A0 752986A0 is the entry to the original menu (you can also change another entry f.ex. ELSE_MMENU_OPEN) now use sfe to find entrypoint of native menu type: sfe f s65v25.bin 14,05,00,00,0c,00,00,00,,,,a? this will give you someting like this: File s65v25.bin (pos=0x0,sz=0x2000000,rd=0x2000000) buffered FirmwareID: Unknown_v00-?-? (default memory mapping) 1. 0x8CE40C (3FF3:240C): 14 05 00 00 0C 00 00 00 F7 77 86 A0 use you hex editor to edit the 4 bytes after CKLK_CK_MAINMNU,0x00 to F77786A0(f.ex.) it should work for all x65 phones testet with s65v16/25 and cx65v16 here is the example patch for s65v25 8CADFC: 752986A0 F77786A0 |
11-24-2004, 21:31 | #24 (permalink) |
Junior Member Join Date: Jul 2004 Age: 36
Member: 72028 Status: Offline Thanks Meter: 0 | This is a patch for Siemens S65 FW25 to make % from 0 to 100 for Akku with standard gold from S65. only one pic is on german, pic 525 is with german text, but you can edit it with SPC3 beta7. a preview and the patch is at attach files. Greetz SPX |
11-28-2004, 23:08 | #25 (permalink) |
Member: 12407 Status: Offline Thanks Meter: 0 | ;kill some messageboxes ;S65v25 ;by arsh0r ;credits go to: SiNgle 08627CC: 5FF0 80BD ;vibra on/off 086285E: 5FF0 80BD ;irda on/off 086288E: 5FF0 80BD ;GPRS on/off 08628DA: 5FF0 80BD ;bluetooth on/off |
11-30-2004, 23:18 | #27 (permalink) |
Member: 12407 Status: Offline Thanks Meter: 0 | ;Goto mainmenu from anywhere by pressing ### ;goto devmenu->LOGAL->options and press Enable ### ;original CX65v25 (C)SiNgle 28.11.04 ;ported S65v25 by arsh0r 30.11.04 ;0B6E9E0: 39F021FF F3F4C8FF ;main menu 0B6E9E0: 39F021FF F8F409FF ;native menu ;PS: pretty tricky to make thumb long brach with link |
12-02-2004, 21:30 | #28 (permalink) |
Insane Poster Join Date: Dec 2004 Location: Moscow, Russia
Member: 95297 Status: Offline Thanks Meter: 0 | SL65v25 ;*** AutoRedial Forever With Selected Pause*** ;CX65v25 (c)SiNgle ;SL65v25 (p)KiRiK 0B3AE24: A068 0020 0B3AE4D: 30 20 0BB8318: 05 0A ;pause 10 secs ;***Disable Msg "Keypad Locked"*** ;CX65v25 (c)SiNgle ;SL65v25 (p)KiRiK 085A2C4: 0021 10BD ;***No Start Sound In Video Rec*** ;CX65v25 (c)SiNgle ;SL65v25 (p)KiRiK 08645A4: 19 1C ;***Disable Msg "Copy SIM" At SIM Change*** ;CX65v25 (c)SiNgle ;SL65v25 (p)KiRiK 0AA097A: 01 00 |
12-02-2004, 21:34 | #29 (permalink) |
Member: 95297 Status: Offline Thanks Meter: 0 | S65v25 ;*** AutoRedial Forever With Selected Pause*** ;CX65v25 (c)SiNgle ;S65v25 (p)KiRiK 0B80410: A068 0020 0B80439: 30 20 0BF0B08: 05 0A ;pause 10 secs ;***Disable Msg "Keypad Locked"*** ;CX65v25 (c)SiNgle ;S65v25 (p)KiRiK 0856734: 0021 10BD ;***No Start Sound In Video Rec*** ;CX65v25 (c)SiNgle ;S65v25 (p)KiRiK 0860948: 19 1C ;***Disable Msg "Copy SIM" At SIM Change*** ;CX65v25 (c)SiNgle ;S65v25 (p)KiRiK 0AC9FAE: 01 00 |
v707sc2 after flashing with new flash file... PATCHING PROBLEM... | ryumahon | UST Pro II | 8 | 03-26-2008 11:27 |
703 SH,stops on flashing 2nd patch flash | Ryuken | SETool2 | 0 | 04-13-2007 03:49 |
X6x Flash patching(THE Thread for discussing) : | zdob | x6x and x7x Flashpatching | 196 | 09-04-2006 19:12 |
***question to x6x flashing expert*** | infogsm | S-Gold Based Phones | 4 | 01-04-2006 03:17 |
Trying to download new x6x flashes | Uvedovle | UfoTools | 4 | 03-12-2005 22:00 |
