Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| x6x and x7x Flashpatching x6x and x7x Flashpatching (and newer phones). |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2000 Location: St Petersburg, Russia. Age: 33
Member: 2911 Status: Offline Thanks: 0
| X6x Flash patching(THE Thread for discussing) : This is thread for discussing about flash patching for siemens x6x. WBR Zdob |
| | #2 (permalink) |
| Junior Member Join Date: Jul 2004 Age: 31
Member: 74227 Status: Offline Thanks: 0
| hi im new. but pls tell me is the test point necessary for a c60 for it to be patched?can it be done without?what exactly does this testpoint and track cut do? |
| | #3 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2002
Member: 16638 Status: Offline Thanks: 0
| C60 increase flex memory Hi ! I was trying to patch C60 fw25 with more flex mem patch, but this not worked! Anyone know how to have this patch realy works? incflex3.vkp http://vi-soft.com.ua/forum/index.ph...d=2317&index=0 Some good translation from russian to english needed! Please help! |
| | #4 (permalink) |
| Junior Member ![]() ![]() Join Date: Feb 2001 Location: Hungary
Member: 3320 Status: Offline Thanks: 0
| where is any working patch for c60? example. debug patch? anyone knows the memory map? i tried discover the memory map from a full backup: 00.0000 - 1f.ffff 2048K firmware 20.0000 - 2b.ffff 768K FFS_B - b:\ 2c.0000 - 4f.ffff 2304K ??? code ??? 50.0000 - 6f.ffff 2048K FFS - a:\ 70.0000 - 7f.ffff 1024K not used 80.0000 - 87.ffff 512K RAM ??? 88.0000 - bf.ffff 3584K hole C0.0000 - f7.ffff 3584K ??? code ??? f8.0000 - fb.ffff 256K not used fc.0000 - ff.ffff 256K "eeprom" area i don't understand why sad some programs the firmware is 0x000000 - 0x200000 because i found codes on other locations like 0x2c0000 - 4fffff and on others see above... |
| | #6 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2003
Member: 41707 Status: Offline Thanks: 0
| I don't have a x60 mobile (i just run into this thread) Anyway in SL45 and i presume in all mobiles, java class verification is a process that actually verifies that the jar file contains a java midlet. If the jar file is a jre (pc) application, then the java class verification will not launch the midlet. Generally in Sl45 we disable java class verification, because it speeds up the loading proccess around 70%. However some midlets will not start without it. (This is because some java bytecodes must be changed by the javaclass verification routine before running) (an example of such a midlet is jubble bobble - must be something like this for x6x) |
| | #7 (permalink) |
| Junior Member Join Date: Aug 2004 Age: 34
Member: 80024 Status: Offline Thanks: 0
| which are the files in siemens phone? how many memory there are inside? how can i write all memories. i flash my c62 with different versions and "flash programmer" says "succesfully" every time but phone is still dead. i think i need to write files or memories inside the phone that now with flash programmer i'm not writing. many persons have problem like this and much of them loose patience on it...i'm on the way. help! |
| | #10 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2002 Location: Palestine Age: 46
Member: 9763 Status: Offline Thanks: 27
| Confirm switch on Hi guyes, Please, patching c60 flash file can cancel Confirm switch on ? I have problem with this left menu key ! Regards Laser |
| | #11 (permalink) |
| Junior Member ![]() ![]() Join Date: Sep 2002
Member: 15976 Status: Offline Thanks: 0
| Please darling post some simple Patch to enable Net Monitor in Cx65 series... I NEEEEEEEEEEED to Live Siemens! bob http://digilander.libero.it/m_50 |
| | #12 (permalink) |
| Junior Member Join Date: Oct 2004 Age: 33
Member: 85233 Status: Offline Thanks: 0
| I have been trying to upgrade my CX65 with winswup32 (160100_eng.exe) with my SIEMENS SERIAL cable, but I kept recieving the message: Error on waiting for Ack EOT Is there anyone who can suggest a solution to this? Thanx in advance lads... |
| | #13 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2002 Location: Flash Age: 33
Member: 11208 Status: Offline Thanks: 1
| Hi.I need patch that make more faster for deskey soft like sl45 patch by Mamaich. IS there anybody know c55,c60 communication transfer rate for file download,upload by Deskey soft by Siemens to pc? 56k or 115k? Is there exist any patch make it faster like Mamaich patch for sl45i? Thank you. |
| | #14 (permalink) |
| Crazy Poster ![]() ![]() ![]() Join Date: Oct 2004 Location: gouda, netherlands Age: 51
Member: 86176 Status: Offline Sonork: telecomwinkel@hotmail.com Thanks: 273
| MC60 Siemens I have a new MC 60 phone. I have Freija 15, and i cut de wire from the CPU. Now, my phone is stil unlocked and i can not use *0# anymore. what did i do wrong? |
| | #15 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2004 Location: Hamburg,Germany
Member: 79798 Status: Offline Sonork: 100.666 Thanks: 9
| Quote:
First phone must be full charge, second phone must be close and right side stand 2option and u must click them, than must be updated. www.gsmflasch.com | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| M55 flash patching(Thread for discussing) | zdob | x4x, x5x Flashpatching | 880 | 01-25-2010 04:37 |
| [SLIKv56]: Thread for UNI2 | trustkill | x4x, x5x Flashpatching | 36 | 04-04-2007 19:02 |
| S55 flash patching(Thread for discussing) | zdob | x4x, x5x Flashpatching | 347 | 12-09-2006 12:47 |
| SL55 flash patching (Thread for discussing) | 3aTmr | x4x, x5x Flashpatching | 29 | 03-21-2006 19:40 |
| Flash patches thread for SLIK56 can be found here..... | cyperghost | Board, Server and Login Problems/Support | 3 | 10-24-2005 18:01 |
