Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > VoDKA-CLIP
Old 02-15-2006, 03:57   #1 (permalink)
Member: 16494
Question Vodka and SE CID 36/37 etc ?
Hi guys...As Vodka only supports SonyErics CID 36/37 how am I able to tell which SonyErics are CID36 or CID 37 and same problem with Sharp's CID24 before trying to unlock them.....?
tks
Old 02-15-2006, 10:18   #2 (permalink)
garch's Avatar
Member: 138305
tks
Test is not destroing.
Old 02-15-2006, 13:39   #3 (permalink)
Member: 99524
Test is destroying in the case of the Ericsson, as you will have to reflash, due to flashing white screen as mentioned in previous posts, if you attempt to attempt to unlock any lower CID. If you have UFS then you can use that, but then u might as well unlock using that. SE Tool cracked could also provide this information i think.
Also there are some with a new flash chip which i have encountered problems with, which although CID 36 K700i, will not unlock with either, so have to use SE TOOL. Vodka Clip as far as i have tried does not unlock these models, but am sure an update will come at some point.
Hope this helps.
Old 02-15-2006, 17:13   #4 (permalink)
garch's Avatar
Member: 138305
Hope this helps.
As I said many ppl worked on ( me too, just for check ) on many k608i , made Unlock. Got error the ones with cid49 only the others was fully functional.
( For cid 36 k700 )
Why not with FuriousboX ?
Old 02-15-2006, 21:28   #5 (permalink)
Member: 16494
tks for info guys
I came unstuck using Vodka on non CID 36/37 K700i ended up with flashing white screen.
Vodka and SonyErics most disapointing then. Having to run SE Tools to find CID to discover if I can or can't use Vodka on the SE phone.
May as well use my USB Smart dongle+SEM Tool v6.3 to get a safe and positive unlock result.
And use Vodka for Lg's etc...
:-( To Vodka then
Old 02-16-2006, 12:07   #6 (permalink)
garch's Avatar
Member: 138305
tks for info guys
:-( To Vodka then
as Your choice ...
... stay tuned upgrades are coming soon .
Old 02-18-2006, 07:34   #7 (permalink)
Member: 64449
I have this problem with se k700. When i try to unlock it using vodka clip the device gives me an error directy after pressing the power button. When i use furiosu latest version i Get :
SE XTreme PLUG v1.3
**** UNLOCKING STARTED ****
Shortly press Power button!
Detected SonyEricsson:
K700/K300/J300/K500/S700/Z500.
Status Ok, OTP Close, CID36, PAF1
IMEI: 358413-00-028882
K700/K500/K300/J300 recognized!
CsLoader Accepted Ok!
System Initialization. Please Wait...
Getting data from server...
Connection ok! Data recieving...
Sign 1 ok.
Sign 2 ok.
Sending security data. Please wait...
Exiting test mode.
**** Stage Two Started! ****
**** Warning! Phone must be powered off during
unlocking process! ****
Execution Time - 00:02:27
Stopped!
I stopped the process because the phone powers on and there is no result. so the phones cannot be unlocked. I have this same thing with 4 phones now. Losing money buying sws-sag and now furious product do not want to work
Old 02-18-2006, 10:29   #8 (permalink)
shohag's Avatar
Member: 147116
Sonork: 100.1578260
flash cid 36/37 replec cid flash euro flash file work 100......................
Old 02-18-2006, 16:54   #9 (permalink)
Member: 99524
does that mean that this is the latest flash chip this guy is encountering? if so, as i suggested in previous posts, use SEMC cracked, as this will unlock without all the time invested in flashing etc.
Old 02-25-2006, 01:14   #10 (permalink)
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
SE XTreme PLUG v1.3
Sign 1 ok.
Sign 2 ok.
Exiting test mode.
Stopped!
Remove batt and put back beetwen stages and press after power on if needed.
How to upgrade se v600 cid 36 to cid 49?? svchost SETool2 0 03-02-2010 13:27
Convert CID 49 to CID 36 for SE K750i deboopi Cruiser Suite 13 11-28-2006 06:47
CID 37 to CID 36 RGUY Cruiser Suite 8 07-16-2006 22:44
K750i K300 SE CID 36 unlock clip now available unlockclips.com Main Sales Section 0 07-25-2005 22:30
SE CID-36 Unlock Clip (K750i, K300 etc) ttsunlock Main Sales Section 0 07-25-2005 16:22
Page generated in 0.31811 seconds with 11 queries
