Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Digital Core Technology 4 ( DCT-4 ) > WD2 & APE (Symbian Phones)
WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708.
Old 01-26-2010, 04:33   #1 (permalink)
Member: 1216995
3230 error flash
3230 error flash:
1st Boot Ok, WD2, UPP: 1081
Fl0: 0x00000000-0x01FFFFFF,00ECDDFE,Sam K8S5615ETA
Fl1: 0x02000000-0x03FFFFFF,00ECEEFE,Sam K8S5615ETB
Fl2: 0x04000000-0x047FFFFF,00EC2250,Sam K8S6415ETB
Algorithm: w3_amd_b.fia, Ver: 4.57.0
Algorithm Ok, MSID: 84F04A3384FC5AFBA423892033
Decoded MSID: 3E4EBAF7-008DAC49-A8000000
Encoded FAID: A58A5C50-C3FDFEE3-E9C9C932
Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00
Area2: 0x00010000-0x00FFFFFF Erased, Time: 01:50
Area3: 0x02000000-0x02A9FFFF Erased, Time: 01:15
Area4: 0x02FC0000-0x02FEFFFF Erased, Time: 00:01
Write Error: hDat 14, at: 0x00400000:08
Process Failed, Repowering Mobile
help my please...
Old 01-28-2010, 01:24   #2 (permalink)
mayor_NY's Avatar
Member: 1150643
Originally Posted by arifkrisnadi View Post
3230 error flash:
help my please...
try to check UPP and IC FLASH brother, reball or change.
The Following User Says Thank You to mayor_NY For This Useful Post:
Old 01-28-2010, 02:35   #3 (permalink)
Member: 975117
Sonork: rivacomcell center
Thumbs up 3230 error
hallo bro..panjenengan asli tiang yojo nggeh??salam kenal aj dari aku..dulu aku jga pernah hidup di jogja lama juga jd penduduk sana and sekarang aku udah comeback lagi ke kampung halaman tercinta..
oke..melihat posting mu aku tergerak ingin berbagi share pengalaman untuk sedikit membant problem yg sedang kamu hadapi..semoga share dari aku bisa menyelesaikan permasalahan yg ada saat ini.
oke aku mulai aja :
kasus gagal flash seperti pada info postingmu memang kerap terjadi pada o.s symbian tipe 7610, 3230, ngage, 3650 atau 3650..
tapi no problem and jangan kwatir..bisa diselesaikan dengan tahap :
1. software :
- box pake ufs hwk :
prosesny :
a. erase flash.
b. full flash.
kalo proses diatas masih gagal coba pake solusi ini
- box pake mxkey and ufs hwk :
prosesny :
a. pilih tab dct4
b. tab advance and pilih kotak get address maka akan muncl secara otomatis detail alamat ,dll lalu pilih kotak erase flash.
c. lalu fullflash seperti biasanya.
apabila dengan solusi diats udah oke maka baiknya disempurnakan dgn wr pm and ui setting..
2. hardware
- ganti ic flash data atau yg " Sam K8S6415ETB " usahakan ic yg baru jgn yg bekas supaya hasilnya suksesfull.
lalu coba diflash pasti 100000000% selesai kasus ini.
kalo masih juga bandell tetep pastikan ic flash yg diganti tsb pas waktu pasangnya atau reball ulang and flash lagi..
coba ya solutions tsb..jgn lupa postingkan hasilnya lagi ke aku kalo sukses
good luck..sugeng enjang
The Following User Says Thank You to Arief Wibowo For This Useful Post:
Old 01-28-2010, 03:05   #4 (permalink)
transpirit's Avatar
Member: 950964
brother try this set is hwk and only format with xtra slow speed if problem is still than flash with hwk
Old 01-28-2010, 03:12   #5 (permalink)
Member: 1220048
Sonork: dragon23456
sir
3230 error flash:
help my please...
try to flash a mxkey doungle..
3230 in flashing error pakmobiles WD2 & APE (Symbian Phones) 3 04-26-2010 04:18
3230 Mcu Flashing Ok-error During Ppm Erased-help zone2 Nokia Hardware & Hardware-Repair Area 2 12-04-2007 21:18
3230 write flash error (****URGENT****) arifraj WD2 & APE (Symbian Phones) 2 12-17-2006 08:29
error flashing 3230 tarikzone UFS2 + UFS3-Tornadoflasher 3 08-12-2006 16:35
Page generated in 0.25372 seconds with 11 queries
