Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708. |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2006 Location: Hafizabad, Pakistan
Member: 269126 Status: Offline Sonork: +923214273135 Thanks: 114
| 3230 hang at nokia seee log whts the problem hardware or software Powering the phone... Reading... MCU SW version: V 5.0717.0ch 04-05-07 RM-51 (c)NMP HW version: 0584 PCI version: UEM version: 144 UPP version: 4225 RFIC version: 0205 DSP version: B0439U_05w33 PPM version: V 5.0717.0ch 04-05-07 RM-51 (c)NMP.29 Production serial number: DNA772770 Product code: 0522253 Module code: 0202511 Basic production code: 0519957 Flash code: Order number: Product specific data: Long production SN: ATO: h????????????????????????????????????????????????? Default SN type: h????????????????????????????????????????????????? IMEI plain: 356664007808622 IMEI spare to net: 3A 65 66 04 70 08 68 02 IMEI SV to net: 33 65 66 04 70 08 68 12 F4 PDC: 4E 54 54 4A 50 12 34 56 Master Code: 5240063437 Phone type: RM-51, Software version: 5.0717.0ch, Language Pack: 29 User code: 12345 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-51.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0522253 Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-51\ Scanning for ini files... INI file 0522253.ini is missing. Continue searching for second ini type... Searching for default location of ini... Checking path: \Products\RM-51\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-51\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Done! |
| | #2 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2008 Location: KATROK CITY
Member: 771238 Status: Offline Sonork: 2366956789 Thanks: 32
| Quote:
Hope your problem will be solved. | |
| | #3 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2006
Member: 341279 Status: Offline Thanks: 1
| just use this command press all the keys the same time 3+*+send key+power key until it shows format on the screen of the phone. then relesace the keys allow it to finish format .your phone should work now. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| 3230 hang at nokia | malikasim | Nokia Hardware & Hardware-Repair Area | 9 | 05-10-2009 05:40 |
| 3230 hang at nokia | malikasim | Nokia Hardware & Hardware-Repair Area | 6 | 05-07-2009 05:50 |
| Nokia 3230 hangs on NOKIA | ajit bs | Nokia Hardware & Hardware-Repair Area | 7 | 08-24-2008 08:27 |
| nokia 3230 hang on nokia startap | binthabit | Nokia Hardware & Hardware-Repair Area | 9 | 07-23-2008 09:54 |
