Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Digital Core Technology 4 ( DCT-4 ) > WD2 & APE (Symbian Phones)
WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708.
Old 09-01-2006, 17:27   #1 (permalink)
mughalG's Avatar
Member: 315789
Thanks Meter: 3,428
3230 Hang on Start up and Shows Nokia Logo only
3230 came in dead position to me. I flashed it with UFS HWK Latest setup files with latest flash files RM51PE506140.1C and PPM as RM51PE506140.29. Phone now turned on but stays at Nokia Logo no more activity.
Then i flashed again by changing PPM to RM51PE506140.34 still same. I also tried Format user area after each time i flash it but still same
What to do now ?
Old 09-01-2006, 17:35   #2 (permalink)
imran_qasim's Avatar
Member: 133436
Sonork: 100.1577364
Thanks Meter: 191
Just Full Erase All Address manually, and flash again.
Everything Will Be Ook
Take Care
ENJOY
Old 09-01-2006, 19:50   #3 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,395
format it manually *+3+send+power
Old 09-02-2006, 08:58   #4 (permalink)
mughalG's Avatar
Member: 315789
Thanks Meter: 3,428
Tried this too earlier but nothing same result....
Old 09-02-2006, 09:01   #5 (permalink)
enzawigroup's Avatar
Member: 141363
Sonork: 100.1594362
Thanks Meter: 148
check the flash's ic or uem problem check the small flash ic re hot or try to change it
best regards.
Old 09-02-2006, 09:08   #6 (permalink)
dmaetrey's Avatar
Member: 315550
Thanks Meter: 110
it wont work with a reset.....erase the mcu+ppm...and flash it agen.....format it 3times....good luck..
Old 09-02-2006, 09:24   #7 (permalink)
Member: 141363
Sonork: 100.1594362
Thanks Meter: 148
best regards.
Old 09-02-2006, 10:08   #8 (permalink)
mughalG's Avatar
Member: 315789
Thanks Meter: 3,428
No luck brother... Still same
Old 12-21-2006, 06:33   #9 (permalink)
Member: 415588
bro i tried it but not working ihave a jaf please help
Old 12-22-2006, 11:26   #10 (permalink)
puneet14884's Avatar
Member: 399779
Thanks Meter: 125
Wink
donot loose hope bro just replace small black ic in front of batt connector known as boot or start up ic & then try format.........all fine 100%
Old 03-27-2007, 06:14   #11 (permalink)
aaneel's Avatar
Member: 156187
Thanks Meter: 17
please give me a photos please small black ic in front of batt connector
Old 03-27-2007, 23:29   #12 (permalink)
iqbal_zaro's Avatar
Member: 437024
Thanks Meter: 480
3230
try and also format manualy
The Following User Says Thank You to iqbal_zaro For This Useful Post:
Old 03-28-2007, 05:57   #13 (permalink)
.::koolfriend4u::.'s Avatar
Member: 200145
Sonork: 100.1596786
Thanks Meter: 677
Arrow
s in most case..if u tried every thng wth soft means...try to change tht boot i.c...mostly ur prblm wll b solvd.orelse problm n flash ic
Old 03-28-2007, 06:07   #14 (permalink)
Member: 248086
Thanks Meter: 22
try to format using 3 fingers *+3+green...
Old 03-30-2007, 11:32   #15 (permalink)
Member: 304395
Thanks Meter: 3
you!!! Formatting................100% ok!
Zetel N95y+ FM hanging on start up and shutdown RazoR888 SpiderMan 6 04-18-2010 12:26
c300 hang on start up.and please wait imran_bcz NSPRO 0 05-06-2008 19:55
LG U450 Hang on start up logo LG sof940 LG 0 02-16-2008 02:55
E310 hang on start up logo FMC_GSM Samsung Hardware Repair 5 09-09-2007 22:37
N-gage QD Hang on Start up and Shows Nokia Logo only Chinnapong WD2 & APE (Symbian Phones) 5 04-06-2007 12:17
Page generated in 0.25274 seconds with 10 queries
