-   WD2 & APE (Symbian Phones) (http://forum.gsmhosting.com/vbb/f348/)
-   -   3230 Hang on Start up and Shows Nokia Logo only (http://forum.gsmhosting.com/vbb/f348/3230-hang-start-up-shows-nokia-logo-only-329024/)
mughalG 09-01-2006 17:27
3230 came in dead position to me. I flashed it with UFS HWK Latest setup files with latest flash files RM51PE506140.1C and PPM as RM51PE506140.29. Phone now turned on but stays at Nokia Logo no more activity.
Then i flashed again by changing PPM to RM51PE506140.34 still same. I also tried Format user area after each time i flash it but still same
What to do now ? :confused:
imran_qasim 09-01-2006 17:35
Just Full Erase All Address manually, and flash again.
Everything Will Be Ook
Take Care
ENJOY
c_ahmad79 09-01-2006 19:50
format it manually *+3+send+power
mughalG 09-02-2006 08:58
Tried this too earlier but nothing same result....:confused:
enzawigroup 09-02-2006 09:01
check the flash's ic or uem problem check the small flash ic re hot or try to change it
best regards.
dmaetrey 09-02-2006 09:08
it wont work with a reset.....erase the mcu+ppm...and flash it agen.....format it 3times....good luck..
enzawigroup 09-02-2006 09:24
best regards.
mughalG 09-02-2006 10:08
No luck brother...:confused: Still same:confused: :confused:
issacraj 12-21-2006 05:33
bro i tried it but not working ihave a jaf please help
puneet14884 12-22-2006 10:26
donot loose hope bro just replace small black ic in front of batt connector known as boot or start up ic & then try format.........all fine 100%:)
aaneel 03-27-2007 06:14
please give me a photos please small black ic in front of batt connector
iqbal_zaro 03-27-2007 23:29
3230
1 Attachment(s)
try and also format manualy
.::koolfriend4u::. 03-28-2007 05:57
s in most case..if u tried every thng wth soft means...try to change tht boot i.c...mostly ur prblm wll b solvd.orelse problm n flash ic
elvislano 03-28-2007 06:07
try to format using 3 fingers *+3+green...
wutgsm 03-30-2007 11:32
you!!! Formatting................100% ok!
Page generated in 0.23883 seconds with 5 queries
