Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Digital Core Technology 4 ( DCT-4 ) > WD2 & APE (Symbian Phones)
WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708.
Old 04-03-2007, 08:50   #16 (permalink)
sandeephanda78's Avatar
Member: 330468
Sonork: 100.1587596
Thanks Meter: 121
i have 7610 when i power it on it shows start up failed contect provider i flash the phone with ufs but the set is in same position when i try to format it it shows format fails when i try to format it manuly it shows nothing pls if any body tell me the procedure to remove that
Old 05-07-2007, 15:53   #17 (permalink)
Member: 12724
Thanks Meter: 30
Originally Posted by wutgsm View Post
you!!! Formatting................100% ok!
Dont be sure!
many of this problems are hardware specially if nokia logo does not blink.
Old 05-07-2007, 15:55   #18 (permalink)
Member: 12724
Thanks Meter: 30
clicking on start new thread is too hard for you?
this thread is for 3230 hang on nokia.
Old 06-21-2007, 16:09   #19 (permalink)
Member: 521143
i have samsung c100 mobile which have hang problem, it hang once a day what's the problem please halp me
Old 06-21-2007, 17:22   #20 (permalink)
Member: 12724
Thanks Meter: 30
This is NOKIA section.This post is about 3230,It is about 3230 hang on startup.
Create your topic in samsung section.
Old 07-17-2007, 14:45   #21 (permalink)
Member: 183528
NOKIA 3230 hang
Hi, my nokia 3230 hang with a white light and NOKIA logo when I start.
After awhile the logo disappear.I can only switch it off by removing the battery. I tried without the mmc card still the same. I try to format by pressing the *+3+ green button still the same
Please help
Thank you
Old 09-16-2007, 16:57   #22 (permalink)
Member: 499081
Thanks Meter: 44
seems there is no solution yet for this problem.have 2 3230s with same problem.hope for solution soonest
Old 09-18-2007, 09:03   #23 (permalink)
Member: 344164
Thanks Meter: 22
near battrey connector right side there will small black ic change that one the set will be ok.
Old 09-18-2007, 09:40   #24 (permalink)
Member: 424047
Thanks Meter: 9
just re-flow the sram.........tested twice for nokia logo only!
Old 09-18-2007, 21:02   #25 (permalink)
Member: 34599
Thanks Meter: 11
Wink smps / zocus
change smps/zocus ic near from bat conector 1000% solution
i fix many 3230 problem like that
Old 10-20-2007, 10:32   #26 (permalink)
Member: 173261
Thanks Meter: 9
its 100% sw problem bro.
try flash it with higher versin. if not working try mcu files other than c1
like c3 , c4 .good luck
Old 10-20-2007, 16:28   #27 (permalink)
Member: 12724
Thanks Meter: 30
saying 100% means low experince.I can say if nokia logo does not blink,it is 99% hardware problem.change zocus.
also run self tests,if it is zocus CBUS will reply fail as result
Old 10-24-2007, 12:19   #28 (permalink)
Member: 86890
Thanks Meter: 9
am in support of alisajjad. flash the phone with an higher version and phone will work
Old 10-25-2007, 09:47   #29 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,321
format it manually *+3+send+power
The Following User Says Thank You to srinibas For This Useful Post:
Old 10-25-2007, 09:57   #30 (permalink)
Member: 515942
Thanks Meter: 29
Hang on Start up and Shows Nokia Logo only
erase flash and then write new flash file
Zetel N95y+ FM hanging on start up and shutdown RazoR888 SpiderMan 6 04-18-2010 12:26
c300 hang on start up.and please wait imran_bcz NSPRO 0 05-06-2008 19:55
LG U450 Hang on start up logo LG sof940 LG 0 02-16-2008 01:55
E310 hang on start up logo FMC_GSM Samsung Hardware Repair 5 09-09-2007 22:37
N-gage QD Hang on Start up and Shows Nokia Logo only Chinnapong WD2 & APE (Symbian Phones) 5 04-06-2007 12:17
Page generated in 0.43780 seconds with 9 queries
