3650 blinks white screen after flash with latest version hi guys, one of my 3650 had a four blinks problem which i flashed and then it stopped blinking and instead hangs on showing tha nokia at start up. i then had to download latest flash file 4.13.... and now it only shows a blinking white screen with no words of nokia, then goes off. i've tried to reflash with old flashes but the same error. please can any let me know what happened? |
Try flashing with a lower version , like any of the 2.series, it should work, most likely with the hanging nokia , this time format user area, till its ok,may be 3 or 4 times. |
after the flashin remove your mmc (memory card) from your phone and test it. mybe your memory card is damaged |
Try Format user area after flash. |
Hi same case with my 3650 white screen only after flashing and cant put in local mode so format user area is impossible. Any more suggestions? Tnx in advance.... |
try flash with a more lower version, if still unchange, there maybe something happend on your firmware, you should have a detail check. br |
used griffin and eraseflash then make full flash mcu-ppm-pm with old version..., everything will be ok |
only use from cceraseppm.fia in ppm flash and write ppm correct and unlock no need full flash best regard |
Damuho, White screen only,,means,,,some files are still missing....What box are u using???? |
tyr to format the use area three times |
i have two 3650 nokia one with camera not showing after snap, and the other one when you record with camera it doesnt record sound only image, pls somebody should help me out |
flashing with a lower version and Format user area then write pm then lint sim lock abd good luck |
U have to flash it with only mcu with every version u hav with whic version local mode comes slect that version ppm too n set will be ok 100 % its tested by me many times |
