Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > Nokia > Nokia Digital Core Technology 4 ( DCT-4 ) > WD2 & APE (Symbian Phones)
WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708.
Old 10-18-2004, 21:51   #1 (permalink)
Member: 54096
3650 questions
we have a 3650 that won't start up properly... your patience is appreciated.
problem: shows nokia logo, fades out, does this 3 or 4 times - can't say for sure since it's my friend's phone and he has it.
holding down the "pencil" key during power-on doesen't help either...
what we did : copied the contents of the FExplorer folder from the card's \system\apps\ folder on the root of the C drive
After searching the forum for a solution, we narrowed down the posibilities to 2:
- The so-called "4x blink" problem, since it matches this device's symtoms
however, it seemed to me that this problem is likely to show up after reflashing, which is not the case here.
or
- symbian's "bug" about needing space on the C drive to run, but allowing the user to fill this drive. (again i cannot say for sure how much space was free on the drive)
from what i read all that is needed is for the user area to be formatted.
of course this tends to become a problem since symbian 60 6.1 does not support the " * + 3 + call + pwr " method, and we can not use any code (the phone does not start).
We tried a service but they said that they have do do a full reflashing of the phone to "cure" this. (thus - i think - charging us more)
now the actual questions:
- is full reflashing really necessary? (as i said there was no reflahing involved in the first place)
- is there any other method of formatting the user area without the use of additional equipment (boxes, that is...)?
- can a cable be manufactured for this operation? (since ~250$ for a box on ebay does NOT look like a solution to me )
- can the 3650 use symbian 60 7? (i saw a post concerning this and i thought i'd give it a shot... although i don't quite see it happening )
Thank you for your patience.
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Share on FacebookTwitter
Old 10-23-2004, 02:43   #2 (permalink)
Member: 17337
first you can only format the set sometimes it works or you need to reflash your phone
second you have to by a box try to use some cheep flasher
third 3650 is not working with serious 60
Old 10-23-2004, 03:41   #3 (permalink)
Member: 20892
there's no way that you can format the user area without the box(Prodigy, Griffiin, Tornado, etc..).
it will surely cure the 4X blinks... tried and tested 100% working.
Old 10-25-2004, 13:32   #4 (permalink)
Member: 54096
well... we took it to a service, and now the 4x blink is cured... for good )
now it won't start at all. only shows coloured vertical lines on the display and then powers off. They told us that the flash chip is gone and needs replacing.
given the fact that we had a functional phone before copying those files, how likely is this to be the case? I am aware that the flash chip could have had too many program/erase cycles, but still (isn't this in the order of hundreds?)...
thank you.
Old 10-25-2004, 15:56   #5 (permalink)
hans0001's Avatar
Member: 84177
In my opinion,try software solutions first,don't touch d flash ic yet,i've experienced that many times.Sometimes PRODIGY can fix that,sometimes can't.Sometimes GRIFFIN can,sometimes can't.Sometimes Twister can,sometimes can't.
What box did they use,when they killed ur phone?I have these 3 boxes so i fix 4blinks 99%, only 1% hardware.So try to bring d phone to other repairer and make sure that they will use a different box...
good luck
Old 10-25-2004, 18:33   #6 (permalink)
Member: 54096
thanks. will try that
just in case we have to go looking for one of them chips, what flash chips are in the 3650? or some compatible devices, in case they need replacing...
Old 10-26-2004, 16:29   #7 (permalink)
hans0001's Avatar
Member: 84177
I'm not sure if there is any,same serial no. is the best!But do that only if there is no hope in software solutions.Bye...
good luck
Old 10-26-2004, 16:48   #8 (permalink)
Member: 66225
Old 10-26-2004, 17:09   #9 (permalink)
Member: 61810
Dont lose hope, a simple formating or even a lil erase file may solve your problem.
br..
GSMCity - GSM Hosting - 1999-2010
Page generated in 0.07082 seconds with 8 queries
