WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708. |
04-12-2005, 04:46 | #1 (permalink) |
Junior Member Join Date: Apr 2005 Location: singapore Age: 47
Member: 136309 Status: Offline Thanks Meter: 0 | 3660 Blank White / UEM Changed Also Still Not Work ! I have 3660 1st problem is after power on then the display is go blank white, and after 30 seconds or 1 minute it's power down. I've already flash it with UFS-3 / Griffin / Phoenix and erase all flash area and the last is I changed UEM, result still the same (White Blank LCD) - when i try to write rpl with ufs-3 there is no NOKIA shown at LCD (Can't set to Local Mode) so after write rpl, there is still no NOKIA shown...Somebody here has rpl file for 3660? because a friends told me to write rpl file for 3660 (they told me rpl file for 3650 different from 3660), but how can I write rpl, when the phone it self can't set to local mode ? Any body here can help? Tx B4 Best Regards, GS |
04-13-2005, 19:11 | #3 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Nowhere Age: 44
Member: 25067 Status: Offline Thanks Meter: 81 | i face this prob many times without solution and all phone i have (exacly 7) was water damage phone the last spare i didn't change is bt module and also try to look small glass ic near battery connector good luck... |
11-29-2005, 15:57 | #5 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: BANDA ACEH INDONESIA
Member: 74519 Status: Offline Thanks Meter: 79 | Quote:
Your problem is UPP, reheat/reball/change | |
09-18-2006, 19:31 | #10 (permalink) |
Freak Poster Join Date: Nov 2001 Location: Here Age: 44
Member: 7676 Status: Offline Thanks Meter: 4 | this an easy problim , you don`t need to change anything with your phone , just downgrade it to V.2.44 and it will work sure , i test it for 3 phone good luck |
10-15-2006, 10:49 | #11 (permalink) |
No Life Poster Join Date: Sep 2006 Age: 41
Member: 356202 Status: Offline Thanks Meter: 46 | [quote=gsm_shogun;1110270]Pls Help... I have 3660 1st problem is after power on then the display is go blank white, and after 30 seconds or 1 minute it's power down. I've already flash it with UFS-3 / Griffin / Phoenix and erase all flash area and the last is I changed UEM, result still the same (White Blank LCD) - when i try to write rpl with ufs-3 there is no NOKIA shown at LCD (Can't set to Local Mode) so after write rpl, there is still no NOKIA shown...Somebody here has rpl file for 3660? because a friends told me to write rpl file for 3660 (they told me rpl file for 3650 different from 3660), but how can I write rpl, when the phone it self can't set to local mode ? Any body here can help? Tx B4 Best Regards, i think the faulty is the rpl that you write in your phone..... ufs will write rpl even the phone is not in local mode... try to write this one...... this is 100% working rpl for 3660........ luck dude .................................................. .................................................. ................ |
11-07-2006, 10:29 | #14 (permalink) | |
Member: 7676 Status: Offline Thanks Meter: 4 | [QUOTE=GSM_BLUE;2036073] Quote:
Downgrade to an old virsion , that will help you ,,,,, | |
11-21-2006, 12:57 | #15 (permalink) |
Temporary banned !! Join Date: Nov 2006 Location: india
Member: 384332 Status: Offline Thanks Meter: 1 | please send me the 3650 version 2.44 my id is simonmanju_june [email protected] |
iphone 3g change digitizer still not work | nickvanexel | iPhone 4 / iPhone 4S | 9 | 02-05-2011 15:45 |
d900 bluetooth ic change, still not working.... Schematic please | dizzu | Samsung Hardware Repair | 3 | 10-08-2008 21:01 |
6070 menu key not work. change key ic but still not working | timopmass | Nokia Hardware & Hardware Repair | 5 | 08-10-2008 22:14 |
Unlock Nokia 1100b still not work | jan | Twisterflasher | 3 | 01-31-2004 22:29 |
CHECK THIS OUT!!! Nu2000 v1.11b still not working on 8250 v 3.12 | ed2k_7 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-26-2001 12:33 |
