WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708. |
11-12-2004, 12:35 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Location: ROMANIA Age: 46
Member: 55427 Status: Offline Thanks Meter: 7 | BlueTooth Problem on 6600 1st Boot Ok, WD2, UPP: 0082 Fl0: 0x00000000-0x007FFFFF,002088BE,St M28W640 Fl1: 0x02000000-0x027FFFFF,002088BE,St M28W640 Fl2: 0x04000000-0x047FFFFF,002088BE,St M28W640 Fl3: 0x06000000-0x067FFFFF,002088BE,St M28W640 Algorithm: w2_st_i.fia, w2_cbusb.fia Algorithm Ok, MSID: 84A45C75AC15AF242BB7E23AD4 Decoded MSID: 3E4EBAF7-004B7348-AA000000 Encoded FAID: 1110C6E1-C00E5E4D-DA59F2CE Area: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area: 0x00010000-0x007FFFFF Erased, Time: 02:02 Area: 0x04000000-0x046FFFFF Erased, Time: 01:50 Area: 0x06000000-0x066FFFFF Erased, Time: 01:47 Area: 0x047C0000-0x047EFFFF Erased, Time: 00:03 BT MCM (21) Image Found: 0x0002DD94 Write Error: Not Rdy, at: 0x000000DC Process Failed, Repowering Mobile So i retryed to flash skiping BlueTooth part and all was ok. But now Bluetooth doesn`t work anymore, because firmware was erased. I tryed to write many times but allways same error. How can i write bluetooth firmware. I mention that i use twister. 10x in advance |
11-12-2004, 14:19 | #2 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Tutuban Age: 68
Member: 10635 Status: Offline Thanks Meter: 10 | Hi, Pls check this thread for solution.. http://forum.gsmhosting.com/vbb/showthread.php?p=912256 BR, epic |
11-12-2004, 18:54 | #3 (permalink) | |
Member: 55427 Status: Offline Thanks Meter: 7 | Quote:
11-13-2004, 14:53 | #4 (permalink) |
Member: 10635 Status: Offline Thanks Meter: 10 | No, absolutely software problem only, well I have tried it ufs for days but i did not find the solution yet, maybe somebody might have done this and post here the step to do.. BR, epic |
11-14-2004, 11:46 | #7 (permalink) | |
To all, thanks for reply, no i didn`t try to flash back old firmware. I will try, and post results BR | |
11-14-2004, 19:44 | #8 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | i alredy solved problem with 2 phones ....only erase problem just erase flash with erase option on ufs...then try flash...new version 5.27 all ok..... |
11-15-2004, 14:07 | #9 (permalink) | |
Thanks B R | |
11-16-2004, 09:13 | #10 (permalink) |
Insane Poster Join Date: Nov 2004 Location: india Age: 42
Member: 89795 Status: Offline Thanks Meter: 0 | helo i have an 6600 it shows "application clossed" .first i format itthen not ok then i flash it ,while erase flash erassing it is ok,after that while flashing first boot ok 2nd boot ok,then shows c bus error in ufs pls give any solution |
How can i repair bluetooth problem on D500? | roniri | TST Dongle | 1 | 10-04-2005 06:55 |
3D Rally Pro Problem on 6600 | ruliza | Nokia Multimedia | 1 | 11-11-2004 02:06 |
Infrared and Bluetooth problem on GX30 | alekso | Sharp | 1 | 08-19-2004 16:10 |
Problem on 6600 | MicrostarGSM® | UFS2 + UFS3-Tornadoflasher | 24 | 03-29-2004 15:38 |
UltraMP3 Problem on 6600 | xms_nard | Nokia Multimedia | 6 | 03-08-2004 21:26 |
