Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Digital Core Technology 4 ( DCT-4 ) > WD2 & APE (Symbian Phones)
WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708.
Old 06-27-2006, 11:20   #1 (permalink)
Member: 18194
6600 BT problem
Hi, I have 6600 with detfective BT module and I don't have change pieces
So is it possible to make it access gallery & take photos w/o having to replace bt module ??
Help appreciated !
thanks.
Old 07-12-2006, 08:42   #2 (permalink)
Member: 43893
HI! sorry mate you cant get the files from your gallley, you need to replace your BT.
Old 07-12-2006, 11:01   #3 (permalink)
Member: 241641
that is right try to replace bt
thanks
Old 07-15-2006, 15:56   #4 (permalink)
Member: 226559
Solution 6600 bt repair
Dear Friend just connect with UFS then select WD2 THEN "CHECK" THEN click "RP BT" .after repair bt check bluetooth on hand set problem solved.
6600 bt problem %99 solution:) zeking82 Nokia Hardware & Hardware-Repair Area 11 09-10-2009 16:53
6600 bt problem Amit Tank WD2 & APE (Symbian Phones) 0 07-24-2007 15:00
6600 BT problem Changed No use...... sharaz191 Nokia Hardware & Hardware-Repair Area 8 02-24-2007 02:44
6600 BT problem lood Nokia Hardware & Hardware-Repair Area 3 06-27-2006 15:55
Page generated in 0.31927 seconds with 11 queries
