WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708. |
04-10-2004, 09:04 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 54
Member: 56617 Status: Offline Thanks Meter: 4 | 6600 dead after flashing with new 4.09.1 Sorry for stubid behav. but I hope everyone will not fall in the same hole like me till we have a solution. I flashed me 6600 ver 3.38 with the new flash 4.09.1 . I have selected these two files : NHL104091.C1 as mcu NHL104091.03 as ppm Is that OK. Because I need the arabic support but I'm not quite sure about them becuase griffin is not giving the lang back with ver 2.083 after that the mobile is dead completely. It is not detected, manually i try to flash again but this error is coming ErrCode:[13:00] or ErrorCode[13:FFFA300] Make sure phone is conntected and powered Where is my mistake or prob. ? Can u Help me please !!!!!!!!!!!!!!!!! Which mcu and ppm I have to select ?? |
04-10-2004, 09:46 | #3 (permalink) |
No Life Poster Join Date: Mar 2001 Location: Porto - Portugal
Member: 3769 Status: Offline Thanks Meter: 53 | I flashed yesterday with 4.0.9.1 firmware and it's working ok. I flashed with Griffin Gold Original and with Clone Prodigy using 6.15 Software. both of them working ok. Try to flash with option "set full factory default "UNchecked". BR |
04-10-2004, 09:47 | #4 (permalink) |
Member: 56617 Status: Offline Thanks Meter: 4 | they r saing about fia 3.7 where is that fia flash 3.7 please in another forums they told me about these fia flash . Do I have to delete thes 3 dir <flash> but where to download ? Thanks |
04-10-2004, 09:48 | #5 (permalink) |
Member: 3769 Status: Offline Thanks Meter: 53 | Install griffin gold suite V. 2.082 it comes with latest boot loader/flash loaders. You can find it on www.griffinteam.net BR |
04-10-2004, 10:16 | #6 (permalink) |
Member: 56617 Status: Offline Thanks Meter: 4 | OK i WILL Thanks alot I downloaded the newer version 2.84 today I have the new golden box setup I will setup golden setup then 2.82 then 2.84. ok Is that the way I have to go through? I hope I understod it. u know that i setup me 2.7 then setup golden setup 2.82 then upgrade with 2.83 and the problem hapened with me. may be i will retry agian but inthe afternoon Thnks again see u soon But can u just adjust me 4 these steps please Anan |
04-26-2004, 06:22 | #7 (permalink) |
Freak Poster Join Date: Jul 2003 Location: Egypt Age: 43
Member: 34847 Status: Offline Thanks Meter: 3 | I flashed 6600 today with 4.0.9.1 firmware and it's working ok I flashed with twister box working ok you must using anther cable may be the cable is damged !!! |
04-26-2004, 06:55 | #8 (permalink) |
No Life Poster Join Date: Apr 2000 Location: near you Age: 60
Member: 1196 Status: Offline Thanks Meter: 6 | yes 80% cables is bad ,,or try to clean batt contact on your Griffin (UFS)cable ,because phone need service contacts to put phone in local or test mode |
6600 dead after flashing with Griffin! | thedave | Griffin | 1 | 10-27-2005 05:46 |
BG3 dead after flashing with Lurker 4.0 | andreic | BF, BG, TH, BHx Series | 7 | 12-19-2003 23:28 |
