Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Digital Core Technology 4 ( DCT-4 ) > WD2 & APE (Symbian Phones)
WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708.
Old 11-25-2008, 19:37   #1 (permalink)
Harisk's Avatar
Member: 280222
6600 phone start-up failed.!
6600 some times show blue screen and show some errors. flashed the set and afer that it show "phone start-up failed. contact the retailer.". Erased the flash, fashed again wrote pm, but no use.
AY BODY PLEASE HELP!
Old 11-28-2008, 06:41   #2 (permalink)
kalindi's Avatar
Member: 549049
br reheat flesh ic & CPU THEN ERASE FLESH THEN CHECK.
Old 11-28-2008, 07:07   #3 (permalink)
Member: 768824
Sonork: m2black2k
erase file using 1,2,3,4 binfile. fullfash,write good pm,reset, format,,,,
Old 11-28-2008, 07:34   #4 (permalink)
amol_sm's Avatar
Member: 343326
Manually format the phone.
Post result.
Old 11-28-2008, 08:11   #5 (permalink)
Member: 751586
Sonork: 0858412346
erase before flash and flash success but not work u must change ic flash f11
Old 11-28-2008, 08:14   #6 (permalink)
venuno's Avatar
Member: 532761
Sonork: 100-1592994
erase flash the fone then flash it again w/other
version after flash write pm then
format 2x unlock if no luck
rehot black ic near battery terminal...
The Following User Says Thank You to venuno For This Useful Post:
Old 11-29-2008, 18:37   #7 (permalink)
Harisk's Avatar
Member: 280222
You are correct!
Post result.
I have already done it and the set found ok. So I gave t away.
I was in trouble because the customer brought the set in workng condition and the problem was memory card not working. While examining the set I found it hanging and once I notced the screen turned blue and display some error messages.
It was hence I flashed it. But after flashing the set did not start but displayed "Start up error, contact retailer"
After manual format st beame ok. I have aleady done it before you reply. Any way thank you.
The Following User Says Thank You to Harisk For This Useful Post:
6600 phone start up failed contact retailer danish_teli Nokia Hardware & Hardware-Repair Area 32 08-31-2012 15:23
6600 phone start up failed contect the retailer bharatg Nokia Hardware & Hardware-Repair Area 20 04-01-2008 11:19
6600 phone start up failed? gpong Nokia Hardware & Hardware-Repair Area 5 11-30-2006 02:47
Nokia 6600 - Phone Start-up Failed webmoly UFS2 + UFS3-Tornadoflasher 6 07-26-2004 08:14
Page generated in 0.57103 seconds with 11 queries
