WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708. |
11-25-2006, 11:59 | #1 (permalink) |
Junior Member Join Date: Nov 2006
Member: 398446 Status: Offline Thanks Meter: 1 | 6600 start up failure contact retailer |
11-25-2006, 23:11 | #5 (permalink) |
No Life Poster Join Date: May 2005 Location: Bulgaria Age: 49
Member: 142632 Status: Offline Sonork: 100.1589012 Thanks Meter: 459 | Format 6600 1. Make sure you have at least 3/4 charge of battery power left. 2. Backup your contacts list and personal files to MMC memory card. 3. Switch-off your 6600 phone. 4. Press and hold 3 keys; "Green" dial key, "*" Star key, no. "3" key on keypad and then press the power on/off to swtich on the 6600 phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 5. After a few minutes when the Full phone formatting completed, your 6600 will back to original system and factory settting |
12-17-2006, 09:37 | #8 (permalink) |
No Life Poster Join Date: Nov 2006 Location: guangzhou,CHINA & delhi,INDIA
Member: 399779 Status: Offline Thanks Meter: 125 | try format it by any means if not working then replace boot ic..........all fine |
The Following User Says Thank You to puneet14884 For This Useful Post: |
10-02-2007, 14:56 | #10 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Mobile solution at Pak_Lahore Age: 46
Member: 158032 Status: Offline Thanks Meter: 331 | If this mathod does not work then try to format with ufs just conect your phone and click on format user area tab after complet do init sim locks and all will be ok take care..... BR Omairbutt786 |
10-20-2007, 10:02 | #15 (permalink) | |
Junior Member Join Date: Aug 2005 Age: 42
Member: 173261 Status: Offline Thanks Meter: 9 | Quote:
then using PF or twister Use the " Format user area " button. if the problem presists then in off condition press the * , 3 , Send button hold these buttons and turn ur mobile phone ON . when see formatting on the LCD relese the buttons........... good luck | |
Nokia 3650 Start up failed.Contact retailer! | Dido76 | WD2 & APE (Symbian Phones) | 9 | 07-21-2013 11:49 |
6600 phone start up failed contact retailer | danish_teli | Nokia Hardware & Hardware Repair | 32 | 08-31-2012 15:23 |
Nokia N95 8Gb Start-up failure.Contact retailer | doodmt | Nokia Base Band 5 ( BB-5 ) | 3 | 10-21-2009 15:35 |
