Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708. |
| | #1 (permalink) |
| Junior Member ![]() ![]() Join Date: Apr 2006
Member: 261603 Status: Offline Thanks: 6
| 7610 Phone start-up failed & User Area Format Failed My 7610 is dead It show massage " Phone start failed. Contract the retailer." I use UFS to flash MCU & PPM ok but " User Area Format Failed 00000000: 01 01 E0 00 FF 2D 00 00 " and now it show " Phone start failed. Contract the retailer." How I can do? Help ma please BR. Thank you. |
| The Following 2 Users Say Thank You to agianmaker For This Useful Post: |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2001
Member: 4600 Status: Offline Thanks: 129
| Write erase flash and then mcu ppm and write good pm. If not solved. Change D462 flash ic. |
| The Following User Says Thank You to GSM RAJ For This Useful Post: |
| | #3 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2005 Location: Bangladesh Age: 30
Member: 117230 Status: Offline Thanks: 66
| Status: Online Here is a tutorial which i found on www.symbianforum.be and was posted by d3vil9 so i do not take any credit. Thanks to org poster, enjoy all. Its important to read through this topic before you proceed with formatting, you will need to charge your phone at least half full to enable a successful format. --- Soft Reset *#7780# : Restores ini files from rom but preserves user data (photos, 3rd party apps etc) - Hard Reset *#7370# : This reformats the C: drive completely and all applications and files stored on this drive will be lost. * --- With *#7370# and *#7780# the lock code will be asked before formatting the phone so be sure to remember your code, the DEFAULT CODE by nokia is 12345. * --- Firstly you might want to make a back up of all your important bookmarks, calender, notes and contacts, Using file manager go to c:/system/data find bookmarks.db for bookmarks, calendar for calendar, notepad.dat for notes, and Contacts.cdb for contacts. * --- Contacts can only be copied when phone is in offline mode/flight mode, use Psiloc System Tools for flight mode, not needed on 6630 or later. Or you can use Contact Manager app * --- Ok so 7650, 3650, 3660, ngage and ngage qd can only be formatted using *#7370# Before your format, be sure that the problem is on phone, remove mmc and see if problem still exists. * --- Also try starting in safe mode (press and hold pencil/abc key while turning on till op logo comes up). You can solve an apparent problem with simple solution --- 6260, 6600, 6620, 6670, 7610, 6630, 6680, n70 etc: Turn phone off, press and hold the green (talk) key on the left + number 3 on the keypad + the * key and then turn the phone back on. Keep pressed until phone boots up. * --- Fonts and Formatting. If you have any fonts installed be sure to remove them using Font Remover app or go to c/ or e/ system/ fonts/ and rename it to whatever and delete it now reboot phone before you attempt format. * --- and above all,this is very important,don't mess with file explorers (delete,rename,alter files) if you don't know what your doing. * --- and yes,formating phone (soft/hard) can screw some app's on mmc. Some will work fine,others don't coz they share files on both drives (c:/e: ) * --- OPERA - to copy opera bookmarks before formatting mmc, assuming opera is installed on e-drive. e/system/data/opera/bookmarks |
| The Following 3 Users Say Thank You to noor nobi For This Useful Post: |
| | #4 (permalink) |
| 6260, 6600, 6620, 6670, 7610, 6630, 6680, n70 etc: Turn phone off, press and hold the green (talk) key on the left + number 3 on the keypad + the * key and then turn the phone back on. Keep pressed until phone boots up 100% " Phone start failed. Contract the retailer." Go out, waite for insert sim |
| The Following 2 Users Say Thank You to noor nobi For This Useful Post: |
| | #5 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2005 Location: dhaka Bangladesh Age: 32
Member: 209955 Status: Offline Thanks: 4
| Quote:
It show massage " Phone start failed. Contract the retailer." I use UFS to flash MCU & PPM ok but " User Area Format Failed | |
| | #9 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2006 Location: Krishnagiri,Tamilnadu,INDIA Age: 33
Member: 265133 Status: Offline Thanks: 74
| 7610 start up failed i have a 7610 with start up failed problem i did manual erase but but it gets erasing error at third area and if i flash it it works for a day and then goes to blank screen |
| The Following 2 Users Say Thank You to murthyy For This Useful Post: |
| | #10 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2005 Location: CALIFORNIA Age: 33
Member: 141854 Status: Offline Thanks: 0
| F12 is problem,Replace F12 with new flash ic(SEC K8S415 ET),flash again,init simlock,format user area,after on your phone is contact the rathailer?? no problem!! can your manual format *# yes power on...and please wait |
| | #11 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2005 Age: 33
Member: 123458 Status: Offline Sonork: 100.1594535 Thanks: 3,736
| you must need to change its CPU and then flash it with latest flash file after flashing do UI Options and Format User Area every thing will be ok |
| | #12 (permalink) |
| Junior Member ![]() ![]() Join Date: Jan 2006 Location: morocco Age: 36
Member: 215295 Status: Offline Thanks: 13
| good solution from morocco listen , make a manual erase from adress 0287FFFF TO 02FC0000 Tfull flash then give a good pm ui settings init sim locks . if no ok then it's a hardware prolem , just reheat the uem and the ram . tested several times with most wd2 , but not the same erase address |
| The Following User Says Thank You to tarikzone For This Useful Post: |
| | #15 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2007 Location: Larkana Sindh Pakistan Age: 29
Member: 600691 Status: Offline Thanks: 9
| just format with hand no any other work *,3,sendbutton and power on formating i tested this forum many time |
| The Following User Says Thank You to asif khokhar For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| 7610 Phone start-up Failed. Contact the Retailer??? | byteforce | Griffin | 22 | 10-04-2011 15:26 |
| 7610 Phone Start-up Faild & All Time Restart Pls Help Me | gsm_khorshed | Nokia Hardware & Hardware-Repair Area | 9 | 11-19-2007 06:14 |
| 7610 user area format failed and dead phone | singapore | WD2 & APE (Symbian Phones) | 0 | 07-07-2005 07:48 |
| 7610 phone start up failed.contact the retailer | dogandbone | UFS2 + UFS3-Tornadoflasher | 5 | 11-15-2004 20:13 |
