WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708. |
06-04-2007, 08:59 | #1 (permalink) |
Junior Member Join Date: Jun 2007
Member: 521484 Status: Offline Thanks Meter: 0 | 7610 problem 1. How to download the address book from the phone and save other personal info if I need to replace the phone? 2. How to fix it? If I need to flash the phone, how do I flash it and where to get the software? 3. Why don't those keys work? I tried to figure out why keys don't work. Which pins, if more than 2, on the connector are responsible for the 3,6,9,#? I tried to do the buzz check with a voltmeter to find which pins are shorted when for example 3 is pressed; those 2 pins look ok. Manually shorting them with a wire doesn't produce a '3' on the screen either so it must be a bad/shorted connection elsewhere. Any suggestions how to troubleshoot this? I'm fairly new to the whole phone terminology and have no idea what jaf, etc are. I read some previous posts. Please do not assume I know anything. I'm very new to this. Thank you for your time. |
06-04-2007, 09:56 | #3 (permalink) |
Member: 521484 Status: Offline Thanks Meter: 0 | Hmm, I think I know which IC is the simcard IC, but where is the keypad IC? I downloaded the zip with pictures and only found the simcard IC (R310 is the simcard one right? Although prefix R should mean it's a resistor pack...weird) |
7610 problem with keypad | Junaid_UK | WD2 & APE (Symbian Phones) | 13 | 08-07-2006 10:17 |
7610 problem | toptro | Twisterflasher | 5 | 02-10-2005 20:29 |
Nokia 7610 Problem | mtech6928 | Nokia Hardware & Hardware Repair | 4 | 12-19-2004 14:07 |
7610 problem | Teflon Don | Nokia Multimedia | 5 | 10-11-2004 15:41 |
7610 Problem 4 Blinks !!! | Nizamo | WD2 & APE (Symbian Phones) | 10 | 08-03-2004 16:23 |
