WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708. |
07-19-2005, 07:57 | #1 (permalink) |
Freak Poster Join Date: Jun 2002 Location: North Pole
Member: 12869 Status: Offline Thanks Meter: 3 | 9300 no signal after imei change Any solution anyone pleaseeeeeeeeeeeeeeeeeeeeeee |
08-18-2005, 00:05 | #4 (permalink) | |
Junior Member Join Date: May 2005 Age: 48
Member: 145294 Status: Offline Thanks Meter: 0 | Quote:
09-07-2005, 07:35 | #6 (permalink) |
Insane Poster Join Date: Aug 2004 Location: Pakistan Age: 41
Member: 79502 Status: Offline Thanks Meter: 6 | 9300 prob solved by Tornado Series :) Nokia 9300 Imie Problem Sloved By Tornado -------------------------------------------------------------------------------- Hey Dudes I have Experinced On My Handset I changed the Imei from Dct4-Imei changer And After that Signal Gone i try to Dispatch Imei Its becum ok but No Signal : And u Must know ITs upto the Version if the Version is not same U can,t do all this So U Must have ALL the Version So u can upgrade Or Downgrade the Phone Versions Ummz , Just Flash with 4.53 version or From Downgrade version Follow As : Mcu Flash File: C:\Program Files\Nokia\Phoneix\Products\RAE6_h56pr3.060 PM Flash FIle :RAE6nxxxx.P01.pp Flash it THan Ui Settings Than Repair Bluee-Tooth ALL Ok This is a Twister-Ufs-3 & Tornado Procedure.. -------------------------------------------------------------------------- |
09-07-2005, 07:36 | #7 (permalink) |
Member: 79502 Status: Offline Thanks Meter: 6 | 9300 prob solved by J.A.F Series :) 9300 imei Problem solved By Jaf -------------------------------------------------------------------------------- Hey Dudes I have Experinced On My Handset I changed the Imei from Dct4-Imei changer And After that Signal Gone i try to Dispatch Imei Its becum ok but No Signal : And u Must know ITs upto the Version if the Version is not same U can,t do all this So U Must have ALL the Version So u can upgrade Or Downgrade the Phone Versions Ummz , Just Flash with 4.53 version or From Downgrade version Follow As : Mcu Flash File: C:\Program Files\Nokia\Phoneix\Products\RAE6_h56pr3.060. PPM Flash FIle: NONE Cnt Flash FIle: NOne ADSP Flash File:C:\Program Files\Nokia\Phoneix\Products\RAE6N4530.c01 Ape Variant File:C:\Program Files\Nokia\Phoneix\Products\RAE6n4530.L21 APE USer Flash:C:\Program Files\Nokia\Phoneix\Products\RAE-6\RAE6n4530.u21 (J.A.F --- Procedure ) |
09-07-2005, 07:46 | #8 (permalink) | |
Member: 79502 Status: Offline Thanks Meter: 6 | Here is ur 9300 Imei Problem Solved Quote:
-------------------------------------------------------------------------------- Nokia 9300 Imie Problem Sloved By Tornado -------------------------------------------------------------------------------- Hey Dudes I have Experinced On My Handset I changed the Imei from Dct4-Imei changer And After that Signal Gone i try to Dispatch Imei Its becum ok but No Signal : And u Must know ITs upto the Version if the Version is not same U can,t do all this So U Must have ALL the Version So u can upgrade Or Downgrade the Phone Versions Ummz , Just Flash with 4.53 version or From Downgrade version Follow As : Mcu Flash File: C:\Program Files\Nokia\Phoneix\Products\RAE6_h56pr3.060 PM Flash FIle :RAE6nxxxx.P01.pp Flash it THan Ui Settings Than Repair Bluee-Tooth ALL Ok This is a Twister-Ufs-3 & Tornado Pro | |
09-08-2005, 05:40 | #9 (permalink) |
Member: 12869 Status: Offline Thanks Meter: 3 | Are you saying that after I change imei I should flash the phone, using my tornado box with your procedure, 'cos that would mean the imei goes back to its original number and I don't want that. |
3100 no signal after RF change | dexs_ans | Nokia Hardware & Hardware Repair | 4 | 01-13-2009 18:41 |
no signal after IMEI patch????:( | amiriratel | MT-BOX | 8 | 06-26-2006 01:43 |
e600 no service after imei change? | gmx | SYSOL Platform | 2 | 02-09-2005 22:11 |
T610 showing NO ACCESS after IMEI change by Fighter | MC Harami | Sony Ericsson Hardware Repair | 1 | 09-03-2004 00:40 |
