WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708. |
07-10-2009, 16:05 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: shandar chock jelum pakistan
Member: 241661 Status: Offline Thanks Meter: 265 | All CDMA codes................... Samsung sph-n240, n400, a460, a500, etc Nam Programming: Nam Set: ##Spc Test Mode: 47*869#1235 Debug Menu: ##33284,ok Service Menu: Menu+8+0 (#889) Reset (Life time, Clear Memory, etc): ##786,ok A-key: ##2539,ok Label Selection: ##3882,ok Label(Home, Work, etc) : **523,ok NGG Setting (Gateway, etc.): ##2769737,ok Vocoder: ##8626337,ok CAI Change: ##7738,ok Enable TTY: ##889,ok Samsung sch-411, 611, n105, a100, a300, a2000, etc Nam Programming: Nam Set: 47*869#08#9 Nam Set: Menu+60 Test Mode: *759#813580 Test Mode: 5809540*45680 A-key: Menu+0, 25## External Audio: Menu+0, #### Debug Menu: Menu+8, 0415 or Spc Debug Menu: Menu+9, 0415 or Spc Brief NAM Programing: Menu+40,626 (not all version) LCD Contrast: Menu+45 (not all version) SIO Mode: Menu+49 SIO Mode: Menu+69 Samsung a300, a530, a610, a620, a660, a670, etc Nam Programming: Nam Set: Menu, 6, * Service Menu: Menu, 9, * Test Mode: 47*68#13580 Samsung X, E, V, S-series (korean), e250, v420, s250, etc Nam Programming: Nam Set: 6548#0**4#6 Nam Set: 47*869#08#9 Nam Set: 74153697193 Test Mode: 5809540*45680 (88 - efs clear) Debug Menu: Menu(hold 2sec)+0, 6725 or 9720 or 1973 or 0415 Debug Menu: Menu+0(hold 2sec), 6725 or 9720 or 1973 or 0415 Samsung N356 (India version) Nam Programming: Test Mode: Menu, 5, down arrow, * Test Mode: **00## (in some flashes) Samsung i700, etc Nam Programming: Nam Set: Go to start and select "PHONE" from the drop down menu, dial #83587 Samsung i300, etc Nam Programming: 1. Tap on the Phone Icon with stylus 2. Press #907*9#0 ENTER LOCK should appear on screen 3. Enter OTKSL 4. SVC MENU will appear press 1 5. Enter 10 digit MIN and then press SAVE 6. Press SAVE again 7. Press 3 and then press SAVE 6 times 8. Enter the HOME SID and press SAVE once 9. Press END key twice TEST MODE COMMANDS: n105_test_mode.txt a500_test_mode.txt a530_test_mode.txt <<KYOCERA>> -------------------------------------------------------------------------------- Qualcomm qcp-800 Nam Pogramming: Nam Set: Menu+3+0+Spc Field Test: Menu+7+0+Fsc Kyocera 1135, 2255, 3035, 5135, 6035, Se47, etc Nam Programming: Nam Set: 111111+Jog Dial(Ok), Select "Programming"+Spc CAI Change: ##7738,ok Enable TTY: ##889,ok Life Timer, PRL, etc: ##786,ok A-key: ##2539,ok A-key: 2539,ok Tips: On some kyocera handsets the factory service module has not been disabled and the phone can be programmed without the spc by inputting. Nam Set: ##333333 menu (service) <<SANYO>> -------------------------------------------------------------------------------- Sanyo 4900, 5150, 5300, 8100, etc Nam Programming: Nam Set: ##Spc+Ok+Key Down+Ok Advanced Setup: ##3282+Ok+Key Down+Ok+Msl A-key: ##2539+Ok+Key Down+Ok Version: ##**837+Ok+Key Down+Ok Debug Menu: ##FSC+Ok+Key Down+Ok Airtime menu: ##8463+Ok+Key Down+Ok Change CAI: ##7738+Ok+Key Down+Ok Vocoder: ##8626337+Ok+Key Down+Ok Reverse Logistic: ##786+Ok+Key Down+Ok Set IP Address: ##2769737+Ok+Key Down+Ok TTY On/Off: ##889+Ok+Key Down+Ok Ready Link: ##4636+Ok+Key Down+Ok Browser Init On/Off: ##4682+Ok+Key Down+Ok Picture Token: ##25327+Ok+Key Down+Ok Unknown Code: ##5282277+Ok+Key Down+Ok (SPC=000000, FSC=040793) Sanyo scp-A011, smp-A017, etc Nam Programming: Nam Set: F9(3 beep) + 0*72696#767 <<NOKIA>> -------------------------------------------------------------------------------- Nokia 3280, 3285, 3580, 3585, 5185, 6185, 8280, etc Nam Programming: Nam Set: *3001#12345# Software Version: *#837# Software Version: *#9999# Esn Number: *#92772689# Restart Phone: *#75681# Restart Phone: *#75682# Nokia 8887 Nam Programming: Nam Set: *3001#12345# Version: *#0000# Evrc: *#8378# Esn/Data/Timer: *#92772689# SID: *#743# Nokia 8587 Nam Programming: Nam Set: *#626#7764726# A-Key: #8159357022#4579# (26 digits) A-Key: #8159357022#4547# (20 digits) Version: *#0000# Version: *#837# Vocoder: *#3872# Change language: Menu 5, 3, 1 Change DM mode: *#7678# Debug Screen: *#8378# Debug: *#8380# Field Test Menu: *#83788# SPC Unlock, Factory Reset: Full Factory Reset: *#7370# Resets all settings including non-user changeable items (like SPC) NOKIA TEST MODE: 51xx, 61xx, 71xx, 3285, 63xx, etc: 1) Turn on the phone. Press *3001#12345# 2) Scroll up to where it says "Field Test" and choose SELECT 3) Highlight "Enable" and choose OK. Turn the phone off then back on. 4) If the test mode screen does not show up press MENU and scroll down to "Field Test" choose SELECT. Press 0 1 then choose OK. 5) Lower left or upper left number is the signal strength. 6) To turn off the test mode press MENU and scroll down to where it says "Field Test" choose SELECT. Press 0 0 and then choose OK. 3360, 6360: 1) Turn on the phone. Press *3001#12345# 2) Scroll up to where it says "Field Test" and choose SELECT 3) Highlight "Enable" and choose OK. Turn the phone off then back on. 4) If the test mode screen does not show up press MENU and scroll down to "Field Test" choose SELECT. Press 2 1 0 1 then choose OK. 5) Lower left or upper left number is the signal strength. 6) To turn off the test mode press MENU and scroll down to where it says "Field Test" choose SELECT. Press 2 1 0 0 and then choose OK. <<AUDIOVOX>> -------------------------------------------------------------------------------- Audiovox 4000, 9000, 9100, 9155, 9500, etc Nam Programming: (Power the phone on and wait until the little light on top goes out) Nam Set: 289+fcn+#+1 Service menu: fcn+00+fsc(000000) Test Mode: Hold (2,*,Rcl)+Power Test Mode Commands: 99 - download - flash phone 124 - inam data write 125 - version 126 - esn read 127 - sec_code 128 - lock_code 129 - is WFTV data write 137 - FSC code 138 - NPcode (nam program code) 139 - dscode 141 - restart 218 - Read_Addr 000 - is cdma mode 001 - is fm mode 002 - is pcs mode 008 - is reg read addr 020 - is lna_range Audiovox pcx-3500xl Nam Programming: Nam Set: ##2726+Send+1998+1+Spc+1 Audiovox cdm-100, 130, 135, 8300, 8500, 8600, etc Nam Programming: Nam Set: ##20022002+Pwr+1+Spc Audiovox 8610, 8910, etc Nam programming: Name Set: ##847446, end, 111111 Audiovox-107 Nam Programming: Nam Set: 45680*47*869#1 Audiovox CMP-3 Nam Programming: Nam Set: 45680*47*869#1 Dm Mode: Menu, 6, 6 Audiovox 9950 Nam Programming: Nam Set: ##3282 Audiovox Z800 (Audiovox 7900, Sharp) Nam Programming: Nam Set: m + # + envelope key + * + 1 Audiovox Thera (Toshiba 2032) Nam Programming: Thera Nam Programming User Manual - nam_thera.pdf AUDIOVOX TEST MODE: 9100, 9155: 1) Turn on the phone. As soon the phone comes on and the green light turns off press RIGHTARROW, 0, 0. The phone will ask for the "FSC Code", press 000000 then choose OK and press RIGHTARROW, RIGHTARROW. Your phone is now in test mode. 2) The signal strength is the number on the top right hand side of the screen. 3) To turn off test mode shut of the phone and then turn it back on. <<MOTOROLA>> -------------------------------------------------------------------------------- Motorola 7760, 7860, 2260, 8160, etc Nam Programming: Nam Set: Fcn,0000000000000, Rcl Nam Set: 74663#, Fcn, Fcn Test Mode: Fcn, 00**83786633, Sto Motorola v60c, v120c etc Nam Programming: Nam Set: 74663#, Menu, Menu, Spc Nam Set: Menu, 073887, * (type quickly) Test Mode: Menu, 073887*, Spc Debug Mode: ##33284 Force the phone into DIGITAL ONLY mode: 1) ##33284 (Debug) 2) RIGHT Softkey (Next) Twice 3) Down arrow 10 times to "PrefMod" 4) RIGHT Softkey (Change) until you see "DigOnly" 5) LEFT softkey (Exit) 6) MENU then LEFT Softkey return to idle screen 7) ##33284 (The last 4 will not display if you have done it correctly) Motorola t182, c210, etc Nam Programming: Nam Set: ##1111 end Nam Set: ##298645665 end Short Nam: ##073887 sto Motorola v710, v730, v740, ms150, etc Nam Programming: Nam Set: 8378*# + press 3 times NATE (spc - 071082) Test Mode: Menu, 073887*, Spc Service Menu: #758353266#646# Motorola StarTac 2004 Nam Programming: Nam Set: 5759789*#, rec key (3)times (spc - 915037) Motorola ms200, ms230, etc Nam Programming: Nam Set: 5759789*# (spc - 915037) Motorola v6060 Nam Programming: Nam Set:147*369#456*0# MOTOROLA TEST MODE: v60, c120, c331, etc: 1) Turn on the phone. Press MENU 0 7 3 8 8 7 * 2) The phone will require you to "Enter a Security Code", press 000000, OK 3) Scroll down to "Test mode" choose SELECT. Scroll down to "Enable" choose SELECT. Your phone is now in test mode. 4) Signal strength is the 3_rd number down on the left hand side of the screen. 5) To toggle between regular mode and test mode: Press MODE then quickly press the BUTTON DIRECTLY TO THE LEFT OF MENU. 6) To turn off the test mode the phone must be in regular mode, then follow the above sequence and scroll down to where it says "DISABLE" instead of "ENABLE" and choose select. Motorola Bible - bible.txt <<LG>> -------------------------------------------------------------------------------- lgc-300, etc Nam Programming: Nam Set: Menu, 9, Spc A-key: Press "Sto" 3sec, 2539** lgc-330w, etc Nam Programming: Nam Set: Menu, 4, 0, Spc A-key: 2539** lgc-510, v111, etc Nam Programming: Nam Set: Menu, 3, 0, Spc A-key: 2539** lgc-500, 800w, etc Nam Programming: Nam Set: Menu, 9 , 0, Spc Debug Mode: Menu, 7, 0, Fsc Debug Mode: Menu, 8, 0, Fsc A-key: 2539** Lg LX,VX-series, VX4400, VX6000, etc Nam Programming: Nam Set: ##Spc Nam Set: Menu, 0 Advanced Settings: ##2342 Vocoder: ##8626337,ok CAI Change: ##7738,ok Enable TTY: ##889,ok A-key: ##2539,ok Reset (Life time, Clear Memory, etc): ##786,ok <<SK TELETECH>> -------------------------------------------------------------------------------- Sky All Models Nam Programming: Nam Set: #7583538324#626# Nam Set: *759#364*7388464# Min simple mode: #758353266#646# Irm simple mode #758353266#476# Voice memo: #8767#277# Test Mode: #7583538324#8378# A-key: #758353266#2539# Service Menu: Menu+4+0+Spc Service Menu: Menu+5+0+Spc <<WITHUS / MODOTTEL>> -------------------------------------------------------------------------------- Withus wce-100, 200, 300, etc Nam Programming: Nam Set: ##948487+Save Nam Set: ##948482+Save Nam Set: ##66835+Save SMS Settings: ##76766 NVM Rebuild: ##777464 <<HYUNDAI>> -------------------------------------------------------------------------------- Hyundai hwp-110 Nam Programming: Nam Set: #86904**89397# DM Mode: ##2740* (Open phone, inter code, close phone) Hyundai hgc-120, 130, 200 Nam Programming: Nam Set: #86904**89397# Hyundai hgc-310, 600, 610 Nam Programming: Nam Set: ##20022002+Pwr+1+Spc Code Field Test: ##20022002+Pwr+1+Master Code Hyundai Curitel h-100, 150, hx-510b, 520 Nam Programming: Nam Set: ##20022002+Pwr+1+Spc Code Field Test: ##20022002+Pwr+1+Master Code A-key: 2539** Debug Menu: ##27732726+Pwr Sar Test: ##27752345+Pwr Baud Rate: ##36**+Pwr DM Mode Enable: **1004+Pwr DS Mode Enable: **1005+Pwr Test Bell/Voice/Led/Dot: ##1122+Pwr RF Mode: ##2240+Pwr Ras Ram: ##2774+Pwr Cmux1: **0481+Pwr Cmux2: **0482+Pwr RX Mode Fax: **0492+Pwr RX Mode Data: **0491+Pwr RX Mode Reset: **0490+Pwr <<HUAWEI>> -------------------------------------------------------------------------------- Huawei ETS-668, 678, 688, etc Nam Programming: Debug Mode: ##44+Menu Debug Screen: ##33+Menu CDG2 Test enable: ##234+Menu CDG2 Test disable: ##432+Menu China Lang Select: ##123+Menu Blocking Debug Code: ###888+Menu Home System Only On: ##461+Menu Home System Only Off: ##460+Menu <<ERICSSON>> -------------------------------------------------------------------------------- Ericsson A1228c, T61, etc Nam Programming: Short NAM: 987+Menu Long NAM: 923885+Menu+Spc CDMA Mode: 904093+Menu Analog Mode: 904095+Menu QNC: 904097+Menu Debug Screen: 904090+Menu DM Mode: 904050+Menu Sony-Ericsson T608 Nam Programming: Nam Set: 923885, Joystick to the right, 111111 <<EPSILON / COMPAL>> -------------------------------------------------------------------------------- Epsilon vc-5x Nam Programming: Nam Set: **147258963## Programming1: **1232580## Programming2: **321456987## Version: **1470963## Debug: **000000## Menu_1: **078987## Menu_2: **1234756## A-key: 2539** Reset: **14789## <<VK MOBILE>> -------------------------------------------------------------------------------- VK-100C, 110C, 200C, etc Nam Programming: Nam Set: 153147539741593 Test Mode: 153147539123258 (88 - clear efs) <<GIGA TELECOM>> -------------------------------------------------------------------------------- Z510, Z710i(gcd-456) Nam Programming: Nam Set: Menu+0+Spc <<AnyDATA>> -------------------------------------------------------------------------------- AMC450 Nam Programming: Nam Set: *74269#*748#96148063+SEL <<GTRAN>> -------------------------------------------------------------------------------- Gtran gcp-2000 Nam Programming: Nam Set: 01#737+Spc Debug Menu: 01#324+Spc Debug Mode: 01#727 Test Mode: 01#764+Spc System Test Mode: 01#768+Spc Gtran gcp-5000 Nam Programming: Debug Mode: 01#727+Spc Test Mode: 01#765 <<PANASONIC>> -------------------------------------------------------------------------------- PANASONIC TEST MODE: Panasonic (Most): 1) Turn on the phone. Press #7764726# choose SEND 2) Scroll down to where it says "NAM 1" and choose OK. Scroll down to "Access To Level 4" choose YES. Scroll down to "Built-In-Monitor" and choose EDIT. 3) Press 1 and choose OK then choose BACK. The phone will say "Back To Level 1" choose YES. Now choose EXIT the phone will ask you "Exit And Save Change" choose YES. 4) Signal strength is the top right number on the screen. 5) To turn off the test mode follow the above sequence except press 0 instead of 1 at the "Built-In-Monitor" <<SYNERTEK>> -------------------------------------------------------------------------------- Synertek S200 Nam Programming: Nam Set: Menu+0+Spc Debug Mode: Test vibro/rx/tx: ##5555+Save Debug Screen: ##33+Save Debug Screen: ##523+Save RF Test: ####+Save Unknown code: ##325+Save <<SONY>> -------------------------------------------------------------------------------- Sony CM-M1300, 3300, Z200 Nam Programming: Nam Set: 111111+Ok(Jog Dial)+Select+Programming+Ok+Spc Text File Also Attached Attached Files All CDMA codes.txt (15.4 KB, 420 views) Best Regards BEST CITY MOBIL JHELUM PAKISTAN |
All Gsm And Cdma Codes Available Only Here | Gulshan_80 | Hardware Repair by brands | 12 | 11-05-2009 03:11 |
All CDMA codes.txt | rajan nishchal | Various CDMA/TDMA Cell Phones | 94 | 08-07-2009 03:23 |
All cdma code here free free free | bantymobile | Various CDMA/TDMA Cell Phones | 22 | 04-13-2009 19:30 |
all cdma code | manishpareek | Various CDMA/TDMA Cell Phones | 0 | 09-18-2008 08:18 |
All Cdma Code | ROBISH_GSM | Various CDMA/TDMA Cell Phones | 2 | 03-29-2005 15:23 |
