Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Digital Core Technology 4 ( DCT-4 ) > WD2 & APE (Symbian Phones)
WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708.
Old 09-11-2007, 09:20   #1 (permalink)
W4r10rD's Avatar
Member: 183043
Thanks Meter: 68
9500
i've got a 9500. when i insert the battery it shows nokia, boot swith nokia hands and when it gets to halfway the big screen just switches off. the outside (phone) is working 100%, but the inside is not working. i formatted the phone, formatted the file system and wrote software but still the same problem. here is log:
Getting MCU ID
MCU ID: 0x1130
FLASH ID0: 00012A7E -> AMD Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 00000001 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
P-key nokia module version 01.00
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 4.49.00
01-06-2005
RA-2
(c) Nokia.
HW version: 6001
PCI version:
UEM version: 16
UPP version: 4400
RFIC version: 0205
DSP version: E4.10A4.20
Production serial number: YBA132834
Product code: 0516926
Module code:
Basic production code: 0630742
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 354305001201131
IMEI spare to net: 3A 45 03 05 10 02 11 03
IMEI SV to net: 33 45 03 05 10 02 11 03 F7
PDC: 4E 54 54 4A 50 12 34 56
Master Code: 0255155604
Phone type: RA-2, Software version: 4.49.00, Language Pack: not available
User code: 12345
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RA-2.ini
Saved INI not found, loading INI list...
Setting local mode...
Reading product code...
Product Code: 0516926
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RA-2\RA2_5221.4900
ADSP Flash file: C:\Program Files\Nokia\Phoenix\Products\RA-2\RA2n5221.c01
APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RA-2\RA2n5221.l01
APE User Flash file: C:\Program Files\Nokia\Phoenix\Products\RA-2\RA2n5221.u01
Languages in ppm: English,French,Dutch
Done!
Backing up PM Field 208 as RPL...
Reading IMEI...
Reading IMEI data...
Building RPL backup file...
C:\Program Files\ODEON\JAF\ProgData\354305001201131_imei_back up_107119.rpl
Done!
Backup imei OK!
MCU: C:\Program Files\Nokia\Phoenix\Products\RA-2\RA2_5221.4900
Booting phone...
MCU ID: 0x1130
BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
Loader version: 04.40.00 -> Revision: 0007
Boot size is 0x0970
Boot is ready...
Flash ID is 0x7E2A0100
Flash loader is C:\Program Files\ODEON\JAF\Flash\m_amd.fia
Loader size is 0x7C20; Loader chk: 95
Loader is ready...
MSID: 84C28B7B57EA0F9D7DA8072CD7
MSID decoded: 3E4EBAE9005E7A78AA000000
FAID: C5E80E24B01BDB097B52F988
Operation took 0 minutes 15 seconds...
Erasing...
Found 4 interval(s) to erase
Erasing area: 01000000 - 0100FFFF...
Erasing area: 01010000 - 0139FFFF...
ADL -> MCU ID: 0xB470
ADL -> FLASH ID: 0x07009800
ADL -> Loader: C:\Program Files\ODEON\JAF\Flash\OMAP1510_TOSHIBAMDOCG3_7.adl
ADL -> Sending loader...
ADL -> Waiting connection to loader...
ADL -> Verify connection...
ADL -> Done!
ADL -> Write: C:\Program Files\Nokia\Phoenix\Products\RA-2\RA2n5221.c01
ADL -> Writing flash...
ADL -> Write 5%
ADL -> Write 10%
ADL -> Write 15%
ADL -> Write 20%
ADL -> Write 25%
Erasing area: 013A0000 - 013EFFFF...
ADL -> Write 30%
Erasing area: 017A0000 - 017EFFFF...
Operation took 0 minutes 30 seconds...
Writing...
ADL -> Write 35%
ADL -> Write 40%
ADL -> Write 45%
ADL -> Write 50%
ADL -> Write 55%
Perm. Data Restore OK
Operation took 0 minutes 14 seconds...
ADL -> Write 60%
ADL -> Write 65%
ADL -> Write 70%
ADL -> Write 75%
ADL -> Write 80%
ADL -> Write 85%
ADL -> Write 90%
ADL -> Write 95%
ADL -> Write 100%
ADL -> Write: C:\Program Files\Nokia\Phoenix\Products\RA-2\RA2n5221.l01
ADL -> Write 5%
ADL -> Write 15%
ADL -> Write 30%
ADL -> Write 40%
ADL -> Write 45%
ADL -> Write 55%
ADL -> Write 70%
ADL -> Write 80%
ADL -> Write 85%
ADL -> Write 95%
ADL -> Write 100%
ADL -> Write: C:\Program Files\Nokia\Phoenix\Products\RA-2\RA2n5221.u01
ADL -> Write 85%
ADL -> Write 100%
ADL -> Done!
Restarting MCU...
Flashing Done!
Operation took 1 minutes 37 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
IMEI: 354305001201131
Resetting PPC...
Done!
Setting test mode...
Setting FULL FACTORY...
Operation took 0 minutes 4 seconds...
Done!
Resetting PRODUCTION TUNE...
Operation took 0 minutes 0 seconds...
Done!
Old 10-25-2007, 09:22   #2 (permalink)
Member: 266278
Thanks Meter: 12
Check the IC behind the internal keypad. Try to rehot or reball. if not change the keypad.
Good luck!
M 9500 EEP Dump Please tanim_1976 Infineon C16X M51 & ARM7 M52 BASED 0 05-18-2003 06:19
Any one know this Phone M 9500 !!!! tanim_1976 Infineon C16X M51 & ARM7 M52 BASED 0 02-26-2003 06:56
Sagem M 9500 PB EEprom 3 baraka42 Infineon C16X M51 & ARM7 M52 BASED 0 12-23-2002 12:51
Sagem MC 9500 zoki Infineon C16X M51 & ARM7 M52 BASED 0 06-28-2001 15:06
Page generated in 0.17540 seconds with 10 queries
