Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Digital Core Technology 4 ( DCT-4 ) > WD2 & APE (Symbian Phones)
WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708.
Old 07-10-2009, 16:05   #1 (permalink)
aleem26's Avatar
Member: 241661
Thumbs up All CDMA codes...................
Here i post many codes for cdma phones ..............................
Samsung sph-n240, n400, a460, a500, etc Nam Programming:
Nam Set: ##Spc
Test Mode: 47*869#1235
Debug Menu: ##33284,ok
Service Menu: Menu+8+0 (#889)
Reset (Life time, Clear Memory, etc): ##786,ok
A-key: ##2539,ok
Label Selection: ##3882,ok
Label(Home, Work, etc) : **523,ok
NGG Setting (Gateway, etc.): ##2769737,ok
Vocoder: ##8626337,ok
CAI Change: ##7738,ok
Enable TTY: ##889,ok
Samsung sch-411, 611, n105, a100, a300, a2000, etc Nam Programming:
Nam Set: 47*869#08#9
Nam Set: Menu+60
Test Mode: *759#813580
Test Mode: 5809540*45680
A-key: Menu+0, 25##
External Audio: Menu+0, ####
Debug Menu: Menu+8, 0415 or Spc
Debug Menu: Menu+9, 0415 or Spc
Brief NAM Programing: Menu+40,626 (not all version)
LCD Contrast: Menu+45 (not all version)
SIO Mode: Menu+49
SIO Mode: Menu+69
Samsung a300, a530, a610, a620, a660, a670, etc Nam Programming:
Nam Set: Menu, 6, *
Service Menu: Menu, 9, *
Test Mode: 47*68#13580
Samsung X, E, V, S-series (korean), e250, v420, s250, etc Nam Programming:
Nam Set: 6548#0**4#6
Nam Set: 74153697193
Test Mode: 5809540*45680 (88 - efs clear)
Debug Menu: Menu(hold 2sec)+0, 6725 or 9720 or 1973 or 0415
Debug Menu: Menu+0(hold 2sec), 6725 or 9720 or 1973 or 0415
Samsung N356 (India version) Nam Programming:
Test Mode: Menu, 5, down arrow, *
Test Mode: **00## (in some flashes)
Samsung i700, etc Nam Programming:
Nam Set: Go to start and select "PHONE" from the drop down menu, dial #83587
Samsung i300, etc Nam Programming:
1. Tap on the Phone Icon with stylus
2. Press #907*9#0 ENTER LOCK should appear on screen
3. Enter OTKSL
4. SVC MENU will appear press 1
5. Enter 10 digit MIN and then press SAVE
6. Press SAVE again
7. Press 3 and then press SAVE 6 times
8. Enter the HOME SID and press SAVE once
9. Press END key twice
TEST MODE COMMANDS:
n105_test_mode.txt
a500_test_mode.txt
a530_test_mode.txt
<<KYOCERA>>
Qualcomm qcp-800 Nam Pogramming:
Nam Set: Menu+3+0+Spc
Field Test: Menu+7+0+Fsc
Kyocera 1135, 2255, 3035, 5135, 6035, Se47, etc Nam Programming:
Nam Set: 111111+Jog Dial(Ok), Select "Programming"+Spc
Life Timer, PRL, etc: ##786,ok
A-key: ##2539,ok
A-key: 2539,ok
Tips:
On some kyocera handsets the factory service module has not been disabled
and the phone can be programmed without the spc by inputting.
Nam Set: ##333333 menu (service)
<<SANYO>>
Sanyo 4900, 5150, 5300, 8100, etc Nam Programming:
Nam Set: ##Spc+Ok+Key Down+Ok
Advanced Setup: ##3282+Ok+Key Down+Ok+Msl
A-key: ##2539+Ok+Key Down+Ok
Version: ##**837+Ok+Key Down+Ok
Debug Menu: ##FSC+Ok+Key Down+Ok
Airtime menu: ##8463+Ok+Key Down+Ok
Change CAI: ##7738+Ok+Key Down+Ok
Vocoder: ##8626337+Ok+Key Down+Ok
Reverse Logistic: ##786+Ok+Key Down+Ok
Set IP Address: ##2769737+Ok+Key Down+Ok
TTY On/Off: ##889+Ok+Key Down+Ok
Ready Link: ##4636+Ok+Key Down+Ok
Browser Init On/Off: ##4682+Ok+Key Down+Ok
Picture Token: ##25327+Ok+Key Down+Ok
Unknown Code: ##5282277+Ok+Key Down+Ok
(SPC=000000, FSC=040793)
Sanyo scp-A011, smp-A017, etc Nam Programming:
Nam Set: F9(3 beep) + 0*72696#767
<<NOKIA>>
Nokia 3280, 3285, 3580, 3585, 5185, 6185, 8280, etc Nam Programming:
Nam Set: *3001#12345#
Software Version: *#837#
Software Version: *#9999#
Esn Number: *#92772689#
Restart Phone: *#75681#
Restart Phone: *#75682#
Nokia 8887 Nam Programming:
Version: *#0000#
Evrc: *#8378#
Esn/Data/Timer: *#92772689#
SID: *#743#
Nokia 8587 Nam Programming:
Nam Set: *#626#7764726#
A-Key: #8159357022#4579# (26 digits)
A-Key: #8159357022#4547# (20 digits)
Version: *#0000#
Version: *#837#
Vocoder: *#3872#
Change language: Menu 5, 3, 1
Change DM mode: *#7678#
Debug Screen: *#8378#
Debug: *#8380#
Field Test Menu: *#83788#
SPC Unlock, Factory Reset:
Full Factory Reset: *#7370#
Resets all settings including non-user changeable items (like SPC)
NOKIA TEST MODE:
51xx, 61xx, 71xx, 3285, 63xx, etc:
1) Turn on the phone. Press *3001#12345#
2) Scroll up to where it says "Field Test" and choose SELECT
3) Highlight "Enable" and choose OK. Turn the phone off then back on.
4) If the test mode screen does not show up press MENU and scroll
down to "Field Test" choose SELECT. Press 0 1 then choose OK.
5) Lower left or upper left number is the signal strength.
6) To turn off the test mode press MENU and scroll down to where it says
"Field Test" choose SELECT. Press 0 0 and then choose OK.
3360, 6360:
down to "Field Test" choose SELECT. Press 2 1 0 1 then choose OK.
"Field Test" choose SELECT. Press 2 1 0 0 and then choose OK.
<<AUDIOVOX>>
Audiovox 4000, 9000, 9100, 9155, 9500, etc Nam Programming:
(Power the phone on and wait until the little light on top goes out)
Nam Set: 289+fcn+#+1
Service menu: fcn+00+fsc(000000)
Test Mode: Hold (2,*,Rcl)+Power
Test Mode Commands:
99 - download - flash phone
124 - inam data write
125 - version
126 - esn read
127 - sec_code
128 - lock_code
129 - is WFTV data write
137 - FSC code
138 - NPcode (nam program code)
139 - dscode
141 - restart
218 - Read_Addr
000 - is cdma mode
001 - is fm mode
002 - is pcs mode
008 - is reg read addr
020 - is lna_range
Audiovox pcx-3500xl Nam Programming:
Nam Set: ##2726+Send+1998+1+Spc+1
Audiovox cdm-100, 130, 135, 8300, 8500, 8600, etc Nam Programming:
Nam Set: ##20022002+Pwr+1+Spc
Audiovox 8610, 8910, etc Nam programming:
Name Set: ##847446, end, 111111
Audiovox-107 Nam Programming:
Nam Set: 45680*47*869#1
Audiovox CMP-3 Nam Programming:
Dm Mode: Menu, 6, 6
Audiovox 9950 Nam Programming:
Nam Set: ##3282
Audiovox Z800 (Audiovox 7900, Sharp) Nam Programming:
Nam Set: m + # + envelope key + * + 1
Audiovox Thera (Toshiba 2032) Nam Programming:
Thera Nam Programming User Manual - nam_thera.pdf
AUDIOVOX TEST MODE:
9100, 9155:
1) Turn on the phone. As soon the phone comes on and the green light
turns off press RIGHTARROW, 0, 0. The phone will ask for the
"FSC Code", press 000000 then choose OK and press RIGHTARROW,
RIGHTARROW. Your phone is now in test mode.
2) The signal strength is the number on the top right hand side of the screen.
3) To turn off test mode shut of the phone and then turn it back on.
<<MOTOROLA>>
Motorola 7760, 7860, 2260, 8160, etc Nam Programming:
Nam Set: Fcn,0000000000000, Rcl
Nam Set: 74663#, Fcn, Fcn
Test Mode: Fcn, 00**83786633, Sto
Motorola v60c, v120c etc Nam Programming:
Nam Set: 74663#, Menu, Menu, Spc
Nam Set: Menu, 073887, * (type quickly)
Test Mode: Menu, 073887*, Spc
Debug Mode: ##33284
Force the phone into DIGITAL ONLY mode:
1) ##33284 (Debug)
2) RIGHT Softkey (Next) Twice
3) Down arrow 10 times to "PrefMod"
4) RIGHT Softkey (Change) until you see "DigOnly"
5) LEFT softkey (Exit)
6) MENU then LEFT Softkey return to idle screen
7) ##33284 (The last 4 will not display if you have done it correctly)
Motorola t182, c210, etc Nam Programming:
Nam Set: ##1111 end
Nam Set: ##298645665 end
Short Nam: ##073887 sto
Motorola v710, v730, v740, ms150, etc Nam Programming:
Nam Set: 8378*# + press 3 times NATE (spc - 071082)
Service Menu: #758353266#646#
Motorola StarTac 2004 Nam Programming:
Nam Set: 5759789*#, rec key (3)times (spc - 915037)
Motorola ms200, ms230, etc Nam Programming:
Nam Set: 5759789*# (spc - 915037)
Motorola v6060 Nam Programming:
Nam Set:147*369#456*0#
MOTOROLA TEST MODE:
v60, c120, c331, etc:
1) Turn on the phone. Press MENU 0 7 3 8 8 7 *
2) The phone will require you to "Enter a Security Code", press 000000, OK
3) Scroll down to "Test mode" choose SELECT. Scroll down to "Enable"
choose SELECT. Your phone is now in test mode.
4) Signal strength is the 3_rd number down on the left hand side of the screen.
5) To toggle between regular mode and test mode: Press MODE then
quickly press the BUTTON DIRECTLY TO THE LEFT OF MENU.
6) To turn off the test mode the phone must be in regular mode, then follow
the above sequence and scroll down to where it says "DISABLE" instead of
"ENABLE" and choose select.
Motorola Bible - bible.txt
<<LG>>
lgc-300, etc Nam Programming:
Nam Set: Menu, 9, Spc
A-key: Press "Sto" 3sec, 2539**
lgc-330w, etc Nam Programming:
Nam Set: Menu, 4, 0, Spc
A-key: 2539**
lgc-510, v111, etc Nam Programming:
Nam Set: Menu, 3, 0, Spc
A-key: 2539**
lgc-500, 800w, etc Nam Programming:
Nam Set: Menu, 9 , 0, Spc
Debug Mode: Menu, 7, 0, Fsc
Debug Mode: Menu, 8, 0, Fsc
A-key: 2539**
Lg LX,VX-series, VX4400, VX6000, etc Nam Programming:
Nam Set: ##Spc
Nam Set: Menu, 0
Advanced Settings: ##2342
A-key: ##2539,ok
<<SK TELETECH>>
Sky All Models Nam Programming:
Nam Set: #7583538324#626#
Nam Set: *759#364*7388464#
Min simple mode: #758353266#646#
Irm simple mode #758353266#476#
Voice memo: #8767#277#
Test Mode: #7583538324#8378#
A-key: #758353266#2539#
Service Menu: Menu+4+0+Spc
Service Menu: Menu+5+0+Spc
<<WITHUS / MODOTTEL>>
Withus wce-100, 200, 300, etc Nam Programming:
Nam Set: ##948487+Save
Nam Set: ##948482+Save
Nam Set: ##66835+Save
SMS Settings: ##76766
NVM Rebuild: ##777464
<<HYUNDAI>>
Hyundai hwp-110 Nam Programming:
Nam Set: #86904**89397#
DM Mode: ##2740*
(Open phone, inter code, close phone)
Hyundai hgc-120, 130, 200 Nam Programming:
Hyundai hgc-310, 600, 610 Nam Programming:
Nam Set: ##20022002+Pwr+1+Spc Code
Field Test: ##20022002+Pwr+1+Master Code
Hyundai Curitel h-100, 150, hx-510b, 520 Nam Programming:
A-key: 2539**
Debug Menu: ##27732726+Pwr
Sar Test: ##27752345+Pwr
Baud Rate: ##36**+Pwr
DM Mode Enable: **1004+Pwr
DS Mode Enable: **1005+Pwr
Test Bell/Voice/Led/Dot: ##1122+Pwr
RF Mode: ##2240+Pwr
Ras Ram: ##2774+Pwr
Cmux1: **0481+Pwr
Cmux2: **0482+Pwr
RX Mode Fax: **0492+Pwr
RX Mode Data: **0491+Pwr
RX Mode Reset: **0490+Pwr
<<HUAWEI>>
Huawei ETS-668, 678, 688, etc Nam Programming:
Debug Mode: ##44+Menu
Debug Screen: ##33+Menu
CDG2 Test enable: ##234+Menu
CDG2 Test disable: ##432+Menu
China Lang Select: ##123+Menu
Blocking Debug Code: ###888+Menu
Home System Only On: ##461+Menu
Home System Only Off: ##460+Menu
<<ERICSSON>>
Ericsson A1228c, T61, etc Nam Programming:
Short NAM: 987+Menu
Long NAM: 923885+Menu+Spc
CDMA Mode: 904093+Menu
Analog Mode: 904095+Menu
QNC: 904097+Menu
Debug Screen: 904090+Menu
DM Mode: 904050+Menu
Sony-Ericsson T608 Nam Programming:
Nam Set: 923885, Joystick to the right, 111111
<<EPSILON / COMPAL>>
Epsilon vc-5x Nam Programming:
Nam Set: **147258963##
Programming1: **1232580##
Programming2: **321456987##
Version: **1470963##
Debug: **000000##
Menu_1: **078987##
Menu_2: **1234756##
A-key: 2539**
Reset: **14789##
<<VK MOBILE>>
VK-100C, 110C, 200C, etc Nam Programming:
Nam Set: 153147539741593
Test Mode: 153147539123258 (88 - clear efs)
<<GIGA TELECOM>>
Z510, Z710i(gcd-456) Nam Programming:
Nam Set: Menu+0+Spc
<<AnyDATA>>
AMC450 Nam Programming:
Nam Set: *74269#*748#96148063+SEL
<<GTRAN>>
Gtran gcp-2000 Nam Programming:
Nam Set: 01#737+Spc
Debug Menu: 01#324+Spc
Debug Mode: 01#727
Test Mode: 01#764+Spc
System Test Mode: 01#768+Spc
Gtran gcp-5000 Nam Programming:
Debug Mode: 01#727+Spc
Test Mode: 01#765
<<PANASONIC>>
PANASONIC TEST MODE:
Panasonic (Most):
1) Turn on the phone. Press #7764726# choose SEND
2) Scroll down to where it says "NAM 1" and choose OK. Scroll down
to "Access To Level 4" choose YES. Scroll down to "Built-In-Monitor"
and choose EDIT.
3) Press 1 and choose OK then choose BACK. The phone will say
"Back To Level 1" choose YES. Now choose EXIT the phone will ask you
"Exit And Save Change" choose YES.
4) Signal strength is the top right number on the screen.
5) To turn off the test mode follow the above sequence except press 0
instead of 1 at the "Built-In-Monitor"
<<SYNERTEK>>
Synertek S200 Nam Programming:
Nam Set: Menu+0+Spc
Debug Mode:
Test vibro/rx/tx: ##5555+Save
Debug Screen: ##33+Save
Debug Screen: ##523+Save
RF Test: ####+Save
Unknown code: ##325+Save
<<SONY>>
Sony CM-M1300, 3300, Z200 Nam Programming:
Nam Set: 111111+Ok(Jog Dial)+Select+Programming+Ok+Spc
Text File Also Attached
Best Regards
BEST CITY MOBIL JHELUM PAKISTAN
Old 07-10-2009, 16:22   #2 (permalink)
VIBINDAS_INDIA's Avatar
Member: 707582
Sonork: 100.1620432
nice post,keep it up
thank you
Old 07-10-2009, 16:35   #3 (permalink)
Member: 1059036
thanks bro plz code reset samsung w619 2 sim
Old 07-10-2009, 20:15   #4 (permalink)
cabycyba's Avatar
Member: 1055056
great job
nice share
All Gsm And Cdma Codes Available Only Here Gulshan_80 Hardware Repair by brands 12 11-05-2009 02:11
All CDMA codes.txt rajan nishchal Various CDMA/TDMA Cell Phones 94 08-07-2009 03:23
All cdma code here free free free bantymobile Various CDMA/TDMA Cell Phones 22 04-13-2009 19:30
all cdma code manishpareek Various CDMA/TDMA Cell Phones 0 09-18-2008 08:18
All Cdma Code ROBISH_GSM Various CDMA/TDMA Cell Phones 2 03-29-2005 14:23
Page generated in 0.34048 seconds with 11 queries
