Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708. |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2004 Location: ROMANIA Age: 35
Member: 55427 Status: Offline Thanks: 2
| BlueTooth Problem on 6600 HI, I tryed to upgrade soft to 6600 from 3.42.1 to 4.09.1 and got this error: 1st Boot Ok, WD2, UPP: 0082 Fl0: 0x00000000-0x007FFFFF,002088BE,St M28W640 Fl1: 0x02000000-0x027FFFFF,002088BE,St M28W640 Fl2: 0x04000000-0x047FFFFF,002088BE,St M28W640 Fl3: 0x06000000-0x067FFFFF,002088BE,St M28W640 Algorithm: w2_st_i.fia, w2_cbusb.fia Algorithm Ok, MSID: 84A45C75AC15AF242BB7E23AD4 Decoded MSID: 3E4EBAF7-004B7348-AA000000 Encoded FAID: 1110C6E1-C00E5E4D-DA59F2CE Area: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area: 0x00010000-0x007FFFFF Erased, Time: 02:02 Area: 0x04000000-0x046FFFFF Erased, Time: 01:50 Area: 0x06000000-0x066FFFFF Erased, Time: 01:47 Area: 0x047C0000-0x047EFFFF Erased, Time: 00:03 BT MCM (21) Image Found: 0x0002DD94 Write Error: Not Rdy, at: 0x000000DC Process Failed, Repowering Mobile So i retryed to flash skiping BlueTooth part and all was ok. But now Bluetooth doesn`t work anymore, because firmware was erased. I tryed to write many times but allways same error. How can i write bluetooth firmware. I mention that i use twister. 10x in advance |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2002 Location: Tutuban Age: 57
Member: 10635 Status: Offline Thanks: 2
| Hi, Pls check this thread for solution.. http://forum.gsmhosting.com/vbb/f348/nokia-7650-bt-problem-167316/#post912256 BR, epic |
| | #3 (permalink) | |
| Quote:
| | #4 (permalink) |
| No, absolutely software problem only, well I have tried it ufs for days but i did not find the solution yet, maybe somebody might have done this and post here the step to do.. BR, epic |
| | #7 (permalink) | |
| Quote:
To all, thanks for reply, no i didn`t try to flash back old firmware. I will try, and post results BR | |
| | #8 (permalink) |
| Super Moderator ![]() Join Date: Jan 2004 Location: INDIA,Gujarat,Surat Age: 28
Member: 49752 Status: Offline Sonork: 100.112446 Thanks: 105
| i alredy solved problem with 2 phones ....only erase problem just erase flash with erase option on ufs...then try flash...new version 5.27 all ok..... |
| | #9 (permalink) | |
| Quote:
Thanks B R | |
| | #10 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Nov 2004 Location: india Age: 31
Member: 89795 Status: Offline Thanks: 0
| helo i have an 6600 it shows "application clossed" .first i format itthen not ok then i flash it ,while erase flash erassing it is ok,after that while flashing first boot ok 2nd boot ok,then shows c bus error in ufs pls give any solution |
| | #11 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2003
Member: 43976 Status: Offline Thanks: 0
| Fixed a 7650 by this method; Try to flash it with selecting BT Hw to "Old". If it doesn't, try "Auto" and "New". Regards JFK Last edited by JFK; 11-16-2004 at 09:53. |
| | #15 (permalink) | |
| Quote:
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How can i repair bluetooth problem on D500? | roniri | TST Dongle | 1 | 10-04-2005 06:55 |
| 3D Rally Pro Problem on 6600 | ruliza | Nokia Multimedia | 1 | 11-11-2004 01:06 |
| Infrared and Bluetooth problem on GX30 | alekso | Sharp | 1 | 08-19-2004 16:10 |
| Problem on 6600 | MicrostarGSM® | UFS2 + UFS3-Tornadoflasher | 24 | 03-29-2004 14:38 |
| UltraMP3 Problem on 6600 | xms_nard | Nokia Multimedia | 6 | 03-08-2004 20:26 |
