Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Digital Core Technology 4 ( DCT-4 ) > WD2 & APE (Symbian Phones)
WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708.
Old 01-01-2004, 20:44   #1 (permalink)
Member: 47947
Exclamation need some advice for nokia6600
im looking to buy some sort of data connection for transfering files into my comp ..ive seen some of these dongles blue tooth are they any good...and wat web-site would be the best 1 to buy it from..
thnx:
Old 01-02-2004, 02:35   #2 (permalink)
GazI's Avatar
Member: 20566
Thanks Meter: 29
i think it is better to bue one datacabel for this phone
paqe njeri
Old 01-04-2004, 16:34   #3 (permalink)
Member: 48130
IS THE A MBUS CABLE FOR THIS PHONE IF THERE IS WERE IS IT PLZ
Old 02-11-2004, 11:33   #4 (permalink)
Member: 52289
I just bought a Nokia 6600 n Billionton USB Bluetooth Adapter (USBBT02-B).
I can send pic from my phone to pc via the bluetooth, however, the nokia mRouter is unable to made a connection with my pc.
Anybody can help??
Thank you.
Old 02-11-2004, 14:00   #5 (permalink)
Member: 52517
Smile
I'm using a belkin F8T001 bluetooth adapter[usb] and a generic sigma 4000 irda adapter[usb] the Nokia datasuite can see the irda [it also sees com 1 and 3]but not bluetooth. I've got to use the belkin software to transfer anything via bluetooth because datasuite just will not see it 'tho I've been told but so far unconfirmed that the nokia datasuite and Belkin bluetooth will work????? anyone confirm, deny?, which means some sis files won't install properly.
In general the irda works well with datasuite, but leaves a lot to be desired as it gives limited access to the file tree in the phone, to get full access you need seleq or fexplorer which being based in the phone mean a lot of manipulating files around....ho hum! ace phone let down by neutered P.C. side software.
Old 02-11-2004, 15:40   #6 (permalink)
Member: 53267
Exclamation Bluetooth and the 6600
I have a Belkin USB Bluetooth adaptor (10 Metre USB Dongle) and use that fine on a 6600, to get it to go on PC Suite, you need to activate a serial connection using your bluetooth tools then M Router should auto detect it using the icon on your computer, only then do you open PC Suite. To shut down, just double click the serial connection icon again, it will sometimes say some sort of error, but usually M Router gets the hint and disconnects.
So yes I can confirm that it is possible, mine works, using the Belkin Bluetooth to a 6600 (firmware 3.45.1) but it was a VERY fiddy thing to set up, I used to have the N-Gage and that never wanted to work on PC Suite, and with that handset infrared wasn't an option!
Infrared is still the most stable though, but requires you to put your phone on funny angles to line up with the IR port on your computer.
But I would not use any sort of cable on the 6600 unless you were going to reflash the handset or something.
Old 02-12-2004, 17:20   #7 (permalink)
Member: 52517
U R a star Nexxus that works a treat....tried allsorts...but never that thanks.
Old 02-12-2004, 17:48   #8 (permalink)
Member: 53267
Glad to help
Old 02-15-2004, 14:14   #9 (permalink)
Member: 52390
I used those dongle bloototh usb adapters and i had a big difficulties installing it ... it only sent files to my phone ... nothing else ... anyway ... difficult to install
I need some advice Mansoor Universalbox 3 10-24-2008 15:28
need some advice... jayfox101 Off Topic Zone 10 08-03-2008 13:29
Need some advice pls teerak2uk Motorola P2k 2 10-15-2006 22:40
i need some advice!!!!! alistair ARM9 BASED M62 / M62+ 1 07-17-2005 17:01
I need some advice about hot air station... sifasli Hardware Repair by brands 4 03-02-2002 18:15
Page generated in 0.21091 seconds with 10 queries
