Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Digital Core Technology 4 ( DCT-4 ) > WD2 & APE (Symbian Phones)
WD2 & APE (Symbian Phones) All WD2 like 3230, 3650, 3660, 6260, 6600, 6650, 6670, 7610, 7650, N-Gage, N-Gage QD also here we can get all About APE phones like 9500, 9300, 9300i, 7710, 6620, 6708.
Old 10-18-2004, 03:50   #1 (permalink)
Member: 51453
Thanks Meter: 729
error on 3650 what does it mean?
st Boot Ok, WD2, UPP: 0082
Fl0: 0x00000000-0xFFFFFFFF,00092A20,Unknown
Fl1: 0x02000000-0x01FFFFFF,38301012,Unknown
Fl2: 0x04000000-0x03FFFFFF,0B01383B,Amd
Algorithm: Unknown, w2_cbusb.fia
2nd Boot Error:
Error Data1:
00000000: 9B 04 04 00 09 00 20 2A 00 00 20 2A 02 30 38 12 ...... *.. *.08.
00000010: 10 00 00 3B 38 04 01 0B 3B 38 00 00 00 06 06 00 ...;8...;8......
00000020: 00 01 00 00 00 00 00 09 00 20 2A 07 01 20 2A 06 ......... *.. *.
00000030: 01 20 2A 05 01 20 2A 85 00 00 00 00 00 00 00 00 . *.. *.........
Error Data2:
00000000: 00 09 00 20 2A 00 00 20 2A 02 30 38 12 10 00 00 ... *.. *.08....
00000010: 3B 38 04 01 0B 3B 38 00 00 00 06 06 00 00 01 00 ;8...;8.........
00000020: 00 00 00 00 09 00 20 2A 07 01 20 2A 06 01 20 2A ...... *.. *.. *
00000030: 05 01 20 2A 85 C3 72 60 93 D9 6E FE E2 DD 91 F3 .. *..r`..n.....
Before taking screenshot, expand this window !
Process Failed, Repowering Mobile
Old 10-19-2004, 20:01   #2 (permalink)
Member: 56337
try flash erase flash in mcu.
when you flashing the phone try to connect the charger.
Old 10-23-2004, 02:39   #3 (permalink)
Member: 17337
Thanks Meter: 12
first try to skip flashing bt (bluethooth) while flashing your phone if it doesn't help try to reheat ic flash or change it
Old 10-25-2004, 14:26   #4 (permalink)
mobx montenegro's Avatar
Member: 78958
I have similiar problem when I try to flash 3650 twister has
data erorr platform 6 and stops flashing!
anybody know what is mean this??
best regrts
Old 10-25-2004, 15:38   #5 (permalink)
hans0001's Avatar
Member: 84177
Thanks Meter: 29
I don't know wat is d meaning of that errors,but i know the solution....FLASH d PHONE with GRIFFIN...
good luck
Old 10-27-2004, 22:16   #6 (permalink)
Member: 78958
good luck
griffin alwais do job when twister fall
I only rehot flash ic and upp after that no conections with two boxes,maybe I shud reballolite flash?????
Old 10-29-2004, 15:47   #7 (permalink)
Member: 7335
hello
i have same problem need help
regards
Old 10-31-2004, 13:29   #8 (permalink)
Member: 4188
Change the flash I.C.
Old 11-01-2004, 15:13   #9 (permalink)
Member: 78958
there are 3 rom memories and sec sdram!!!how can i find which flash ic is maybe dead,i try to find manual and looked beter the shematic of flash sistem and i will back with new ideas!!
Old 11-15-2004, 11:30   #10 (permalink)
Member: 4188
Change all 3 Flash I.C. , it will solve the flash problem. Changing of UEM depends on the next error message. Write Flash, RPL (if required), PMM ,Unlock and Factory Defaults.
You're done. 8-)
Old 11-17-2004, 05:48   #11 (permalink)
e64y's Avatar
Member: 30582
good luck
With griffin,u will have Error[BDBDADAD]
Old 11-18-2004, 17:12   #12 (permalink)
hans0001's Avatar
Member: 84177
Thanks Meter: 29
That means hardware solution is needed,reheat the flash ic's,if not ok,replace them.
gud luck
Old 11-24-2004, 22:35   #13 (permalink)
Member: 78958
ok dood,now i have one question about flash ic!
is flash ic for nokia 3650 ready to resold on bord when i by it?do i need some kind preprograming the ic or it is simple like>by ic from specialisated store and resolded,flashed like you are last posted unlockphone4
Old 11-24-2004, 22:52   #14 (permalink)
mohammad2004's Avatar
Member: 71144
Thanks Meter: 12
replace flash and ram ic
No firmware on smartcard! - What does it mean? corbin Multi-Box 7 08-19-2006 08:34
Platform: 4 Error what does it mean? RafalTK Twisterflasher 0 06-17-2005 14:39
x70 e/400/command execution error what does it mean? sutiee Panasonic 2 03-24-2005 09:45
Page generated in 0.32684 seconds with 8 queries
